Results 1 to 11 of 11
setting up for 3 bikes in a trailer.
    Nov 2004
    Boston, MA
    Last trailer question...
    Its a 7x12 with a 30 inch v nose...
    I have three stands, 2 condor front wheel chocks and one strapless rear stand.
    Mostly will be 2 bikes with me, occasionally a third....
    What would be the best way to do this?
    2 bikers right next to eachother in the back, and one chock up in the v for occasional use?
    2 upfront and a third single all the way at the back wuith the friont wheel between the others?
    Staggered?
    The stands will be fixed, so I kinda wanna get it right the first time....
    EVERYTHING is a repost
    06 749R #0047
    08 R 1200 GSA
    13 Monster EVO 1100
    High maintenance priss
    Central MA
    Re: setting up for 3 bikes in a trailer.
    I would think you'd want to take advantage of the v-nose and put 1 front & 2 rear. Also may make most sense from a weight distribution perspective.
    We ran two up front next to each other and the third was in between the others with the rest of our shit on either side...
    2 in back 1 in front with rear tire between the two front tires. If you got a side door this will still allow you to use it and get inside and not worrying about opening the door and have a bike right there. I’ll try to get my cad layout so you can see.
    One in front, one in the back, one in the glove compartment.
    Nov 2004
    Boston, MA
    can the one in the glove box be yours down to VIR? If so, we got a winner!
    06 749R #0047
    08 R 1200 GSA
    13 Monster EVO 1100
    I guess I'm only bringing the Go-ped this year
    If you are mainly running two bikes, set up for that.
    I like to have my two bikes centered over the trailer axle, and then arrange my gear to get close to the proper tongue weight. Sometimes this means throwing a heavy item behind the bikes.
    I also built a work table/shelf along the front of my trailer, but I built it high enough that I could still roll a bike wheel under it if I had to carry a third bike.
    Tony
    Trackdays in CT, NY, and NH
    www.TonysTrackDays.com
    Jul 2002
    Waltham
    Tony's makes the most sense as most of the weight should be dispersed over the trailer axle or axles.
    Nov 2004
    Boston, MA
    Quote Originally Posted by 35racer View Post
    I guess I dont fully get the tongue weight concept. Do I want to have as little as possible or an exact amount to balance things out?
    Why would you need to put a heavy item behind the bikes?
    06 749R #0047
    08 R 1200 GSA
    13 Monster EVO 1100
    Roughly 10% of the weight should be on the tongue.
    If everything weighs 4000 pounds, you should have a 400lb tongue weight (put a stick under the tongue going down to a scale to get a number)
    If you have a 600lb tongue weight, moving some stuff from the front of the trailer to behind the bikes will help balance things out.
    Now... don't get anal about this, but it's good to do it one time to get a feel.
    A trailer with too little tongue weight will sway a lot. With too much, the front end of your truck will have no weight and you'll look like a V from the side.
    Tony
  1. 2 bikes on u-haul trailer
    By Marc R in forum General Track Day Talk
    Last Post: 09-07-12, 10:19 AM
  2. Best trailer setup for 3 bikes?
    By xxaarraa in forum General Bike Related
    Last Post: 09-01-12, 06:29 PM
  3. New tron trailer w/ bikes
    By P_easy in forum General Bike Related
    Last Post: 08-27-09, 11:48 AM
  4. I'm unloading my bikes from the trailer when
    By dhuze in forum General Bike Related
    Last Post: 08-09-06, 06:00 PM
