Hey does anyone have a copy of the suzuki warranty online ? Also does it cost anything to bring in my bike to the dealership and ask them why my bike isn't starting when it's covered under the manufaturer's warranty ?
It won't cost you anything but the time & effort to take the bike over to the dealer. I'm not sure if Suzuki does this but most companies any dealer will know you have a warranty just by looking the VIN # up in their computer.
Since a broken bike can't take itself to the dealership though, it might be easier to try and figure it out yourself though. Or tell us what's going on and someone might be able to help you.
If your bike is an 02 and it was working last fall and now it won't start, I bet the battery died. Did you stick it on a charger for the winter?
Ben
thx for the help , yep charged it but then , i was like wtf . . . didn't start . . . . I think its the spark plugs cause the starter works and all and the battery seems fine.
is the bike crankin' over and over...seems like it WANTS to start...but wont?
If thats the case...just leave it be till spring (warmer weather).
lines could be froze up.
Give it some time to thaw out...and if you have a fuel on off switch...CHECK IT!
Sounds dumb...but i've heard of worse...
If that still dont work...I sugggest lookin' um Mark (a.k.a) TLR MAN
(a.k.a) Mr Wizard (a.k.a) Wiz (a.k.a) the shit!![]()
" Never create what you can't control "
Did you make sure that the kill switch on the handle bar is set on run. Sounds like you have a switch off or a bad sensor, ie neutral, kickstand.
'04 600RR
If the starter works it's not the kill switch or the kickstand sensor.
Alright thanks everyone for their help , i'm just gonna wait till spring comes cause frigin snow everywhere . . . I'm pretty sure its probably the cold cause it started before when it was 40+ degrees outside.
no problem...
good luck!![]()
