Page 3 of 3 FirstFirst 123
Results 51 to 75 of 75
Do you do your own service?
  1. #51
    Jul 2005
    Bennington, NH
    Re: Do you do your own service?
    I do most of my own wrenching on all my vehicles. By the time I get a ride to the repair shop and drop it off then go pick it up, I can have the work done. I was talking to a guy about that the other day when he mentioned repair shops having lower labor prices when compared to cars. I told him it was probably due to people being able to do their own work as bikes are easy. If the rates were really high, no one would take them in. Well, except BMW guys...
    The repair shop in my town is less than a quarter mile from my house. If the labor rates were lower, I doubt either of us would do any work on either of our cars. We used to live next door to a Subaru mechanic (Clayton actually went there this winter). His rates were low enough that Rob had him do a lot for us, mostly to save time.
  2. #52
    some of us don't use bikes as toys but use them as DDS instead
    And some of us work on our own bikes that are DDS's. The key, Randy, is to 1, enjoy working on them, and 2, have 3 spare bikes ready to ride if you break the first
    Yeah, still haven't heard from him. And the Subaru is still using coolant.
    satz
    Guest
    I do all my service ,except for tires. I drop the rims and get the new tires.
    Jul 2005
    Bennington, NH
    hmm, didn't know you were trying to get in touch. i'll prod him a bit via the faceyspaces.
  5. #55
    Dublin, NH
    I bring my vehicles to the shop to extract the remainder of the bolts that I sheared off in the frame. That's the only thing I'm not very good at.
    2023 KTM 890 Adventure R
  6. #56
    Key 1 is my biggest issue!
    KB KB's Avatar
    Manchester NH
    I work on my own stuff and I do all my own stunts.
    LRRS/CCS EX #13
    GMD COMPUTRACK
  8. #58
    who knows
    I do the same as Trouble, suspension and big motor work I would send out but would have no issue with dropping the engine out of the bike to get it to the shop. I find that part to be surprisingly easy.
    As for vavle adjustments I stripped my bike down to the engine but I paid Degsy to do the actual valve adjustment as I wanted it done right. I think I could do the next one by myself if I wanted to but I will most likely hire him again to do the actual measurements and re-buttoning up the engine. I think putting the cam shafts back in and getting them correct on the chain was the most difficult part of the whole process.
    Quote Originally Posted by Trouble View Post
    I send out the suspension and big motor work. Checking the valves are as far as I go into the motor. I do pretty much everything else. The motor's out of the race bike now so I thought I'd take the time to do a thorough cleaning and tidy up the wiring.
    Raymond NH
    You can make that go much easier with a sharpie. I never bother with the factory marks, I just mark the chain, cams and crank as I find them, remove the cams for shim swaps, and put it all back the same way I found it.
    Oct 2004
    Southeastern Taxachusetts
    yes, because I am a cheap son'ofabitch
    MSF RiderCoach
    MSF Dirt Bike School Coach
    she rides like the wind
    & smells good too.
  11. #61
    Westford, MA
    While I am not good at many things, I am half-decent at turning a wrench sometimes.
    That and I ride an Bandit for chrissakes. It's not like a Ducati where ya have to worry about shorting out the Continuum Transfuntionor.
    ...I have your pants!!!
  12. #62
    Looks tidy. LOL
    Man, I am jealous of that workshop...
    Old and Slow Sheppo's Avatar
    Westford, Ma
    wish mine had more light, brighter walls and it was cleaner...
    Posted by Jane in BoxChat
  15. #65
    Lifer Trouble's Avatar
    Monkton, VT
    Looks tidy. LOL
    It got worse before it got better...
    You're welcome to use it any time you want. Too bad you don't live closer. I enjoy sharing it with others.
    LRRS EX #7
    Low Down Racing
  16. #66
    who knows
    I know Deg's was mentioning something about white out and forgetting to use it. I assume this was for marking them.
    Wirelessly posted
    I mark the cam sprockets with white out so i know i have the correct number of links between cam sprockets.
    It is important to have the cams lines up in the correct spot when you take them out and reinstall them because if you just mark everything and dont worry about where the crank is in its cycle, the cam lobes and springs can cause the cam towers to crack or bend when you loosen them off.
    Raymond NH
    Wirelessly posted
    As long as the chain has not moved on the crank, and the the crank has not moved enough to make the chain markings at the cams move out of sight, the crank position becomes irrelevant. You just need to make sure the cam teeth align with the same teeth on the chain as before. On some bikes, this means marking both cam sprockets, the crank sprocket, and the chain in three places. On my bike, the cam chain cannot slip on the crank sprocket without splitting the engine cases, even if the chain is completely loose, so I only need to mark the chain in two places, and both cams.
    I think he's saying to rotate the engine such that all of the valves are closed (TDC). This way there is little or no pressure on the cams.
    I think..
    Wirelessly posted
    Wirelessly posted
    Youre absolutely correct and that is a perfectly good way to do it. I didnt mean to say that isnt right. Sorry for miscommuniation.
    What i meant was that the manuals give you a loosening/tightening order for the cam tower bolts. That is based usually on a particular cylinder being at TDC on a compression stroke. This is because of where the cam lobes end up. Some will be compressing the valve springs and if you loosen those bolts first, the cam tower will have lateral force applied to it from the valve spring and that risks a cam tower crack. Does that make sense? Did i explain it right?
    Raymond NH
    Wirelessly posted
    I get it now, yeah that makes perfect sense. I am very careful about cam bolts and only use the torque sequence provided by the service manual after the bolts are all snugged down. What I do is a learned skill and perhaps best left to people that have done this sort of stuff over and over.
    Raymond NH
    I think..
    That's not possible on an IL4 with a flat crank. Might be an option on a cross plane R1, not sure.
    Wirelessly posted
    I think..
    Yep. Not possible on an I4. You have to use the factory marks combined with the loosening order UNLESS you know what youre doing and have done it a bunch. Then you can do it the stoinky way and it works perfectly.
    Hmm.. I guess that makes sense. I never touched the cams in the one I4 I had; it had old fashioned screw and lock nut adjusters.
    Rindge NH
    Try to do most work myself, I take a pass on carb and heavy engine work. Although today I did send the ZZR out for a chain change,( I did the sprockets) since I didn't have a chain rivet tool and for the $44 they charged me to do it was worth it.
  1. Hi again...14k service etc
    By getaddicted in forum General Bike Related
    Last Post: 09-21-08, 07:33 PM
  2. Lapinski Service Dyno Service Warrick RI
    By LapinskiService in forum General Bike Related
    Last Post: 03-06-06, 04:48 PM
  3. Service
    By DaSarge in forum General Bike Related
    Last Post: 02-11-05, 02:02 PM
