Results 1 to 2 of 2
MFChop #396 2005 ZX6-R Race Bike Build Thread
    Senior Member MFChop's Avatar
    Apr 2014
    Nashville, TN
    Cool MFChop #396 2005 ZX6-R Race Bike Build Thread
    Just realized I never started / posted one on here... so better late than never. Might read a bit weird because it pieced together from other thread post but Ill keep it going from here on out
    Armour Bodies Race fairings
    Bestem Carbon Fiber Fender
    K-Tech 25SSK Cartridges
    K-Tech 35DDS Pro Rear
    ZX-6RR Rear Linkage
    BMC Filter
    Hamaguchi Ti Exhaust
    Cometic .45mm Head Gasket
    Orient Express Manual Cam Chain Tensioner
    DynoJet Power Commander 3USB
    DynoJet Ignition Module
    DynoJet Quick Shifter
    STM Slipper Clutch
    Factory Pro Shift Star
    Shorai Battery
    Ivans Servo Eliminator
    Ivans Pair Block off plates
    Samco Coolant Hoses
    AFAM -1 +2 Sprockets
    Brembo RCS19 M/C
    Nissin Calipers
    Spiegler Lines Front and Rear
    CL C60 Pads Front RX3 Rear
    D.I.D 520 EVR3 chain
    1/4 Turn Throttle
    Woodcraft Rear sets
    Woodcraft Frame sliders
    Woodcraft Stator Cover
    Woodcraft Crank Case Cover
    Woodcraft Clip ons
    Woodcraft Toe Guard
    Woodcraft Ignition Key Switch Eliminator
    434 Racing Levers
    434 Racing Ti Race Bolts
    Scotts Ohlins Steering damper
    NGK CR9E Plugs
    Pirelli Diablo Supercorsa 120/170 SC2 f - 180/60 SC1 r
    I ll add some more pics shortly
    Special thank you to my 2015 Sponsors for all their help this season!!
    At Dyno Solutions of Brookfield CT
    [/QUOTE]
    KTech Suspension curtesy of Advanced Traction
    Finally got some free time back in CT this weekend to install my Factory Pro Shift Star even took some pics....
    Install was pretty straight forward, although I had to re do it all because the star wasn't fully indexed. The offset nipple on the shaft was a PITA to align with the stiffer detent spring installed
    Stock on left
    FAP FAP FAP
    Shifts are definitely firmer and more positively engaged, defiantly worth it
    During second practice; entering T3 I took a downshift and heard some chatter from the transmission as the gear wouldn't engage. I tried to up shift still nothing, so a bailed into the T3-T10 split ending my practice. I had had this issue once last season enter in the bowl, thought it was user error. It occurred once round 1 then again round 3 and now, always on downshifts. I had installed a shift star prior to this round hoping it would rectify the issue, but apparently not......................
    So I rip into it; as he stood by talking with some other riders while. Within an hour of work I was able to strip it down and pull the shift forks out to find this...
    Left to right 5/6 - 3/1 - 2/4
    You can clearly see each one of the ears are worn especially on the 1/2nd's each one's thickness was only ~.05 above factory tolerable specs to be replaced. Also you can tell from the radius shaped wear at the bottom of the 3/1 and slightly on the 2/4 that they are bent as well. The shift drum has no signs of wear and is well within spec. I still need to verify that the gear groves are within spec and the dogs /slots appear okay later today, knock on wood they are. Hopefully it’s just the shift forks themselves, which are already on order ($160).
    Well add one more thing to the list, shift drum assembly
    Yesterday evening after work I put the bike back on its side in an attempt to inspect the Dogs / slots. While doing to I noticed some lateral movement from the 3rd and 4th. I decide enough was enough, packed up my trailer and went back to CT for the night (no garage here )
    1.5hr after I get home...
    And the cases are split!
