Results 1 to 22 of 22
Looking for an odd-sized tube locally
    Swapping the dirt tires off the CRF I bought for some scooter tires. I ended up puncturing the tube I bought pretty badly. I tried patching it, but it didn't hold air overnight. So, back to the drawing board and looking for a new tube locally.
    Does anyone know of any scooter dealerships in MA/RI?
    I am calling all of the motorcycle dealerships in the area and none seem to have the scooter tube size I need, which is a 4.00/4.60-14.
    The other question is, is there anyone one here that is good at truing a spoked rim? I may be in need.
    Re: Looking for an odd-sized tube locally
    Dude. Use a stock tube.
    Tire I bought is wider. I'm just going by what Josh mentioned and I what found from asking on the mini racing forum section of the WERA board. (http://www.cb450stuff.com/tires/). Stock is a 3.00/3.60-14, substantially smaller.
    Jan 2010
    cny
    only place i'd think of is maybe redstreak motors in marlboro?
    Quote Originally Posted by gamorg02 View Post
    Called and they don't have one. Thank you for the tip though.
    Just have them order it. They should be able to get it by tomorrow.
    Lifer JohnnyV's Avatar
    Westborough, MA
    Rt. 9 Westbound Framingham. Try them
    https://www.metrowestscooter.com/
    No hurry. But wanted to X it off the list.
    I take it you never have inflated a tube that's not in a tire before. They stretch. A lot. A stock tone will do the job just fine without stretching the rubber beyond its capability.
    Just order it and be done.
    Not since I rode bicycles as a kid. I've never had to replace the tubes in road or mountain bikes I've owned as an adult.
    Same deal. None in stock.
    Done. (but still looking locally to see if I can get one today)
    Jun 2005
    I'm with Chipppppaaaaahhhhh. I'd use the stocker.
    It's a pitbike ferchrissakes.
    Lifer Pittenger5's Avatar
    Austin
    This is Chuckles we're talking about. It doesnt matter the purpose of the item at hand.
    Zip Tie Alley #505
    Hit the nail on the head. I'd rather use the right one that something that just "works".
    Jun 2005
    that shit cray
    These tubes are susceptible to both pinch flats and wear flats on mini-tards so I tend to prefer not undersizing the tube, although the smaller tubes are easier to install initially. Worst case if you undersize it'll install cleanly and then fail early. When you go to install the new tube, put just a little air in it. Not enough so that it has any pressure or tension, but enough so it's not a pressed flat washer. That'll help prevent folds and keep it slightly off the rim and sidewalls while you work the bead on.
    I did some video research on installing and found just what you mentioned. Unfortunately, the first rear tire/tube I installed I got all the way around and it was the very last bit of the tire I had to get onto the rim that bit the tube. I immediately heard the air I had put in (to aid, as suggested) rush out. I know I was screwed.
    These things aren't cheap either. $13.99 + shipping. This time, I ordered 2, just in case.
    KB KB's Avatar
    Manchester NH
    USE THE STOCK ONE
    Chuck you crack me up.
    What would you do without the internets?
    LRRS/CCS EX #13
    GMD COMPUTRACK
    Gee wouldn't know what a sumo mini was and would cruise around the pits with his straw hat and knobbies.
    USE THE STOCK ONE
    Well, I wouldn't have a job, for one thing.
    You know I like being difficult.
    Jun 2005
    Chucklez if you're up at a Bomo day ask me to show you the sparks my "pitbike" throws from the brake levers. I'm pretty sure the tubes are the right size, though.
  1. Survey - Mid Sized Tire Warmer
    By Woodcraft in forum Woodcraft
    Last Post: 11-11-15, 11:52 AM
  2. Small sized and ladies gear
    By Expat in forum For Sale
    Last Post: 05-24-12, 03:10 PM
  3. kid-sized leathers
    By Kitt in forum Wanted
    Last Post: 04-05-10, 04:58 PM
