My 450 lb sport bike puts 790 ft-lbs of torque to the rear wheel in first gear. 70 ft-lbs at the crank*1.714 primary reduction *2.562 final reduction*2.571 first gear reduction
I can easily generate 250 ft-lbs of torque with a decent-sized 1/2" drive ratchet and my arms, but I cannot beat a Harley in a race. Torque is meaningless, HP is everything.
What harleys are these with 130-145 ft.lbs. of torque? Your typical big-twin HD is around 70-80 ft.lbs., and even the wheelie-bar equipped, strip-only Destroyer tops out at 97 ft.lbs. @ 7600rpm.
The suzuki M109 is the torqueyist v-twin cruiser I'm aware of, with 118 ft.lbs of torque, but still only manages a 12-second 1/4 mile. A ZX-14 on the other hand produces about the same peak torque but has about 70 more peak horsepower, and is a solid 3 seconds faster in the 1/4.
V-twin cruisers are not fast. Most 600s will smoke nearly any cruiser if the rider knows what he's doing.
I doubt they did that to your bike, probably an annoying coincidence. If you had parked by a bunch of scooters and this happened would you have assumed the scooter guys did this to you? May be your own pre conceived idea of the Harley guys too.... not that they can't be assholes but hey, so can sportbike riders or anyone for that matter.
The HD that are the biggest assholes are usually the poser guys that rely on the bikes for their identity. The real biker crowd usually don't seem to care one way or another. I've had some real good conversations with guys from the biker crowd about my sportbikes, their HDs, riding in general. Admittedly though, they were a lot more interested when I had my TL1000R with full M4 system, now that was a good sounding bike!
Harley-Davidson (TM): The world's most efficient device for turning gasoline into noise, without the potentially harmful side-effects of horsepower.
So the choke opened itself? Just saying, someone was messing with the bike, and if i had to hazard a guess between the blonde 20 somethings, and the grizzly bikers, i'd go with the latter. This is not a strictly HD hangout, they are mostly outside on the patio so they can sit there and stare at each others bikes with cock in hand.
I don't know about the harleys but the customs got some nut to them. Chad's snapped my neck pretty good, and with a 280 or whatever rear tire delivering that 1800CC plus power to short ration gears, with the weight to hold the traction, I know those things can move in a straight line. They can't however stop or turn. I want one.
im calling BS on both accounts this is the slip from the dyno drags at bike night.
im on the left with an 02 FZ1 and on the right is one of the guys who runs the drag races bike which was some sort of custom that had a 116CI motor which is about double my liter bike
All I was saying is that the custom has nut. You're also forgetting you were on a simulation, I'm guessing with the front and rear strapped down. A sport bike will flip and lose traction a whole lot easier than a chopper. They won't beat in a quarter or a top speed, the engines don't rev high and the bikes have no aerodynamics. Double the displacement will rip your arms out of the sockets when you wack the gas though.
ok i just wanted to clear that up. my wifes cousin (who knows bikes and has had several) holds strong to his belief that a sportster if one of the fastest 1/4 mile bikes
and yes it was strapped down. the 9.75 is a number i could NEVER do on my bike but i bet some one with a clue could
I'm not trying to bust your balls and it sux that that happened, but the way you described it made me think that, whatever happened, it may not have been what you thought.
I havent had a bike with carbs or choke for years so forgive me if botched this assessment but, even if someone put your choke on and then cranked on the throttle with the bike not running, I don't think that would flood your carbs. The choke just cuts the air flow down and twisting the throttle shouldnt dump fuel in like that if its not running, right? Maybe you have a problem with your carbs? It is an older F2, maybe needs a carb tune or rebuild? -OR- maybe someone was f#cking w/ your ride and almost dropped it or tipped it over, now that could flood your carbs and leave a gas smell. They might have put the choke on when they were picking it back up? Just guessing here, who knows...
Not for nothing, but being a "loser Harley guy" myself, I don't think that most of the guys give a crap about where you park. I ride with a LARGE Harley type group and there are some of the guys that do own rockets also. Hell, I would but my wife would cut my balls off and feed them to my pugs.
If you didn't see who did it, don't make an assumption. It could have very easily been another rocket rider.
And as far as kicking the bikes over, well, ricer, Harley, chopper...whatever. That would not be a smart thing to do on many levels.
Tom
ProVehiclePhotos.com
Manchester, NH
the percentage of asswipes in any given population is a constant....
same percentage in cagers, sportbike riders, cruiser riders, cops, doctors, teachers, conservatives, liberals, Catholics, athiests, etc etc etc....
I live my life assuming the guy next to me ISNT an asswipe until proven differently. I would have parked my bike there too and would not have expected a problem. Law of averages says you'll run into the asswipe sooner or later...it was just your turn. Don't let it change your life! I will continue to believe that the bunch of Harley riders I pass are as likely to wave back as not...so I always wave! And I don't get all worked up if they don't wave back...maybe next time they will!
Life is short...most folks feel the same way and given half a chance will respond positively to positive responses. If your world smells like shit you might want to check your mustache!!!
Muhammad Ali.
