i found a 690smr that has marchesinis on it. how sturdy are these? the bike would spend most of its life on pavement but i dont want to be scared to take it on an occasional agricultural excursion. i know laced wheels are pretty sturdy, are cast wheels really no good for "shortcuts"? the idea of a spare set of laced wheels doesnt sound cheap but neither does replacing a marchensi
thoughts?
Are they magnesium or aluminum?
Personally I would buy a second set of laced wheels to use and sell the Marchesinis or use them when you aren't running offroad.
aluminum i believe. a set of laced wheels arent cheap
i realize that they are worth more. my question is are they up to the task of the occasional off roading or if i get them erase any chance of off roading from my head?
My duke came with them, although, I don't foresee going off road much with it. The rims probably would handle more than the tires.
I did hit a hard packed road in vt on friday. Didn't go much over 20, though. Watch out for the rear brembos.![]()
LRRS/CCS #66
The marchesinis are worth more than laced wheels.
dirt roads and stuff you're totally fine but any sort of 'trail' will make you cry from the sound of rocks hitting those $$$ wheels. (had a set on my SXV)
they are just so sexy!
I had em on z YZF, loved em, tested em, jumped em... Good stuff.
I think smutty is a little gun shy, they are strong, but if you plan on doing endurocross, trade for laced.
I will note, you better have a slipper clutch on the bike if you plan on backing it in on those wheels... my rear sprocket bolts had a bad experience once. At the very least - loctite the $#!+ out of them.
The marchesini's are worth more.
is this gonna be one of the new NESR catch phrases? "the marchensis are worth more"![]()
I have a set, they're def worth more.
Zip-Tie Alley Racing
LRRS/CCS #103
im better than you, so if im worthless what does that make you?
im only worthless because i dont have marchensis
And you love nickelback.
BLASPHEMY!!! YOU SHUT YOUR WHORE MOUTH!!!
you cut me deep mike
Overall I think marchesinis are too classy for oxx, he should probably sell them, after all they are worth more
LRRS/CCS #103
