Results 51 to 75 of 85
K-Pipe
  1. #51
    holland ma.
    Re: K-Pipe
    buddy 125 scooter can get to 55...it says 60ish on the speedo so i'm guessing it's more like 50-55....i need to confirm via gps this summer
    those little scooter scoot. It must be due to the CVT in them. I dont think I ever beat any 125 scooter on my 125. Even with the big bore kit i didnt win the stop light grand prix.
    South Coast MAsshole
    Re: K-Pipe
    I’m pretty happy with it as it’s my only 2 wheel toy at the moment and I find it fun to rip around town on...i did a bunch of homework before I picked one up...narrowed down to the manufacturers that i read were pretty reliable (list below)...after asking on here, decided on something that would register as a motorcycle so I could keep up with traffic...wanted to to have a small footprint and be agile and quick...wanted 4 stroke so no need to mix...wanted it to be affordable and have good parts availability (haven’t changed the buddy design much over the years)...wanted plastic panels over metal for weight and easier and cheaper to replace...didn’t want to shift so I can squid out in sandals in the summer...so that’s where I ended up...still want a duke 390 or maybe an electric motorcycle but this is what I have for now
    Genuine
    Honda
    Piaggio/Vespa/Aprilia/derbi
    Suzuki
    Sym/Lance
    Kymco
    Italjet
    Point37s Garage Sale Thread
  3. #53
    Re: K-Pipe
    no pic, but the exhaust came out awesome
  4. #54
    Re: K-Pipe
    Do you have it all back now?
  5. #55
    Re: K-Pipe
    no, going back to RMS to reassemble plastic & mount the oil cooler
    due to exhaust port, and oil cooler connections location, the exhaust had to be done first. the exhaust wasn't cheap, 1¼" pipe is harder to work with than larger pipe
    by the time I get done with this project, it will have cost me more than I paid for the bike
  6. #56
    Re: K-Pipe
    OK, I haven't been on it yet, but the mechanic has taken a couple spins around the parking lot, getting clutch adjusted etc. only think left is the oil cooler, I happened to stop by on my way back from a Doc's appt. they were about to call me, where to mount the oil cooler, not the best location for getting air, but out of any suspension movement, I will probably look for a shorter but wider cooler, and I may be able to mount it where it gets good air
    exhaust sounds good, quiet enough to pass inspection
    K-Pipe-img_1608-jpg
  7. #57
    Re: K-Pipe
    It's starting to look like a dirt tracker!
  8. #58
    Re: K-Pipe
    mechanic and service manager (Norm) have taken a few spins around the lot, 1st gear is low, 2nd has some nut too, larger gap to 3rd, they haven't been on road yet, but will before they call me that it's ready. The 190 is double the HP of the stock 125
    only thing left, is to wrap the exhaust, the oil cooler lines are close, so is the calf of the riders leg
    I am gonna start looking at some more dirt oriented tires, the ones on it now are pretty square
  9. #59
    Re: K-Pipe
    Careful with that wrap. Knowing you, you'll be doing a lot of all-weather riding. I know you've used the wrap before, but keep in mind that stuff is a sponge in the rain/snow.
  10. #60
    Re: K-Pipe
    the k-pipe will be a local fair weather bike
  11. #61
    Re: K-Pipe
    Norm has been prepping me for the check I'm gonna hafta write, and I know they put in a lot of extra hours not anticipated, cause other than the engine assembly bolting to the frame, there was no other "direct swap" about it. But the shop was excited for the winter work, kept em busy. and sounds like everyone wants to get on it for a spin
  12. #62
    Re: K-Pipe
    Let's go for a spin tomorrow!
  13. #63
    Re: K-Pipe
    maybe, waiting for the call to pick up, they still have to wrap the exhaust, and had to order the wrap last Tuesday
  14. #64
    Re: K-Pipe
    at least my insurance is cheap on it, Full Coverage, 250k/500k/100k limits liability & um, 100 deductible collision, and ACV on comprehensive, some other coverage as well, all for $22.51/yr
  15. #65
    Re: K-Pipe
    you know me to well
    They come in the right size, studded or siped https://www.mitas-moto.com/en/produc...s/mc-32-winter
  16. #66
    Re: K-Pipe
    If you need some wrap, I have a fairly fresh roll. I use it for a certain gasket on my woodstove.
    Holy fuck! My pig is +/- $325/year. I thought THAT was cheap!
    you know me to well
    Are they actually available thought?
  17. #67
    Re: K-Pipe
    I found the unstudded 110/80-17 in a couple places, but still looking for the 130/70-17 rear
    10" scooter size readily available
    tells me that at least one tire mfg is thinking about winter tires for motorcycles
    edit: found them readily available, studded and unstudded, in Finland
  18. #68
    Re: K-Pipe
    Let me know if you pick it up today. I'll be home at 4:00. Just dropping some shit off, getting geared up, and heading out for a couple hours.
  19. #69
    Re: K-Pipe
    picking up tomorrow
  20. #70
    Re: K-Pipe
    this thing rips 0-60 time maybe 12 seconds, cruises easily in traffic up to 65 at least, with not much throttle, did have to downshift to 4th coming up the ½ mile of 18% hill on my street, but had no problem keeping it at 50mph. Impressive cause the 125 couldn't even go 60, except down that 18% grade
    gotta get used to how the clutch grabs from a stop in 1st
  21. #71
    Re: K-Pipe
    K-Pipe-img_1609-jpg
    it'll 70+ easily, I slowed er down a bit, 250lb bike 275lb rider and a 15mph crosswind, sane cruisin speed is 60±
  22. #72
    Re: K-Pipe
    checking oil today, I discovered the new motor has both a dip stick and a sight glass
  23. #73
    Re: K-Pipe
    Now keep an eye on the level!!!
  24. #74
    Re: K-Pipe
    just got an email, the YSS shock I ordered is not in stock, either a cheaper shock, or a more expensive, waiting for links, the more $ one I think is same, but with remote reservoir, is probably the way I will go
  25. #75
    Re: K-Pipe
    I rode my K-Pipe to a doc's appt this morning, on the way back, I hit the Spaulding for a couple exits. It easily goes 65-70, maybe faster, things start getting dicey above 65, the bike is not made for that kind of speed. I will never use all 17 horsepower, I'm skert
    45-50 is nice, without having to keep it pinned like I did with the 125
    haven't used a tank of gas yet, so don't know my fuel economy yet
    I'm also looking at heat shields, even though I wrapped the exhaust, my ankle is right there, foot pegs are small, and my feet are big, I will look for a longer shifter as well
  1. Megaphone pipe on an SV
    By GingahNinjah in forum Pit Area
    Last Post: 03-17-16, 05:51 PM
  2. 99 yz 125 pipe wanted
    By shawnalan in forum Wanted
    Last Post: 05-20-13, 04:34 PM
  3. R1 MJS Y-pipe
    By Quigs in forum General Bike Related
    Last Post: 08-22-09, 05:52 AM
  4. Need 03' 636 pipe
    By NINJA_GIRL750 in forum General Bike Related
    Last Post: 07-01-09, 01:22 PM
  5. 7/8 Pipe Bender
    By clive in forum General Bike Related
    Last Post: 12-02-07, 05:56 PM
