Results 1 to 25 of 41
What's the legal limit again?
    Banned Euro trash-hole BCT748's Avatar
    Apr 2008
    Salem NH
    Thanks to Ted for letting me play with his decibel meter I now know just how obnoxious my bike really is. I tested my brothers 675 with a Jardine at the same time for a little comparison.
    2006 Triumph 675 w/ Jardine slip on:
    Idle: 92Db
    4,000:115Db
    Red line: 118Db
    1999 Ducati 748 w/ hollow V&H
    Idle: 95Db
    4,000: 110Db
    Red line: 128Db
    This test was done a little quick because my garage is in a pretty dense neighborhood so it was a single pull on each bike before someone called the cops. I think my 4K reading should have been a little higher but with only a quick single pull it's hard to tell. In the spring I'll get a more accurate reading (hopefully it wont be preformed by a LEO)
    Unofficial self proclaimed official NESR plumber.
    "Ah shit son, datz be a Ducati!"-Random kid in Methuen.
    Re: What's the legal limit again?
    Quote Originally Posted by BCT748 View Post
    Idle: 95Db
    4,000: 110Db
    Red line: 128Db
    Just like a Honda Civic, all that noise and still makes less than 80 horsepower.
    Just Registered Brian675's Avatar
    NH
    Is this another attempt to tell us all how your bike is the mother fuckin shit?
    I am trying to find a way to quiet down my gixxer at the moment too. Have a D&D on it right now and have a Vance and Hines that I am going to try. Don't have much hope for it though. Will probably end up building one myself. I don't even want to know what it blows right now.
    Apr 2008
    Salem NH
    92 and change asshole
    Quote Originally Posted by Brian675 View Post
    Pete? Is that you?
    Who said I was trying to quite it down? If anything I'm trying to max out the meter that goes up to 130
    HEY! My Civic makes 197.
    Two Brothers
    D&D
    V&H
    MIVV
    All very loud.
    Yoshimura, not very loud.
    800 miles this year Danno's Avatar
    Cambridge
    You'll want to take the reading outdoors and measure how far away you are. Then we can calculate how legal you're not.
    My latest mantra for MA cage drivers
    -- "The rocks in your brain are the gravel in my path" --
    Meriden, Ct
    So does my GSX-R!
    Apr 2008
    Salem NH
    Quote Originally Posted by Danno View Post
    It was outside and I followed the directions that came with the meter. I just didn't hold the RMP that long for it to top out because of the neighbors.
    Riiiiiiiight...
    Riiiiiiiight...
    So does my GSX-R!
    Riiiiiiiight...
    Apr 2008
    Salem NH
    Riiiiiiiight...
    Sorry, 91.67 at the wheel. I accidentally lied about 1hp
    0.08 right?
    Idle: 92Db
    4,000:115Db
    Red line: 118Db
    Idle: 95Db
    4,000: 110Db
    Red line: 128Db
    actually, no, 3500rpms is the test level, my SV used to pass just barely, @ 2800 rpm ( rpms for twins & thumpers to test at, nice of them to give an edge to harleys) @ 5000rpm, I was pumping out 120db but still passed , I'd be willing to bet the duc, cause its' a twin passes easily, the T, maybe not
    266:59-a Motorcycle Noise Levels. –
    I. No person shall operate a motorcycle which has a measured noise level of more than 106 decibels on the decibel meter when measured 20 inches from the exhaust pipe at a 45 degree angle while the engine is operating at 2,800 revolutions per minute for one and 2 cylinder motorcycles and 3,500 revolutions per minute for any motorcycle with 3 or more cylinders.
    Two Brothers
    D&D
    V&H
    MIVV
    All very loud.
    D&D and V&H just came with it, so I thought I would try those first. Going to try to custom make one at the local shop using parts next, as leaving at 6:30 in the morning isn't going to please my neighbors. They already hate me enough for the rm125 in my field.
    NH
    Quote Originally Posted by tom3040 View Post
    0.08 right?
    and we have a winner!
    Lifer LuvDog's Avatar
    Ashland, MA
    Idle: 95Db
    4,000: 110Db
    Red line: 128Db
    Were those the sound levels of your clutch rattling around?
    2003 ZX7R
    1995 916
    Senior Member roadracer685's Avatar
    Mar 2007
    probably still not as loud as my harley all of the noise and none of the HP made a whopping 79rwhp and 81ftlbs stock with pipes so there! (not for long though motor is apart as we speak)
    Part time expert,part time hooligan
    Just Registered Doc's Avatar
    Jericho, VT
    Dude get a real bike!
    Do you still have the silly sticker on it?
    I kid, I kid!
    Lifer jwm2k3's Avatar
    Mar 2004
    Lynn, MA
    LOLOLOLOLOL!!
    Southern, NH
    Does your pipe do this?
    Dyno Jets are VERY Optimistic
    Zip Tie Alley Racing #444
    Signature edit by Tricky mike
    Tucson, AZ
    OMG your bike is loud... that makes me so
    Original
    Apr 2008
    Salem NH
    If I get a chance I'll run it at 2,800 and see what I get. I went with 24" at a 45 degree angle. I'm going to try the different settings on the reader to see if anything makes a difference, it was set on slow which takes a full second to read but the fast setting is only 1/10th of that and there is another setting that I don't fully understand yet.
    Still haven't gotten around to throwing on the vented cover so the clutch is still relatively quiet
    I kid, I kid!
    I'm working my way up the real bike chain
    The sticker has been gone for a while, some asshole stole the fucking thing
    Nope, mine actually runs right
    Quote Originally Posted by BLACK SQUIRREL 441 View Post
    From what I've seen they are pretty close to most other dynos, give or take a couple HP. There's more power in it, not that much but a little, it still needs to be tuned.
    Quote Originally Posted by jnm988 View Post
    OMG so are you
    Tucson, AZ
    Quote Originally Posted by MVOUS View Post
    depending on what state you live in the legal limit is 16. Some states its 18.
    thats what you were asking about right?
    www.ageofconsent.com is my bible.
    Original
  1. No Cops, Yes Cars, No Limit!
    By RocketPunch in forum General Bike Related
    Last Post: 07-19-13, 11:50 AM
  2. Age Limit
    By capt1014 in forum Pit Area
    Last Post: 08-28-06, 01:33 PM
  3. Stretch limit on a 530 chain.
    By SVixxer in forum Bike Maintenance
    Last Post: 10-04-05, 05:08 AM
