I see People in the Pit Garages use what looks like a Small Table, The use with a track Stand
DC
Zip Tie Alley Racing #444
Signature edit by Tricky mike
I got one thru RandyO and will repeat what he said.
I bought the Ducati attachments from Bike Lift| Bike Lifts from On-Bike.com
This has a mount that rests on the front cylinder under the exhaust and
the other mount holds onto the rearsets.
You cannot knock it over and with the variety of mounts I now have, you can work on 4 wheelers, just about every kind of bike out there.
If you get it from Rokon, you will get one of the original packages that already
have over a half dozen mounts. All you need to order is the footpeg mounts and the CM-VT Ducati front cylinder mount for SV's and Duc's.
If you get it from Driven Gear or Bike Lift, all you get is one set of mounts and at 85 bucks a set ... that adds up real fast.
It is an incredible feat of engineering ... impossible to tip over and even
more access than a table.
If you are close to Nashua, I can show you mine and how it works.
harbor frieght has one for like 279. not sure how stable it is, but it looked pretty solid when I saw it once in person.
I love my table, but it's a very simple one. Aluminum top with frame... and 6 legs that screw into it. (unscrew the legs and the table stores flat)
I use a plank to get bike up and down.
you could always get a few guys and...im sorry i couldn't resist![]()
I think this is what you seek Kitt...
Motorcycle Lifts Hydraulic Motorcycle Lift Table Motorcycle Lift Jacks - DerekWeaver.com
And if you need just a good, solid table stand, try this-
POWERSTANDS: Browsing PowerPlatform - Portable Motorcycle Work / Display Table
Mike
Am #124
The one posted above is very similar to the one I had built.
I'm not sure which one I like better. The one I use now has removable legs, so they could get lost.
But since they screw into the platform, you can also adjust for small fluctuations in the ground.
For that price above, though... I'd probably just buy one of those.
powerstands makes a table. in fact if you are an AM you can get contingency from them and use it toward a purchase. I think kates has one
I'm confused how powerstands came up with that table, Pitbull never had a table did they?
what do you mean? alot of the 2 stroke guys have tables because the bikes are so small you cant really get comfortable next to them
the nie thing about an eazyrizer is that you have several oprions on lifting the bike depending on what work your doing,
if your not taking wheels off, lifting with the wheel hoops is simple
you can use a front hoop and footpeg mounts
or the rear hoop and the sport v-twin front mount
or the standard beam mounts, you can secure it with the sidestand, or with the footpeg mounts
OR you can easily fabricate your own specialty mounts
first time you use it, you have to fuss with it learning how to adjust the mounts to your particular bike, but after that, it's tit
it's so much more versitile than a table
I use a cordless electric drill to do the actual lifting
Harbor Freight Tools - Quality Tools at the Lowest Prices
379$.
Or, for 479, you get the air-actuated lift.
