1
Wirelessly posted
Dont blame Yamaha. Blame Kyoto.Originally Posted by boosten lebaron
Edit : i see smutty beat me to it.
So I went a different direction. The guys at National Powersports (Nate, Chris, and Ryan) were gracious enough to help me out of my RSV4 and into a Hypermotard 1100S. After riding Brett's last year, and coupled with ease of service, more comfortable riding position both solo and 1up, I put the feelers out there and they were great in giving me a deal that I have driven away with a very satisfied smile on my face. I highly recommend those guys if youre looking for a new bike.
Back on topic, good luck Mark, hope it works out for you.
A whole host of reasons. One being that Seacoast is 3 hours away, and no one locally could read codes, troubleshoot, etc... If a light came on like it did earlier this year, its 6 hours of driving, $200 in gas for the truck, just to turn off a service light, read a code...you get the drift.
The Hyper is beyond simple. 2 valve, oil cooled, comfortable, and dare I say more fun at lower speeds. Much easier to have fun with, and commute, and bring the GF out to dinner. I had the most fun on a ride today on the hyper than I have had in a long time.
that collapsed hose is likely form as Degsy a pinched hose between the radiator and expansion tank, line in the tank or and my money is on, the radiator cap.
There is a two way valve it the cap. The large spring maintains system pressure, when pressure is exceeded(when warming up and at temp) the spring is pushed and the coolant allowed to expand into the expansion tank.
When the engine cools the coolant contracts, the smaller spring (you can't really see but the center of the cap has a small disk that you can flick with your finger) opens and allows the coolant that moved over to the expansion tank to return back to the main cooling system. If this valve does allow the coolant to return vacuum will built in the system and collapse the hose/hoses.
If ANY part of this system is block the same thing will happen. One easy check is to remove the line on the radiator and blow throw it. If you can, the line and tank are good and the cap is bad. If not you need to fine if it's the line or the tank. It sounds like you have no plans on fixing it yourself and I don't blame you one bit but if your board and can get at the stuff easily it's worth a shot.
Tim
LRRS #44
Superbike Services 44
I try to be helpful
Tim
LRRS #44