    Cardboard is our friend
    Pics of the gears / slots. You can see the wear, and the slight rounding on the edged of the dogs
    4th
    3rd
    1st has very light wear and second is just like 3rd and 4th
    Got the new gears / dogs in.... Good vs Bad
    Right now Im in the hole ~$600. Hopefully when I get home Friday night I can put the bottom end back together and get the valve lashing done in the AM so I'll have time to swap out shims with a dealer. Then Sunday have it back in and running, fingers crossed.
    Im still in the hunt for a thinner head gasket, there used to be OEM KIT ones however with a 10yr old bike those parts are now basicly non existant. Cometic only has a .45 which is -.40. I think that might be way to thin i.e. valve clearance issues and to high of a compression. So I might be beat with doing that
    Edit: with little time left and coming up short on my searches, I ordered a Comitec .45 gasket
    So last night I got in to Wolcott and spliced in the newer MOSFET 07-08 and I runs extremely cooler. Wish I had a temp gun to see but the OE one ran wicked hot after 2 min of idle, hot enough where you would tap it and say okay I wont touch that again. The new one runs extremely cool, after a 45 min session on the dyno it was luke warm.
    So John put her up on the dyno did a couple pulls today.
    Heres the history so far......
    Heres from 3-4 yrs ago when I went from some pre-made map to a custom tune by the dyno guru...
    From 110hp to 115hp with a very nice smoothening of the power curve....
    A year later I went in for a scheduled Drs check up... also at this point an Ignition model was installed however left at 0
    She put down 109hp after some re tuning of the map it was up to 111hp. Now mind you this is now on a larger / heavier 180/60 race tire, which caused the loss of power...
    Now almost exactly a year later back for a visit again. The replacing of the rectifier removed the entire bucking issue I had during the last round of racing so that was a relief to see. Since its last visit I re built the transmission and added a thinner head gasket (-.40mm). I presumed the A/F wouldn't be affected much but still good to make sure its in peak condition.
    So heres is where we are at today 113.21hp!!
    Just rolling on to the dyno with zero timing it made 108hp after some tooling of the A/F and adding in 4° of timing it put down 113hp, so ~1.55 gain. I don't have a comparing to the 108hp run but there was a nice mid range gain of +2-4hp in the 4-8k range too, although Im not there too often during races.
    Given its a 10yr old bike I'm still plenty please with the power it putting down and as you can see the power curve is perfect.
    During last round I ran a compression test and all the cylinders were fine but on the lower end of the tolerable allowance (165psi, min 155psi). Im sure I'm loosing some power there, but hey I have almost 30k on the odometer. Over the winter Im most likely to re-hone the cylinder jugs and new piston rings possibly new pistons too, cost prohibiting
    But I cant say enough about John and how well he does his job and the effort he puts in to it.
    If you're in the NE area I highly recommend him, his link is in my signature below
    Lifer jwm2k3's Avatar
    Mar 2004
    Lynn, MA
    Re: MFChop #396 2005 ZX6-R Race Bike Build Thread
    This is one of the best maintained race bikes I've ever seen. I'd be happy to own this bike after you....you spare no expense.
  1. For Sale - Motorcycles | 2005 CBR 600RR Race Bike
    By Steve724 in forum For Sale
    Last Post: 06-03-19, 10:45 PM
  2. For Sale - Motorcycles | 2005 Suzuki GSX-R 600 - Track Bike or Race Bike (missing title)
    By Mchristiansen in forum For Sale
    Last Post: 07-20-18, 05:23 PM
  3. MFChop CCS #396 - 2015 ZX6R Race Bike Build
    By MFChop in forum Pit Area
    Last Post: 05-01-17, 06:30 PM
  4. For Sale - Motorcycles | 2005 ZX6-R Race Bike
    By MFChop in forum For Sale
    Last Post: 12-28-15, 10:29 AM
  5. MFChop #396 LRRS Round 4 Race Report
    By MFChop in forum Race Reports
    Last Post: 07-30-14, 10:47 AM
