Results 1 to 13 of 13
Does this look expensive?
    Posting Freak idratherberidin's Avatar
    Apr 2008
    Danvers, Ma
    I had a "mishap" with a certain YZ125 yesterday and not sure how bad it is. I lost the front in some sand around my parking lot at work, bike went down slid for a few feet then went into the side of my shed. I picked the bike up and this is the only damage I found
    and
    As you can see the forks are a little uneven, and the wheel isn't exactly sitting straight.
    Any ideas? Anyone want to buy it?
    Re: Does this look expensive?
    It looks like they may have shifted, in the triples and are not bent, Take the wheel of and loose the triples and see if they are bent
    you may have bent the triples
    I still miss that bike
    Zip Tie Alley Racing #444
    Signature edit by Tricky mike
    Waterbury, VT
    Check the top of the forks and make sure the same amount is exposed - adjust them if you need to. Then - Stand in front of the bike with the front wheel between your legs and torque the handle bars in the direction you want them to go. Don't be afraid to get 'persuasive' with it. Worst case - loosen the triple clamps up a little and then torque on it.
    SSearchVT
    Apr 2008
    Danvers, Ma
    Quote Originally Posted by BLACK SQUIRREL View Post
    It looks like they may have shifted, in the triples not bent, Take the wheel of and loose the triples and see if they are bent
    Thanks, I'll give that a shot. The bikes been really good to me. I have a nice little track that goes around my warehouse and have been tearing it up every chance i get. It still starts first kick, even after the accident.
    Apr 2008
    Danvers, Ma
    Thanks. It looks like I have something to do next week at work.
    live to ride seth399's Avatar
    Feb 2007
    CA
    loosen the axle/pinch bolts as well...get everything loose and straighten/retighten and see how it looks
    LRRS #399
    MX #505
    Lifer lrrs313's Avatar
    Asheville, NC
    Quote Originally Posted by seth505 View Post
    +1
    Doesn't look bad at all -- actually happens quite a lot to some bikes in the dirt.
    Apr 2006
    Beverly, MA
    It'll buff right out.
    As long as you run your course counter clockwise, I don't see a problem?
    Asheville, NC
    James Stewart's front end looked twisted worse than that last night and he came from DFL in the first turn back to 7th.
    May 2007
    Southern NH
    kinda what I was thinking....
    Muhammad Ali.
    Feb 2004
    Bellingham, MA
    I fix those all the time, $100 if you bring in the front end, $175 if you bring in the whole bike.
    Posting Freak 6 Fingered Man's Avatar
    Feb 2009
    Exeter NH
    Quote Originally Posted by lrrs313 View Post
    That was awesome, that kid can ride it pisses me off.
    I would make sure it is straight and then look for a set of aftermarket triples stock ones do that all the time.
  1. Is expensive gear more durable?
    By number9 in forum Dirty Bastards
    Last Post: 06-03-17, 08:11 PM
  2. expensive tape!
    By Paul_E_D in forum General Bike Related
    Last Post: 02-20-08, 02:15 PM
  3. How expensive is racing?
    By Lucky13 in forum General Bike Related
    Last Post: 10-08-04, 03:32 PM
