Results 1 to 14 of 14
How to remove mirrors
    BAMF dingley00's Avatar
    Lincoln, RI
    I don't know if I'm having a total brain fart, but I cannot get these mirrors off my 2010 kawasaki z1000. They have two nuts (top one has a flange). I've tried loosening them one at a time, against each other, even tried to see if they were reversed threaded. How do I get these friggin things off!?!?!?
    Attached Thumbnails Attached Thumbnails How to remove mirrors-wp_000399-jpg   How to remove mirrors-wp_000398-jpg   How to remove mirrors-wp_000397-jpg
    2010 Kawasaki Z1000
    Lifer golden chicken's Avatar
    Attleboro, MA
    Re: How to remove mirrors
    Usually the bottom unscrews from the handlebar mount and the top one holds the mirror from spinning.
    Oct 2004
    Southeastern Taxachusetts
    Loosen the nut, then unscrew the mirror bar (twirl the mirror off)
    MSF RiderCoach
    MSF Dirt Bike School Coach
    she rides like the wind
    & smells good too.
    Lifer JohnnyV's Avatar
    Westborough, MA
    Wirelessly posted (Blackberry Bold 9930)
    Yep, unscrew the tapered collar-type nut and then spin off the mirror
    LRRS EX #99 Kitt's Avatar
    Lake Champlain, VT
    This also works...
    Lincoln, RI
    So, just unscrew the top collared nut (lefty-loosy) and that's it?! I've been doing that, there's no way that's all you have to do because I've been trying to He-Man those off for days now.
    2010 Kawasaki Z1000
    Old and Slow Sheppo's Avatar
    Westford, Ma
    the left mirror could be reverse threat.. be careful.
    Posted by Jane in BoxChat
    Lincoln, RI
    Then clutch-side I want to turn the top flange nut to the right?!
    2010 Kawasaki Z1000
    Westford, Ma
    Quote Originally Posted by dingley00 View Post
    yup... maybe
    This also works...
    Dublin, NH
    On my 08 Z1000, you had to have a wrench on both. You needed to loosen the bottom one while holding the top one from spinning. If I recall correctly they also had blue loctite on the mirror stud, so it took a bit of muscle.
    2023 KTM 890 Adventure R
    Banned Rambunctous's Avatar
    Waterville Valley, NH
    Derry NH
    Are you trying to just completely remove them to install something different? If that's the case, put a wrench on the bottom "nut" and remove. They in theory should both be regular thread, meaning turn left, and will have Loctite on them, so will require some muscle, heat, or both.
    The whole assembly (both nuts) should be a compression fitting. The bottom has 3 or 4 fingers on it sticking up that hold the mirror shaft, and the top nut tightens and clamps down those fingers to hold it all together. At least that's how my Tuono mirrors were set up, and this looks like the same setup. The 2 halves may have seized over time and may be quite hard to loosen.
    Step one: lowside.
  1. Any way to remove track day scrubbing??
    By klp in forum General Bike Related
    Last Post: 09-15-11, 10:58 AM
  2. remove front blinkers 02 r6
    By burtonboarder23 in forum Bike Maintenance
    Last Post: 04-28-11, 07:31 PM
  3. Remove Tank
    By GixxerK1ng in forum General Bike Related
    Last Post: 08-21-08, 11:08 AM
