Got a 99 that won't stay in third gear, probably a bend shift fork.
I want to just replace the engine instead of repair the gear due to the total amount of labor needed. My question is will a 2003 SV1000 engine fit?
Or has anyone come across my problem and what did you do to resolve it?
Or does anyone know of a good solid TLR engine for sale?
Thanks for your time.
The SV engine should fit, but you got some differences in wiring, ECU, etc. Would be a nice little project..plus the SV engine is cammed differently, and has smaller intake valves...
If you want to give me that broken motor of yours, I'll take it...![]()
The motor is mine. I would be helping with the swap and he has my yosh cans. I was hoping you would see this because you know the R and SV1K. Would you see any issues? I know an R motor will go in an S pretty easily. I know internally they are a little different, different side covers, etc. We should be able to use the R throttle bodies and ECU? Not sure about the oil cooler though. FYI two TLR motors sold on ebay last night for $375 for both. Both had issues but were complete. Do you think it would be an easy swap?
