I know someone asked this question a while back but i couldn't find it in the history.
I have a tank with alittle surface rust inside. Nothing to serious, no pitting. Is there anything "i" can do to get rid of it or should i have a pro do it. If the pro is the way to go does anyone know of a place that will do it.
I was thinking of taking it to a radiator place and having them acid dip it. Opinions?
1993 Honda CBR900RR
1990 Suzuki GSXR1100
1992 Kawasaki ZX750
1996 Honda F3 Trackbike
I'm not worried about the paint i have to repaint it anyway. I was reading some articles that said the same thing you just said. I'll give that a try.
It's not allot of rust. There was a little around the gascap opening...i rubbed it off with my finger and it was gone. I took the petcock off and looked inside with a flashlight. No rust anywere but the bottom of the tank. There are some chemicals out there i can try. Pour it in and let it sit for a couple of hours. Rince repeat a few times. Before i spend a bundle on stuff i think i'll try the sand and beads method. Hope it works. Thanks for the input.
1993 Honda CBR900RR
1992 Kawasaki ZX750
There is some very strong toilet bowl cleaner we have at work that will remove surface rust like nothing... Let me know if you want sum? Swish it around and then flush it out good! All set to go bud
Kreem Products
This is the stuff right here. works awesome!!
1993 Honda CBR900RR
1992 Kawasaki ZX750
CYCLE TANK REPAIR KIT-POR-15 Inc.
the best stuff ever. i've used it with incredible results in a tank that sat half full for 10+ years. if you look at all their products their is a heavy duty cycle kit as well, but that may be more than you need.
LRRS EX #165 (formerly)
My other concern is when i put this stuff or any stuff in the tank will it flush out all the way. I've drained tanks before to paint them and for the life of me i can never get all the gas out. It seems like some of it sits in the Reserve area and won't come out. I know these products are designed for this purpose. But it makes me nervous to think the gas will be contaminated and fuck the bike up.
1993 Honda CBR900RR
1992 Kawasaki ZX750
LOL, think what you want... I work with metal all day long. I know what works. We cut steel parts on wire EDM's all day long that are subjected to water coolant. The surface gets rusty. We use this shit to take the rust off. Steve knows I aint a bullshitter...... steve knows me all too well!
OK...Mister Rotorouter man i'll try your stuff.
1993 Honda CBR900RR
1992 Kawasaki ZX750
Hopefully..."away goes rusty down the drain"...everyone sing along!
Alittle Tidy Bowl after that and she'll be ready to roll.
1993 Honda CBR900RR
1992 Kawasaki ZX750
unless the rust is really light, don't waste your money on the cheap stuff. It will get the rust of but as soon as the tank finishes drying out it will all rust right back up again. I went through this earlier this season before I ended up going the kreem route.
I play around a lot with old bikes.. and coting the tank can be tricky.. I have read that this stuff is the best.. I had no luck with the Keem.. But the tank I has was awful.
http://www.damonq.com/TechSheets/Red-Kote.pdf
There is a small Norton shop I believe it is in Nashua NH off exit 6 Rt3 That sells some good stuff too, I am not sure the name of the product but it easy to use 1 step process according the the guy at Hudson Yamaha.
but I never made it there. I have a few tanks I should realy get done next year. Be sure to install an inline filter
Look into POR-15.
