Results 1 to 9 of 9
New Piston for my CRF
    Lifer JettaJayGLS's Avatar
    Tahoe City
    This is for my road race bike.
    The time has come (I don't know how I made it this long without replacing em) to replace the piston/rings on my crf.
    Here are my requirements:
    Semi-reliable
    Pump gas
    That's about it.
    Right now, it has an OEM piston in it. Not sure if it is the 02/03 with 11:1 compression or the 04+ 12:1 compression, but I know its oem.
    My first thoughts were to just get the 04 and keep it reliable and how it is, which is great. But Smutty started talking about 13:1 kawi pistons with bigger valve reliefs, and it seems everyone and there mother are running at least 12.5:1 without problems, and I'm at a loss. Especially since just about everything I see has to do with riding dirt.
    I know there's a ton of CRF knowledge on here (cough* Smutty, Chip, and Adam cough*), what are you thoughts?
    Other motor work includes hot cams stage 2 cam, aftermarket crank (not sure what kind) and a port and polish.
    Re: New Piston for my CRF
    O. E. M.
    I agree with Paul, if reliable is part of the equation, keep it OEM.
    *gasp*
    Lifer lrrs313's Avatar
    Asheville, NC
    If Kurlon says not to mod it, for god sakes listen to him. And write that down its got to be a first.
    -Brian
    15 S-Works Venge
    Quote Originally Posted by lrrs313 View Post
    Let the record show, my suggestion was based on the OP's 'reliability' requirement... I have a proud hall of failure showing all sorts of very fast, very exploded bits I base this advise on. Had the OP failed to mention reliability as a concern I would have instead noted that he's running longer duration cams than stock which should lower his dynamic compression, allowing him to run a higher than stock static CR piston on pump gas safely.
    Tahoe City
    Note:
    Semi-reliable
    Semi-reliable
    Sell it, get a Husaberg single cam machine. I'll walk you through a 720cc build that'll stop all over these piddily 450cc high comp toys.
    Id get an aftermarket. Just make sure its below 13:1.
  1. Caliper piston press tool
    By Punjistick in forum Bike Maintenance
    Last Post: 02-22-21, 03:50 PM
  2. Piston Ring Collapse
    By KB in forum Bike Maintenance
    Last Post: 01-09-16, 08:11 AM
  3. piston & valves
    By isaac_ in forum Bike Maintenance
    Last Post: 01-11-15, 06:02 PM
  4. Anyone have a CRF250 piston pin clip?
    By MarkMarine in forum Dirty Bastards
    Last Post: 09-08-14, 11:46 AM
  5. Reading piston color
    By Paul_E_D in forum General Bike Related
    Last Post: 01-28-07, 01:54 PM
