Results 1 to 23 of 23
motorcycle table lift.
    LRRS EX #99 Kitt's Avatar
    Lake Champlain, VT
    Looking to pick up the table-style motorcycle lift... I see them range from $500 to $3000... anybody have experience with lower costs lifts that work and stabilize the bike well?
    I see People in the Pit Garages use what looks like a Small Table, The use with a track Stand
    DC
    Zip Tie Alley Racing #444
    Signature edit by Tricky mike
    I have an EazyRizer
    nothing is more stable, has some advantages over a table, easier access, and disadvantages, no table to rest your tools on.
    best price on one is here
    I got turned on to the EazyRizer by a friend that works at Rokon, they use the EazyRizer as a manufacturing platform
    IWOK Prez. bigred875's Avatar
    Manvile, RI
    I have an EazyRizer
    how would that work on a bike with an after market Ti exh?
    Manvile, RI
    Incidentally, most after-market thin-wall stainless steel and titanium systems are actually stronger than their chromium plated, mild steel counterparts.
    do you have any experience with a Ti exh?
    Lifer Currently's Avatar
    Ooltewah, TN
    I got one thru RandyO and will repeat what he said.
    I bought the Ducati attachments from Bike Lift| Bike Lifts from On-Bike.com
    This has a mount that rests on the front cylinder under the exhaust and
    the other mount holds onto the rearsets.
    You cannot knock it over and with the variety of mounts I now have, you can work on 4 wheelers, just about every kind of bike out there.
    If you get it from Rokon, you will get one of the original packages that already
    have over a half dozen mounts. All you need to order is the footpeg mounts and the CM-VT Ducati front cylinder mount for SV's and Duc's.
    If you get it from Driven Gear or Bike Lift, all you get is one set of mounts and at 85 bucks a set ... that adds up real fast.
    It is an incredible feat of engineering ... impossible to tip over and even
    more access than a table.
    If you are close to Nashua, I can show you mine and how it works.
    recluse Dangerz0ne's Avatar
    North Providence
    harbor frieght has one for like 279. not sure how stable it is, but it looked pretty solid when I saw it once in person.
    Lake Champlain, VT
    so far none with the "table"
    I could just get a buddy to weld up an aluminum platform, but I think the lift feature would be nice... I work on bikes a lot, and need it to save my back when working.
    I love my table, but it's a very simple one. Aluminum top with frame... and 6 legs that screw into it. (unscrew the legs and the table stores flat)
    I use a plank to get bike up and down.
    Tony
    Trackdays in CT, NY, and NH
    www.TonysTrackDays.com
    Lake Champlain, VT
    Quote Originally Posted by 35racer View Post
    u make it up yourself?
    Lifer Wishbone's Avatar
    Jul 2006
    you could always get a few guys and...im sorry i couldn't resist
    Full Tilt - Full Time Trackday Guru's Avatar
    Dec 2006
    Concord, NH
    I think this is what you seek Kitt...
    Motorcycle Lifts Hydraulic Motorcycle Lift Table Motorcycle Lift Jacks - DerekWeaver.com
    And if you need just a good, solid table stand, try this-
    POWERSTANDS: Browsing PowerPlatform - Portable Motorcycle Work / Display Table
    Mike
    Am #124
    I designed and had my first one built. Gave that to a friend.
    The one I have now was made by someone else... but he doesn't make them anymore.
    You can stop by and see it... and probably have one built... or build it yourself if you can weld?
    Tony
    The one posted above is very similar to the one I had built.
    I'm not sure which one I like better. The one I use now has removable legs, so they could get lost.
    But since they screw into the platform, you can also adjust for small fluctuations in the ground.
    For that price above, though... I'd probably just buy one of those.
    Tony
    powerstands makes a table. in fact if you are an AM you can get contingency from them and use it toward a purchase. I think kates has one
    Just Registered
    Is it not obvious?
    I'm confused how powerstands came up with that table, Pitbull never had a table did they?
    www.gpsdiscussion.com
    motorcycleaddicts.org
    Lifer LuvDog's Avatar
    Ashland, MA
    Quote Originally Posted by somestrangeguy View Post
    LOL
    2003 ZX7R
    1995 916
    what do you mean? alot of the 2 stroke guys have tables because the bikes are so small you cant really get comfortable next to them
    Quote Originally Posted by bigred875 View Post
    the nie thing about an eazyrizer is that you have several oprions on lifting the bike depending on what work your doing,
    if your not taking wheels off, lifting with the wheel hoops is simple
    you can use a front hoop and footpeg mounts
    or the rear hoop and the sport v-twin front mount
    or the standard beam mounts, you can secure it with the sidestand, or with the footpeg mounts
    OR you can easily fabricate your own specialty mounts
    first time you use it, you have to fuss with it learning how to adjust the mounts to your particular bike, but after that, it's tit
    it's so much more versitile than a table
    I use a cordless electric drill to do the actual lifting
    ...tit...
    It never got fast enough rebelpacket's Avatar
    Jul 2003
    Bozeman, MT
    Manvile, RI
    Quote Originally Posted by rebelpacket View Post
    and you can go see it in warwick, ri
  1. Wanted - Parts & Tools | Motorcycle Lift Table
    By Nortoncafe in forum Wanted
    Last Post: 04-02-20, 08:05 AM
  2. Table Lift
    By gamorg02 in forum For Sale
    Last Post: 12-05-12, 09:11 AM
  3. WTB: Motorcycle table lift
    By xxaarraa in forum Wanted
    Last Post: 11-07-12, 03:59 PM
  4. WTB table lift
    By gamorg02 in forum Wanted
    Last Post: 10-16-12, 01:19 PM
  5. Looking for a Motorcycle table lift.
    By Doc in forum Wanted
    Last Post: 09-02-12, 07:22 PM
