I had a "mishap" with a certain YZ125 yesterday and not sure how bad it is. I lost the front in some sand around my parking lot at work, bike went down slid for a few feet then went into the side of my shed. I picked the bike up and this is the only damage I found
and
As you can see the forks are a little uneven, and the wheel isn't exactly sitting straight.
Any ideas? Anyone want to buy it?
It looks like they may have shifted, in the triples and are not bent, Take the wheel of and loose the triples and see if they are bent
you may have bent the triples
I still miss that bike
Zip Tie Alley Racing #444
Signature edit by Tricky mike
Check the top of the forks and make sure the same amount is exposed - adjust them if you need to. Then - Stand in front of the bike with the front wheel between your legs and torque the handle bars in the direction you want them to go. Don't be afraid to get 'persuasive' with it. Worst case - loosen the triple clamps up a little and then torque on it.
SSearchVT
loosen the axle/pinch bolts as well...get everything loose and straighten/retighten and see how it looks
LRRS #399
MX #505
It'll buff right out.
As long as you run your course counter clockwise, I don't see a problem?
James Stewart's front end looked twisted worse than that last night and he came from DFL in the first turn back to 7th.
