2
We often teach quick turning when we work with one-on one students at TTD events. It's also something Keith Code preaches. Do You use the Power of the Quick Turn? http://www.ridinginthezone.com/the-p...he-quick-turn/
thanks for the link
Thanks Ken. These articles you post are really worth reading for me.
Thanks Ken. What's a couple good exit turns at Thompson to work on this?
Thanks.
Greg
2013 ZX6R-636
Quick turning corners at Thompson include turn 4 and Turn 8. Turn 1 can also be a quick turn...but not if you trailbrake deeply (as a matter of fact, this pertains to most corners...a turn that would normally be a quick turn needs to be a slower turn if you trailbrake).
Maxim, are you talking about NHMS? If so, then Turn 3 is a quick turn if you don't trailbrake, but is definitely a quick turn if you don't. Same goes for Turn 6. If you trail the brakes, then the turn becomes more of a slower turn in.
Thanks Ken. Something to work on Tuesday. Among other things to work on.
2013 ZX6R-636
-dana
LRRS NOV #358
http://DucatiRacerChick.blogspot.com/
There's truth and charm and beauty
And strangeness everywhere
The closer we examine
The more there's nothing there
As always, great write up!
Ken is there any opinion what technique is better for turn 3 at NHMS? My guess is they both have advantages but the main deciding factor might be set up for a pass? I had to think really hard whether I quick turn or trail brake in 3 as I feel its so close to being either but I'm pretty sure I quick turn because its more of an abrupt tip in (or flick) after hard braking so I am always pointed for the inside curbing coming out as opposed to running wide, and by doing this I seem to be able to get on the gas a lot sooner than most which makes up for the power of my SV vs big bike trying to get over the hill.
The first turn that came to mind as I was reading though was T11. Is this a turn that would benefit enormously focusing on quick turning as it would set you up better for 11A and 12? T11 is my least favorite turn and I seem to struggle on finding the correct line and its lack of camber makes it deceiving!
