Screw the bling, get these:
Click here
Best mod ever... I can't believe how often I end up using them and how much better they make the riding...
Easy to install... so few excuses.
And DIRT cheap too!
I want these! This is the one I should order: 20-10001
DUAL STAR HEATED GRIP KIT
$29.95
KIT
correct?
Are they really easy to install?
Will you be available for technical assitance if I cant get them to work?
--HBerry
LRRS# 285 - Retired
04 ZX-6R
88 EX500 - Broke
Yah there are a ton of people on the site who could help you.
It's very easy, the only part that can get tricky is just depending on how involved you want to get in integrating the switch into your dash. If your bike doesn't have a finished/enclosed dash like a lot of race replicas, you can just zip tie/glue/velcro the switch onto the side of something and be done.
I just bought a set of the older style set a few weeks ago. I wonder if I should buy these and sell the other set? I have the set with the resistor....
i use mine all the time. got a pretty stealthy install too, i had too, not much of a fairing anywhere on the z1k to hide the switch.
Brent LRRS #772
2006 KTM 560 SMR
I don't really understand what the deal is with the resistor.. is it mounted right on the grip where it interferes with something?
No, you have two leads coming from the battery to the switch, then one lead to the grips. On one of the leads coming from the battery there is a resistor. I dunno, doesn't seem like that much of a hassle to me.....
Where did you mount your switch Brent?
right next to the speedo in this little fin of plastic.
I put blue LED's in as hi/lo indicators too. they are damn bright, i need to lower the current to em.
And they both turn on... i think the switch adds a resistive heating element to the path for the different heat levels, not seperate current paths. so really, just one led for on/off would have been sufficient.
Brent LRRS #772
2006 KTM 560 SMR
the resistor is a large ceramc one, kinda a PIA to find a good place to mount it, I mounted mine on my headlamp bucket out of the wayOriginally posted by benVFR
I have to agree Ben, heated grips are one of those things that once you have em, you wonder how you did without them.
Hmm.. I wonder if I fucked up not using the included switch. Mine are the new ones without the resistor. I didn't use the stock switch, but the one I got had very similar electrical specs, and they seem to work just fine. Maybe I'm losing a little bit of heat though. (ISTR the voltage drops came out right too)
Ben, I just had a look at yours; very clean job installing.
It's funny, I wonder why nobody parked where I did?![]()
Hey, did you guys have to use any glue to keep em in place?
My grips stay stuck, until they warm up and then the throttle side grip starts sliding around. I think maybe its the soap residue in there from when I slid them on.
that's why you use Aqua NetOriginally posted by SWEET_Z
My grips stay stuck, until they warm up and then the throttle side grip starts sliding around. I think maybe its the soap residue in there from when I slid them on.![]()
That's cause you're not supposed to use soap.Originally posted by SWEET_Z
yea right, a thick mix of dish soap with water works AWESOME!
You just gotta make sure it cures (couple days) before you use it!
Brent LRRS #772
2006 KTM 560 SMR
I have been using grip heaters for years. Got 'em on all three bikes. Cheap and great.
Aqua net rocks and works great for potato cannons too.
Originally posted by stoinkythepig
Aqua net rocks and works great for potato cannons too.![]()
Can it be any hairspray? I will have to borrow me mums and she may have the fancy brand.
I would think so. It just has to go on wet and dry sticky.Originally posted by SWEET_Z
It just has to go on wet and dry sticky.![]()
As a member of the year-round riding club, I recommend these.
I tried to evade their usage via 2 pairs of gloves, heatpacks, and sliding fingers back. It's doable without heated grips, but it's just not fun and relaxing.
Okay Ben,
I just got these in the mail last night, when will you be helping me install them?
--HBerry
LRRS# 285 - Retired
04 ZX-6R
88 EX500 - Broke
I got mine the other day tooGoing to do the install shortly along with the adjustable clipons
-=Greg
2001 RC51
You will be helping me do so also corerect?Originally posted by slingblade
--HBerry
LRRS# 285 - Retired
04 ZX-6R
88 EX500 - Broke
when i installed them on ATVs the instuctions said to use a high temp adhesive like JB Weld. I know it sound crazy but it works and isnt hard to scrape off when you remove them later in lifeOriginally posted by SWEET_Z
