Results 1 to 5 of 5
Exhaust Leak Opinions
    Not sure if this is maintenance per se, but more of a what should I do question.
    I have two very small holes in one of the primaries on my header. When I say small I mean half of a pencil eraser sized and one is smaller than that. They are located directly under the bike where one of the lower primaries runs under the oil pan. That being said I have a couple proposed solutions:
    1. Go to an exhaust shop and see if they can lay a bead over something that small.
    2. Use that high temp exhaust band-aid wrap
    3. Use high temp exhaust putty
    4. If I'm feeling like a real badass, use both 2 and 3.
    Any input into this is greatly appreciated, and has anyone used the exhaust wrap/putty, thanks.
    Lifer golden chicken's Avatar
    Attleboro, MA
    Re: Exhaust Leak Opinions
    Cheapest, ugliest solution I can think of?
    Cut a soda/beer can up and hose clamp it in place. Use muffler cement or high temp silicone if you really want to. Hell, if the holes are small enough, just use a hose clamp.
    Most expensive, awesomest solution?
    Full exhaust upgrade!
    Old and Slow Sheppo's Avatar
    Westford, Ma
    why are there holes? Rot or wear? Is there enough metal to weld too?
    Weld a patch UGLY but cheap, replace that section of tube LESS UGLY still reasonable or new exhaust.
    Posted by Jane in BoxChat
    Looks like it might have scraped when going over a bump or something like that. No rot that I can see. I would hate to have to replace it with a new header.
    Westford, Ma
    Quote Originally Posted by LXnastynotch93 View Post
    have a patch welded on.. be done with it.. if it's worn through its too thin to just weld up. Plenty of good welders on the forum.
  1. For Sale - Parts & Tools | Lightly Used Rinehart Exhaust & Stock Exhaust 2020 Street Glide
    Last Post: 01-03-21, 03:09 PM
  2. Help gas leak :(
    By sliceypete in forum Bike Maintenance
    Last Post: 06-21-11, 02:01 PM
  3. Exhaust option opinions
    By FriskyDingo in forum General Bike Related
    Last Post: 04-19-11, 11:18 AM
  4. sv exhaust opinions?????
    By vintage ex race in forum Pit Area
    Last Post: 01-16-08, 11:19 PM
  5. Oil leak
    By jimaug87 in forum Bike Maintenance
    Last Post: 08-15-07, 08:34 PM
