I have my old laserdisc player, or is that 90's?? I always wanted to hang one of those bad boys from the rear view like people used to do with CD's.
Sweet! Special socket came in early, hopefully doing the steering head bearings tonight.
Man, what a PITA it is to get the rear wheel off....
Keep tinkering, you're going to make me really happy one day.
New castle socket worked mint. Also works for taking the swingarm off my Wee and SV, bonus!
I get bikes, and I make them right. That's my thing. I am not a polisher, washer, cleaner, detailer, etc. I don't mind my bikes dirty. But mechanically? They have to be right.
Got the front wheel bearings out last night thanks to my neighbors blind hole bearing puller. Steering stem is in the freezer with the new wheel bearings waiting for more of my free time.
Hoping to get it together by the weekend.
Just as I feared, right rear wheel bearing was toast and the hub where the bearing sits is fucked from wear. No wonder the PO tightened the shit out of the axle.
Two main things can/do go wrong on these bikes. Stator, which is fairly easy to test, and the rear bearing issue, which can't be tested for until you pull the wheel off the bike.
Looks like I'm in the market for a wheel.
Not sure of the exact situation, but can you use some green loctite to retain the bearing?
I've got a little bottle of 648 on my desk just gave me the idea.
I'd need to machine the wheel to assure centered bearing either way.
The "proper" fix for this is to swap a GL1500 rear wheel/final drive. They corrected the bearing offset issue by then.
If I can find a used wheel from an '86/87 GL1200 where the bearing hasn't spin or enlarged the hub, I could use the green loctite stuff when I install the fresh bearings.
Got a link?
Got an assortment from Amazon on the way.
I just found 3 quarts of Honda OEM coolant in my garage if you want them. Brand new and sealed. They are what the goldwing manual calls for for coolant
