Results 1 to 25 of 25
Best mod ever
    Oct 2001
    Bedford, MA
    Best mod ever
    Screw the bling, get these:
    Click here
    Best mod ever... I can't believe how often I end up using them and how much better they make the riding...
    Easy to install... so few excuses.
    And DIRT cheap too!
    Work U HBerry's Avatar
    Nashua
    Best mod ever
    I want these! This is the one I should order: 20-10001
    DUAL STAR HEATED GRIP KIT
    $29.95
    KIT
    correct?
    Are they really easy to install?
    Will you be available for technical assitance if I cant get them to work?
    --HBerry
    LRRS# 285 - Retired
    04 ZX-6R
    88 EX500 - Broke
    Oct 2001
    Bedford, MA
    Best mod ever
    Yah there are a ton of people on the site who could help you.
    It's very easy, the only part that can get tricky is just depending on how involved you want to get in integrating the switch into your dash. If your bike doesn't have a finished/enclosed dash like a lot of race replicas, you can just zip tie/glue/velcro the switch onto the side of something and be done.
    Best mod ever
    I just bought a set of the older style set a few weeks ago. I wonder if I should buy these and sell the other set? I have the set with the resistor....
    Lifer oreo_n2's Avatar
    Mar 2002
    Amherst, NH
    Best mod ever
    i use mine all the time. got a pretty stealthy install too, i had too, not much of a fairing anywhere on the z1k to hide the switch.
    Brent LRRS #772
    2006 KTM 560 SMR
    Oct 2001
    Bedford, MA
    Best mod ever
    I don't really understand what the deal is with the resistor.. is it mounted right on the grip where it interferes with something?
    Best mod ever
    No, you have two leads coming from the battery to the switch, then one lead to the grips. On one of the leads coming from the battery there is a resistor. I dunno, doesn't seem like that much of a hassle to me.....
    Where did you mount your switch Brent?
    Mar 2002
    Amherst, NH
    Best mod ever
    right next to the speedo in this little fin of plastic.
    I put blue LED's in as hi/lo indicators too. they are damn bright, i need to lower the current to em.
    And they both turn on... i think the switch adds a resistive heating element to the path for the different heat levels, not seperate current paths. so really, just one led for on/off would have been sufficient.
    Brent LRRS #772
    2006 KTM 560 SMR
    Best mod ever
    the resistor is a large ceramc one, kinda a PIA to find a good place to mount it, I mounted mine on my headlamp bucket out of the way
    Best mod ever
    I have to agree Ben, heated grips are one of those things that once you have em, you wonder how you did without them.
    Oct 2001
    Bedford, MA
    Best mod ever
    Hmm.. I wonder if I fucked up not using the included switch. Mine are the new ones without the resistor. I didn't use the stock switch, but the one I got had very similar electrical specs, and they seem to work just fine. Maybe I'm losing a little bit of heat though. (ISTR the voltage drops came out right too)
    Best mod ever
    Ben, I just had a look at yours; very clean job installing.
    It's funny, I wonder why nobody parked where I did?
    Posting Freak SWEET_Z's Avatar
    Jul 2002
    Smallbany, NY
    Best mod ever
    Hey, did you guys have to use any glue to keep em in place?
    My grips stay stuck, until they warm up and then the throttle side grip starts sliding around. I think maybe its the soap residue in there from when I slid them on.
    Best mod ever
    that's why you use Aqua Net
    Oct 2001
    Bedford, MA
    Best mod ever
    That's cause you're not supposed to use soap.
    Mar 2002
    Amherst, NH
    Best mod ever
    yea right, a thick mix of dish soap with water works AWESOME!
    You just gotta make sure it cures (couple days) before you use it!
    Brent LRRS #772
    2006 KTM 560 SMR
    Raymond NH
    Best mod ever
    I have been using grip heaters for years. Got 'em on all three bikes. Cheap and great.
    Aqua net rocks and works great for potato cannons too.
    Jul 2002
    Smallbany, NY
    Best mod ever
    Can it be any hairspray? I will have to borrow me mums and she may have the fancy brand.
    Raymond NH
    Best mod ever
    I would think so. It just has to go on wet and dry sticky.
    Jul 2002
    Smallbany, NY
    Best mod ever
    Best mod ever
    As a member of the year-round riding club, I recommend these.
    I tried to evade their usage via 2 pairs of gloves, heatpacks, and sliding fingers back. It's doable without heated grips, but it's just not fun and relaxing.
    Nashua
    Best mod ever
    Okay Ben,
    I just got these in the mail last night, when will you be helping me install them?
    --HBerry
    LRRS# 285 - Retired
    04 ZX-6R
    88 EX500 - Broke
    Senior Member slingblade's Avatar
    central, ma
    Best mod ever
    I got mine the other day too Going to do the install shortly along with the adjustable clipons
    Nashua
    Best mod ever
    You will be helping me do so also corerect?
    --HBerry
    LRRS# 285 - Retired
    04 ZX-6R
    88 EX500 - Broke
    Best mod ever
    when i installed them on ATVs the instuctions said to use a high temp adhesive like JB Weld. I know it sound crazy but it works and isnt hard to scrape off when you remove them later in life
