Page 9 of 10 FirstFirst 12345678910 LastLast
Results 201 to 225 of 227
Picking up a KTM RC8R
  1. #201
    Lifer Gixxer's Avatar
    Re: Picking up a KTM RC8R
    Picking up a KTM RC8R-img_7965-jpg
    Your park avenue leads to..
  2. #202
    TWINS! xrocket21's Avatar
    Central Maine
    Fuuuuuuuck, concept 2021 RC8R with a 1,300cc and single rear swing arm!!!!
    Yes.
  4. #204
    Central Maine
    Yes.
    I love everything about it. They fixed the ugly front end and headlight, the single swingarm, but it all still holds the rc8R character....
    Central Maine
    Got the -1 front sprocket installed and went for a ride. I like it a lot better. I think I may end up going +2 in the rear at some point.
    I did however botch something with the clutch along the way. I bolted the slave back on without a bracket, noticed, the fixed it. When I went to ride I had ZERO clutch. I fucked with it for an hour, bled the slave and found no bubbles, un installed it and re installed it 7 times, and I have a little clutch now, enough to ride. But with the lever adjusted all the way out it barely disengages the clutch and it grabs immediately with no modulation. Ill try bleeding the master next but it was VERY frustrating. I feel like every time I try to ride this bike I have a problem.
    The previous owner put this cheap solid sunstar rear sprocket on, stock 38T, Id get a 40T.
    Also, the clutch reservoir says mineral oil only? Isnt it usually just brake fluid? Ill need to find some of that.
    edit, cracked the master bleeder and that immediately fixed it Glad I fucked with it for over an hour and it was a 10 second fix. Never would have thought I got air in it, I never opened the system. Oh well, either way, glad it is fixed. Did the front brake too and that stiffened it right up!!! Thing is dialed now. I did learn that I don't have an 11mm wrench though?
  6. #206
    Isn’t there supposed to be a spring washer and nut holding that sprocket on?
    And I’m almost certain the clutch fluid for the KTM I had was Dot 5 or 6, which is quite a bit different than Dot 4 brake fluid
    The Magura clutches use mineral oil.
    Central Maine
    Wtf?
    I ordered some, but Ive never seen that before
    Feb 2008
    Rhody
    That sounds so bizarre to me?
    Hyper
  10. #210
    The austrians do lots of bizarre things
    Sent from my SM-S901U using Tapatalk
    Central Maine
    I agree! Definitely not something i stock on the shelves
    I DO like that they use the same size torx for nearly everything!
    Hypertarded
    RI / CT border
    Yeah, goes WAY back, I had a few sets of Magura Hydraulic rim brakes on my Mtn Bikes in the mid 90s and they used mineral oil. They came with a little kit: bottle of mineral oil, syringe with tubing to bleed them & mini wrench. AWESOME brakes at the time.
    GREAT week of weather coming up, hope you got time to get out and put some miles on.
    Central Maine
    Which washer and nut?
    There’s no nut or washer in your picture, holding the counter shaft sprocket, to the counter shaft. A quick google image search for the RC8 also shows a washer and nut holding the counter shaft sprocket on, I tried to save and add the picture but the file wasn’t supported by this site.
    Dublin, NH
    The new ones use DOT4 or 5.1. They stopped using mineral oil in the Adventure line in 2016 and went to brake fluid.
    FWIW you CANNOT use brake fluid in a mineral oil clutch master/slave, it will eat the seals.
    Lastly, the OEM KTM clutch slave sucks. It's plastic and only has a single o-ring, which means with enough heat the bore will get deformed and the piston will "rotate" in the bore and eventually leaks. Get an Oberon slave cylinder if you want to avoid a headache later on.
    2023 KTM 890 Adventure R
  16. #216
    Central Maine
    Wait, what? There needs to be a nut there to hold the sprocket on, it doesn't just sit like that?
    I don’t think I’ve ever seen a bike where the sprocket just sits there
    Picking up a KTM RC8R-img_6678-jpg
    Central Maine
    I thought you were joking with me...
    I do realize that there is a nut to hold the sprocket on....
    My bad, I didn’t pick up on it.. started to happen the day I turned 50… lol
    Central Maine
    Oddly enough, it didnt have the bellville washer, it has one of those thin washers you peen over one of the flats of the nut to lock it on
    rides bikes
    Nov 2014
    You've perfectly summed up owning an aging Euro-bike! But man, when they work...they're a work of art.
    I think I only ever had two real issues with my RC8. The first was the fork lock; I forget if it had to be re-keyed before I bought it or something, but it broke in the stem and I could only turn the bars one way. Tore it apart and fixed it relatively easily. The other issue was the stator, which was of course the last thing I tested because it seemed like such an unlikely thing to fail.
    My Aprilia SXV550 however...that was a drama queen of a bike. I would LOVE to get another one of those, but I would HATE to have to rely on it working every day.
    I remember when (maybe R7?) the SXV reliability reports came out
    You guys blaze the way for us Japanese bike owners to learn the euro bike ways
  23. #223
    rides bikes
    Nov 2014
    I'm mostly on Japanese bikes too, but I'd buy another SXV in a heartbeat if a good deal on one popped up. I think it's fair to say that that was the most fun bike I've ever ridden.
    Xrocket21, do you have a louver/shutter system behind the grill of your Raptor? Is that a sham? How many vehicles just have their radiator behind the grill, but ford puts those..
  25. #225
    My SXV 550 was definitely the black sheep in the SXV community, mine was oddly reliable and other than leaking fork seals, I never had an issue with it.
    Euro bikes are definitely a passion, you own them because they are sexy, not for their reliability.
