Results 1 to 13 of 13
Revalve
    Member minutiesabotage's Avatar
    Apr 2008
    Lowell/Milford
    Revalve
    This may sound like a dumb question, and since every serious racer does it, obviously there is a good answer, but what is the point of revalving a set of forks?
    It seems to me that most bikes have enough adjustments to make them both way too soft and way too stiff. The only thing I can think of is a different damping curve to compensate better for small vs. big imperfections in the road.
    I have asked around and the best I get is "It gives you more control" or worse: "It makes it better"...so yea, hopefully someone with some experience can chase my ignorance away.
    2001 CBR 929RR
    1996 ZX-7 P1
    1981 KZ1000 K1 LTD
    Lowell/Milford, MA
    Re: Revalve
    It's a whole package. Racers usually replace the springs as well as the valving.
    While factory suspensions are decent, components, like those made by Race Tech, are more precise and offer a much better ride and adjustments than stock components do.
    Re: Revalve
    In addition to 97BladeRider's comment, I'll add that the way they do that is by precision machining their parts....something an OEM doesn't do simply because mass-production doesn't allow the extra time to de-bur and create matched sets of springs/ valves, etc.
    Apr 2008
    Lowell/Milford
    Re: Revalve
    I was kinda hoping to get a bit more technical than "better ride and adjustments"
    Edit: I think Bergs answered as I was typing.
    2001 CBR 929RR
    1996 ZX-7 P1
    1981 KZ1000 K1 LTD
    Lowell/Milford, MA
    Just Registered wookie's Avatar
    Sep 2006
    San Antonio, TX
    Re: Revalve
    Also, if you weight 250+ (i.e., wookie weight) revalve/respring can change the suspension into a range more appropriate for your weight.
    2003 R6 - Track
    2000 SV650 - Street/Track
    Re: Revalve
    Quote Originally Posted by minutiesabotage View Post
    I tried.
    Re: Revalve
    Don't be so hard on yourself Chuckles.
    Apr 2008
    Lowell/Milford
    Re: Revalve
    Haha, sorry, I did not mean that in a bad way.
    2001 CBR 929RR
    1996 ZX-7 P1
    1981 KZ1000 K1 LTD
    Lowell/Milford, MA
    Sep 2006
    San Antonio, TX
    Re: Revalve
    Technically it is vodoo magic.
    See the high priestist at GMD and remember to bring lots of bucks for sacrifice.
    2003 R6 - Track
    Lifer richw's Avatar
    Aug 2004
    Baltic,CT
    Re: Revalve
    I inquired about such race tech and they said their
    gold valves eliminated the adjustability
    t or f ?
    That's why I didn't
    Glen Beck is John the Baptist
    Lifer eboos's Avatar
    Re: Revalve
    Call Peter at GMD Boston and ask him your questions. My best answer for you would probably fall into the "it makes it better" so I will refer you to this website.
    Waterbury, VT
    Re: Revalve
    For the track - it makes sense to have someone go through the forks and shock and tweak them to balance the bike out to the rider/track/riding style combination.
    For the street - after making sure the sag and spring rate are correct for the rider I believe that there is enough adjustment through oil weight, compression and rebound knobs to accomodate most people. Put a passenger on and everything changes.
    The track is a controlled surface for the most part, while the street is random (heaves, bad pavement, etc).
    SSearchVT
    Lifer Pittenger5's Avatar
    Austin
    Re: Revalve
    Quote Originally Posted by wookie View Post
    Or 145 (dollar bill weight)
    Zip Tie Alley #505
  1. For Sale - Parts & Tools | 2006 Yamaha R6 Front Suspension W/ GMD revalve
    By Brendin87 in forum For Sale
    Last Post: 12-20-14, 02:49 AM
  2. Cartridge fork revalve
    By Paul_E_D in forum Bike Maintenance
    Last Post: 04-03-04, 10:15 AM
