Results 1 to 24 of 24
Tie down question
    Lifer Pittenger5's Avatar
    Austin
    Tie down question
    When you're tying down 2 bikes in the back of a pickup (what kind of tie down question were you expecting you sick bastards?) how do you deal with the rotors? When I put my pit bike and race bike in the back of mine, the tie down for the pit bike basically lays on the rotor of the race bike. I dont know if this is enough pressure to over time warp it, or do any damage or anything. Its an EBC floating rotor, so that makes me a little nervous that its not fixed there and is supposed to move a bit.
    Zip Tie Alley #505
    Re: Tie down question
    not really sure i understand the question...i'm looking for a picture of how i tie down my bike & i'll post it up in a few
    never mind, i've only tied down one bike at a time, and i think i understand your question now.
    Shock you -jro-'s Avatar
    outside of Boston
    not really sure i understand the question...i'm looking for a picture of how i tie down my bitches & i'll post it up in a few
    Austin
    Zip Tie Alley #505
    ya, i've got a case of the mondays. my bad
    Lifer DuncanMoto's Avatar
    I think you need to check your method of tie down. Maybe buy some wheel chocks for your pickup bed to keep the bikes upright.
    Austin
    Well the bikes are upright, but the angle from the tie down point on the bar, and the tie down point of the truck hits the rotor of the race bike, theres no way to get around it, near as I can tell
    Zip Tie Alley #505
    Majer:Danjer™ ChicknStripEatr's Avatar
    Sep 2005
    RI/NH
    In the front of the bed, locate the middle of the floor, drill a hole through the bed and install a 3/8" eye-bolt. Use fender washers to prevent it from pulling through. This gives you 3 tie down points for the two bikes, this way the tie-downs don't have to cross through the bikes.
    Old and Slow Sheppo's Avatar
    Westford, Ma
    Quote Originally Posted by ChicknStripEatr View Post
    Or stagger the pit bike back 6" or a foot.
    Posted by Jane in BoxChat
    May 2007
    Southern NH
    Where are you attaching to the bike? Maybe Canyon Dancers would help? (Mixed feelings about this...depending on your clip-ons)
    Muhammad Ali.
    IWOK Prez. bigred875's Avatar
    Manvile, RI
    nothing should touch the rotors, they warp pretty easily
    Austin
    Well I use canyon dancers (I like them) but for a pit bike they're not that feasable, but I remember when we had regular bikes in there, the angles were just enough to hit the rotors regardless. So its not just cause its a pit bike.
    Guess I gotta start looking for a trailer.
    Zip Tie Alley #505
    Manvile, RI
    what is your pit bike? I used to lean my 50 up against the bed rail and use 1 tie down to hold it against the side of the truck....make sure the gas if off..viola
    Austin
    KLX110
    I might hafta try that, Im gonna load up a couple days early next race weekend and just play with some stuff, see what I can figure out
    Zip Tie Alley #505
    Manvile, RI
    ya dude...it's just a pit bike..i wouldnt get too fancy
    live to ride seth399's Avatar
    Feb 2007
    CA
    ya, if you have fullsize bikes you'd be set...but since its a pitbike, lean it one way toward the big bike or other way and you will be fine.
    May 2007
    Southern NH
    Ok...then how 'bout softties around the top of the triple clamps....I suspect you just need to find a different place on the bike to tie to and change the angle. But you're a pretty smart cookie so you have likely already considered that and I am probably missing the real issue...
    or maybe just lay it down on the passenger seat and if you have a passenger then use the canyon dancers to secure him/her in the bed...
    Muhammad Ali.
    Austin
    Yah, I currently tie it around the triples essentially, I think its just because of the lack of space in a truck bed with 2 bikes in it, the tie down is like 6 inches away from the rotor, and really theres no way to angle it to keep it away from the rotor.
    Zip Tie Alley #505
    Senior Member apollomx681's Avatar
    i got a trailer you can have.. it come with a bike and a rider too
    LRRS- zip-tie alley #681
    2004 zx636r- road....carbon fiber=
    2002 sv650- toecutter, track
    2002 xr100- dirty play
    Jul 2008
    Waitsfield, Vermont
    Could you go to the opposing (front/rear) tiedown instead of that one? E.g. if the problem is that the triple-tree tiedown hits the rotor, tie that to the back tiedown in the bed instead of the front one?
    Austin
    Quote Originally Posted by apollomx681 View Post
    Teach the girl how to put on and take off tire warmers, hold an umbrella and bring her sister, throw her in the deal and SOLD!
    Zip Tie Alley #505
    Austin
    Quote Originally Posted by kbroderick View Post
    Hmm, maybe. I think the bike might be in the way too much, but maybe Ill give that a shot
    Zip Tie Alley #505
    When I haul a street bike and a pit bike in my trailer, the street bike gets put on as normal in the center, and the front strapped down. I then pick the back up and swing it to one side, and strap that wheel to the side to keep it there. The pit bike then goes in backwards, rear wheel against the opposite side, front centered and strapped down. (The two bikes essentially '69' each other at an angle in the trailer. If you can't put the tail gate up in this arrangement, just make certain your strapping setup prevents the pitbike from moving forward. It doesn't weigh much, so you don't have to have it tensioned against the forks like a full size bike to keep it in place.
  1. 125 question
    By gixxer72 in forum Dirty Bastards
    Last Post: 02-27-13, 10:34 AM
