Page 2 of 2 FirstFirst 12
Results 26 to 36 of 36
How to move spare wheels safely?
    xxaarraa
    Guest
    Re: How to move spare wheels safely?
    if you do the chocks, remember there a few different kinds:
    1.) permanent:
    2.) removable:
    3.) 3.5" for small street bikes, or dirt bikes:
    4.) 6-1/2" for bigger street bikes and cruisers:
    since you have a collapsing trailer, I recommend the 6-1/2" removable chocks. When I'm moving someone around, it's nice to be able to pull the chocks out in pinch, so I'd imagine the same convenience is applicable to help you with your storage situation
    Thanks Breakdirt. I do have a couple of the removable pingel chocks laying around. But I think the locking chocks may be more secure and these will be mounted all the way on the front of the trailer where I had new diamond plate put on, so they should not hinder any folding which happens at the rear. I will be doing this this weekend, so stay tuned for pics!
    xxaarraa
    Guest
    ok. i see now.
    i could see something like this working pretty well. obviously not 2 high but basically a rod through the hub where the axle goes, and washer over the end with a hitch pin. you could weld or bolt it onto the tongue or just in front of the bike.
    Attachment 39832
    That's a really cool idea, I think PitBull makes a tire tree. But I wonder how much weight they add. I love the Kendon because I am a little guy but can still stand the trailer up and move it around by myself quite easily, and don't want to add too much weight.
    xxaarraa
    Guest
    OK guys, here's an update. More of a teaser, since I haven't finished it yet. My skilled neighbor friend (everyone should have a neighbor with a rivet gun) played a lead role. I have to sand it all down, spray some black enamel and bolt it to my roof rack.
    Its an adaptation of breakdirt's idea, modified in two key ways:
    a. I went with locking chocks for stability that the pingels won't offer, and had to modify one of them to fit the bigger/fatter rear wheel and tire.
    b. I also decided to mount it on the roof of my truck instead of the trailer floor (that way, hopefully i never have to take the rains down and they stay out of the way all weekend without taking up usable real estate at ground level). I'll run some bicycle cable locks through the wheels and the roof rack to prevent spontaneous theft. I plan on securing the wheels to the chocks with buckled rubber dive-knife straps.
    The mock up shot on the truck makes it look so ridiculous that its going to be so awesome!! "Sir, why do you have those giant wheels on the top of your truck? Oh.. those are for in case I flip over!"
    How to move spare wheels safely?-uploadfromtaptalk1408622028442-jpg
    How to move spare wheels safely?-uploadfromtaptalk1408622037710-jpg
    How to move spare wheels safely?-uploadfromtaptalk1408622045061-jpg
    How to move spare wheels safely?-uploadfromtaptalk1408622060061-jpg
    Dearest gawd, I offer this display of rain tires as an offering for no fookin' rain on my track day. Thank you.
    Nov 2009
    Bristol County
    Very sweet setup. But something to consider for those who've never had stuff on their roof on the highway: It can create a lot of wind noise. For those couple hour trips to the track, that might get old. I suppose just like a motorcycle and helmet noise, the car's airflow pattern will determine if the noise is significant or not.
    nedirtriders.com
    xxaarraa
    Guest
    Yes, good point. My truck is as un-aerodynamic as possible as it is (it is lifted, and is very boxy). I will see how bad the noise is next weekend. Plan is to secure this to the roof rack with wing nuts to facilitate easy removal, so worst case, I only put it on during the summer.
    guess what I think of it?
    friggen awesome
    I'd imagine moving the entire contraption with tires is a bit heavy as a solo man mission - you can pop out the wheels comfortably while the whole thing is on the roof?
    Dr Q : Last resort Medic Qfactor's Avatar
    Homeless, MA
    have you considered exposure to sun / heat on the tires?
    just my .02
    Q
    Nov 2009
    Bristol County
    If it does make too much noise, you might be able to wrap a motorcycle cover around the whole assembly, or build some sort of wind deflector up front. But here's to hoping you don't even notice it.
    nedirtriders.com
    xxaarraa
    Guest
    friggen awesome
    We thought of this. That's why both wheels are on the same side of the truck - don't have to unload one, then walk over, climb and unload the other. They slide right out of each chock, pretty easy. The rubber buckle dive knife straps are easy to do/undo. They will be riveted on to the chocks at the appropriate tie-down points, so they will always be handy. Rear wheel & tire is super light, front is slightly heavier with those rotors. But even a tiny guy like me can do it pretty quickly while standing on the truck's rock sliders.
    Quote Originally Posted by Qfactor View Post
    just my .02
    Q
    That shouldn't be a significant factor. Even 100 degree weather shouldn't be hot enough to really cause any heat cycles on the tires. As for the wheels themselves, they are meant to be ridden in the open, with a whole bike bolted on to them. Storing them on top of a car is the least of the wear they are made for. The wheels/tires will only be on there on track-day weekends, otherwise stored inside my house (an exposure of maybe 10 weekends a year?).
    I like how you think Keep adding more things to this contraption till it turns into an entirely unrecognizable project! You should have seen us go to town with the rivet gun!
    Newbie South of Heaven's Avatar
    Jun 2014
    Jamaica Plain
    Ashwin, when you go for something you give it 110% ! That's for sure!
  1. For Sale - Motorcycles | Hawk race bike, stands, warmers, spare wheels/rains, $2k
    By Mustang in forum For Sale
    Last Post: 02-17-14, 08:59 AM
  2. thank goodness for spare wheels
    By Pestilence in forum General Bike Related
    Last Post: 06-28-10, 07:49 AM
  3. Spare set of wheels, ZRX1200
    By TheIglu in forum Wanted
    Last Post: 02-20-10, 09:09 AM
  4. Spare wheels or pit bike?
    By GixerJockey in forum Pit Area
    Last Post: 12-24-08, 12:32 AM
  5. can you safely jump start
    By 01YZF6 in forum General Bike Related
    Last Post: 04-17-06, 06:49 PM
