Results 1 to 13 of 13
setup Penske shock for a different bike
    Dec 2009
    Hoping for a bit of information on a shock upgrade for my track bike.
    I have a Penske 8987 triple that I'd like to use on my Gen2 SV650. It was originally set for a GSXR 600 with a 6” long Hyperco spring. The spring was marked 650 – 648. As I'm 175 lbs w/o gear it looks like I need to do a spring swap and change the valving. The length looks OK for an SV as it's eye to eye length is set to about 335mm (adjustable).
    For spring it looks like I need a 500 lbs spring. I'm assuming all I have to do is move the upper spring collar from 6” to 7” from the lower collar, get a 7” Hyperco 500 lb spring and have the shock valve shimmed for my weight. Am I correct?
    Thanks for your help.setup Penske shock for a different bike-penske-8987-shock-body-jpg
    Re: setup Penske shock for a different bike
    Is the geometry/linkage the same on the GSXR as the SV?
    Dec 2009
    I don't know about the GSXR geometry.
    I thought the point when replacing a shock to keep the geometry of the bike as close to original as practical. I haven't changed the linkage of the SV. The new shock length is essentially the same as the original shock. Why do you ask?
    Permanent N00b -Dutch-'s Avatar
    Feb 2014
    Pawtucket, RI
    That sounds like an awful lot of work. Send it to me and forget about the headache.
    Rookie Rada's Avatar
    Sep 2010
    Granville, NY
    Call PK at GMD...
    Dec 2009
    Call PK at GMD...
    I did today but got voicemail. I suspect they're pretty busy getting customer stuff ready for the season. I'll be trying again tomorrow. In the mean time I figured I'd ask for some that have gone this path before.
    Senior Member marshdrummer's Avatar
    Nov 2006
    Southington, CT
    You can call Penske also. they can tell you the original differences. I say original since the LRRS guys like there rear ends jacked up...(insert awesome comment here)
    Sep 2010
    Granville, NY
    Stiff too
    Quote Originally Posted by 02redhawk View Post
    Because if the geometry is different in how it exerts force on the shock, then you may be in for a really bad time trying to get it to work. Things like progressive linkage vs non-progressive, length of lever for swingarm, etc. Any of those differences would make quite a difference in an SV shock to a GSXR shock.
    So, while you wait for a call back from GMD, read what GMD wrote here:
    http://www.nestreetriders.com/forum/...hock-Swap-Myth
    May 2011
    Holyoke, MA
    A shock is a very simple spring and damper. As long as the spring rate, length, and damping characteristics are good for the SV it will work. He said he was getting it resprung, revalved, and it is set to the right length. The linkage will affect the force the shock sees so a 500lb spring on one bike may be too stiff and on another it would be too weak based on the force curve, but a 500lb spring on an SV is a 500lb spring no matter what brand/model shock you have.
    The post does bring up a good point though. If you pay $400 for a used aftermarket shock that needs to be resprung and revalved to match you, why not simply buy a brand new shock that is already in the right specs? it will end up costing the same. Also goes to the value of a used bike with an aftermarket shock. If it's not set for your weight(or close enough that it can be adjusted to work), it doesn't really add much value to the bike because of the expense of having to set it up.
    Dec 2009
    Thanks for all your responses. I met with pk this afternoon and left the shock for a new spring and revalve. As for the going the reconfig route, I figured the shock body can be setup for many different bikes. Different springs and valving for sure but as long as I was looking at a config that had a similar length and stroke I should be fine. A good point was made about geometry but again I wasnt changing linkage, length or stroke so it seemed worth a shot.
    Finally, I kept missing deals on the used Penske doubles and new ones were above $800. A new Jri was a bit more. I'll be into the triple including having it setup for me around $750 before I sell the other spring. Seems llike it should work out ok.
    Sep 2013
    Boston, MA
    I'm a little late in replying but here goes. I got a 8983 (double) last year, which is pretty much the same shock as the 8987, but without the high speed compression circuit. I have an '06 SV and I weigh about 165-170. My shock was set up with 335mm length and 500# spring. I'm not sure what valving was used, but it was set up for an SV. The 335mm length raised the rear end, which improves the geometry over stock (330mm, I think). For racing, 340mm is common. If you're coming from a stock shock you are going to love the Penske!
    Dec 2009
    Thanks for the replys. I'm looking forward to the improvement.
  1. For Sale - Parts & Tools | Penske shock for CBR600 F4 / F4i
    By MattR302 in forum For Sale
    Last Post: 04-13-17, 09:48 AM
  2. For Sale - Parts & Tools | Penske Shock for SV650 gen 1
    By Mad Max in forum For Sale
    Last Post: 04-09-14, 11:43 PM
  3. WTB 08 gix 600 Ohlins/Penske shock
    By ahtune69 in forum Wanted
    Last Post: 05-12-13, 06:05 AM
  4. Penske shock rebuild
    Last Post: 10-30-12, 08:21 AM
  5. '03-'09 R6/R6S Forks & Penske Shock
    By ///3oris in forum For Sale
    Last Post: 09-22-12, 09:24 PM
