Page 2 of 2 FirstFirst 12
Results 26 to 28 of 28
also posted on cbr forums 04CBR600RR won't idle or run correctly
    Re: also posted on cbr forums 04CBR600RR won't idle or run correctly
    I'm pretty sure that it's a 10,000 volt spark, at the very least....
    Dec 2005
    Near The Dragon
    Quote Originally Posted by Bandit12k View Post
    I am a welder, and if you've ever welded with fluxcore, or tried to weld over rusty metal, you'll understand it doesn't take much to knock out that spark!!!!!!!!!
    And that's at 220V, with a WHOLE LOT of amps.
    A 12v spark at only a few amps is easily muffed by just a poof of sweet baby pampering honda post intake fairy powder.
    Electronics lesson : Even with 4 tips on that spark plug, you will still only get ONE arc of spark. The easiest path of travel for the juice to get to.
    spark plugs don't run at 12volts, they are usually being fed about 30,000 volts.
    voltage is synonymous with pressure, so that 30,000V will try damned hard to find a path to complete the circuit.. unlike that 220 volt welding analogy. although, with the right stick and the right settings, you can weld just about anything.. just turn up the juice
    as far as the 4 tipped spark plug, you are right, but the point is that the closest electrode erodes through use, the gap grows, and the spark moves to the new closest gap(shortest path), effectively quadrupling the plug's gap-life.
    not to be a dick, but its a good idea to fully understand the subject before trying to sound like an expert
    Get out while you can
    Find your own path
    Lifer JettaJayGLS's Avatar
    Tahoe City
    Rode about 100 miles today, idle has leveled out, and all is good
  1. For Sale - Services | Need your taxes done? Correctly and quickly?
    By Mustang in forum For Sale
    Last Post: 01-31-22, 08:57 PM
  2. over-heat and 6k idle?
    By JunoAF in forum Bike Maintenance
    Last Post: 08-02-08, 10:46 AM
  3. Won't Idle cold
    By M1966 in forum Bike Maintenance
    Last Post: 07-29-08, 07:10 AM
  4. This woman is my idle...
    By Adrenalinechic in forum Pit Area
    Last Post: 06-11-07, 08:34 AM
