Results 1 to 5 of 5
TLR wont prime
    Addict jbmass's Avatar
    Nov 2010
    Warwick, RI
    TLR wont prime
    I pull of my sub-frame today on my TLR to install my Penske, and when I re-installed everything (double and triple checked all connections) the bike won't prime. Key turns on lights etc, bike cranks over, but nothing else. The tip over switch is reading open through my meter, and I'm not getting voltage to fuel pump relay across coil. Could my problem be somewhere in the start circuit? I do have the wiring diagram, but can't seem to pinpoint my gremlin. I can work the relay, so I know the relay works, and I don't think they are polarity biased. Is there an interlock I should inspect? I should be reading ground through the PCU on part of the fuel pump relay, but it isn't. If I manually ground the relay I can get it to prime, but I think the PCU doesn't know this so it isn't allowing spark.
    Anyone have this problem before?
    The tip over switch is fine, it's showing code C-41, fuel pump relay system code.
    Alright, I can get it to start if I jump the relay from the yellow/blue coming out of the ECU that's supposed to read ground. All my black/whites are reading through the harness so I know they are all working, but the ECU isn't supplying ground on the yellow/blue to turn on the fuel pump relay.
    Is it ok to supply my own ground to the relay since the ECU isn't communicating with it? The only think that I notice that's different is it doesn't turn off the pump after 5 seconds after I initially turn the key to ON postion.
    Nov 2010
    Warwick, RI
    Re: TLR wont prime
    The fault code clears when I jump the relay as well
    Re: TLR wont prime
    I'm gonna go with the obvious here and tell you to make sure the fuel relay PLUGS are FIRMLY pushed into one another, then make sure they're secured to that little cross section under the seat (use wire ties). I won't even get into the hell that tiny little overlooked plug put me through...
    Nov 2010
    Warwick, RI
    Re: TLR wont prime
    I even went as far as taking those apart and soldering them, replacing the krimp connectors. I also read continuity from the relay back through the ECU output, and no problem there as well as relay output to interlocks/pump.
    With the relay closed I'm reading 0.07 ohms through the coil, but relay ground yellow/blue (ECU output) to black/white (input to ECU at the harness) I'm reading 80 ohms, which might make sense since it's normally not reading ground until the ECU tells the relay to turn on the pump, at which point the ECU supplies ground through yellow/blue.
    Super Moderator beet's Avatar
    May 2002
    Meriden CT
    Re: TLR wont prime
    Check everything again, it could be intermit under load thing. But check your connections carefully , makesure your wires are not only in there conections are nice and tight replace
    for fix as needed.
    www.bostonmoto.com
    Forum Rules
  1. MotoGP Unlimited now available on Amazon Prime
    By number9 in forum General Bike Related
    Last Post: 03-16-22, 08:12 AM
  2. CBR 600 F4i - No Fuel Pump Prime
    By kb1 in forum Bike Maintenance
    Last Post: 03-29-12, 02:52 PM
  3. f4i wont start
    Last Post: 07-05-07, 03:24 PM
