Results 1 to 19 of 19
Peg feelers - take 'em off or what?
    Lifer Currently's Avatar
    Ooltewah, TN
    When I was at the Gap last week, several people told me to remove my peg
    feelers on my SV.
    What is the general consensus here?
    Remove them totally?
    Replace them with short bolts to provide some wear resistance to the peg?
    Take them off completely and never look back.
    I did grind them quite a bit over there even though I was hanging off
    especially in the decreasing radius curves.
    And by the way ... who is the effing asshole that straightened all those local curves around here when I was gone!
    I Dance With Will
    Oct 2002
    unknown
    Quote Originally Posted by Currently View Post
    it was the fuckin cops.
    i suppose you should remove them if you keep dragging it because then you can drag the plastics next.
    "fuckit!"
    LRRS EX #99 Kitt's Avatar
    Lake Champlain, VT
    take em off.
    replace them with sparkey feelers
    May 2007
    Southern NH
    Do your rearsets fold up? If they do, I might leave em on...they provide feedback without introducing any risk. If they don't I'd take em off
    ... if you keep dragging it because then you can drag the plastics next.
    Muhammad Ali.
    Ense petit placidam sandman's Avatar
    sema
    them off and never look back.
    jim
    "Molon labe"
    Install those spring-loaded curb feelers like the old-schoolers had on their boat-sized Caddys.
    Ooltewah, TN
    They are the stock ones that fold up ... that was the point I was trying to make.
    They told me if I hit a groove in the pavement dragging those feelers, it would upset the chassis and suspension enough to lowside the bike.
    As for sparky feelers .. they already make lots of sparks when they touch .. my right one is almost 3/4 ground off while the left one is about
    a third ground off.
    sema
    a third ground off.
    lose them asap!
    jim
    "Molon labe"
    Lifer akira700's Avatar
    Apr 2005
    in the city
    they serve no purpose at all...other than to irritate you
    as you touch.
    I find with them off
    its a little less jarring to drag the folding peg itself...
    best would be to get higher after market ones
    that dont drag at all
    Jan 2007
    Rochester MA
    Take them off.....
    I'd rather drag a little feeler than a big peg.
    Unless they're 1-2 inches long I'd leave em on.
    My theory is, if you're dragging pegs & you aren't dragging a knee, your form & technique has room for improvment. I used to drag em on my ZX... then I started learning how I could improve my technique & form.... I worked on it at the track & now I'm going much faster than before, leaning MORE than before and am no longer dragging my pegs.
    Take em off now & you'll only be temporarily hiding the signs that you need to make adjustments to your technique.
    sema
    i agree, but i'd rather have nothing there to drag on the ground.
    then when you run into that corner that tightens up a little more than you expected or have to tighten your line to go around a rock theres nothing there to touch the ground and fuck you up.
    jim
    "Molon labe"
    You're absolutely right, I'd rather have nothing drag either..... but take the feelers off & you'll start leaning further & further until now you're dragging peg.... you're also going faster than you were before on the same roads, you're closer to the limits of the tire & you're closer to experiencing an "unscheduled dismount".
    By taking the feelers off, the only thing you're doing is removing a warning sign that you need to change something about your technique. The proper fix for this is learning how to ride better. I suppose the BEST solution is to do BOTH.
    Like Peter Kates says... "If you can't afford to do it right, how can you afford to do it over?"
    This follows the same principle... if you can't afford to learn the proper technique, how can you afford to fix your bike & your body?
    .... duey's Avatar
    Wilmington MA
    SV's have the stock curb feelers extremely low IMO. Even with my monkey ass hanging off the pegs (not feelers) scraped. Only time i scraped the feelers on the street was on Kurts "Goat Trail" (i think thats what its called).
    First and only time i scraped the feelers was coming out of 12, and since it seems like plenty of people drag hard parts coming on to the straight they left alot of nice little grooves in the pavement (or it could just be my imagination), when i scraped there i had to pit next lap and check my pants because it gave me a nice little wiggle coming on the straight.
    2021 Ducati Panigale V2
    2020 Honda Grom
    strange, I always dragged my exaust pipe first on righthanders, and sidestand on lefthanders
    even bar end mirrors, before the pege feelers
    Ooltewah, TN
    I got a second gen, Randy
    I Dance With Will
    Oct 2002
    unknown
    haha! nice!
    "fuckit!"
    actually I don't think it's a 1st/2nd gen thing, I think it's my fat ass settling the suspension
