Results 1 to 17 of 17
Storing A Bike The Right Way
    Member S4R_GRL's Avatar
    Apr 2008
    North West Corner of Rhody
    I am purchasing a new home soon and one of the sacrifices that I need to make is to store my Ducati for this season. The decision is a financial decision, I will be able to store it in the new place. It is heated, indoor storage, in the basement of the new house.
    My question is what do I need to do to it to preserve it? I don't want to let it
    sit an wrought and have more problems next year because of the haitus.
    Nat Pixon! noxin's Avatar
    Apr 2008
    Boston, MA
    Wirelessly posted (BlackBerry8310/4.2.2 Profile/MIDP-2.0 Configuration/CLDC-1.1 VendorID/102)
    Just follow the winterizing guides. All of it will be relevant until you can wake it again
    Lifer BostonSVkid's Avatar
    Dec 2005
    Re: Storing A Bike The Right Way
    Umm I will ride it all season and see the bike gets plenty of use!
    2006 Ducati Monster S2R800
    Super Moderator beet's Avatar
    May 2002
    Meriden CT
    for how long?
    www.bostonmoto.com
    Forum Rules
    I've always stored bikes in the basement and pretty much don't do anything to them other than topping off the battery once a month or so.
    Expatriated to Seoul spicy's Avatar
    Reading-> 서올특별시 강남구
    winterizing would probably be appropriate, depending on how hardcore you wanna be.
    light: yank battery, full tank, up on stands
    heavier: + fuel stabilizer, WD40 chain, block off exhaust, charge battery once a month
    heaviest: + block off airbox, WD40 entire engine, oil change, fill crankcase with oil up to spout (must remember to drain to proper level before resurrecting), yank plugs and dribble oil through into cylinders, trickle charger for yanked battery
    hurray, strikethrough!
    Apr 2008
    Quote Originally Posted by beet View Post
    for how long?
    For about a year. I have a Kawi that I will be riding this year because it's alot
    cheaper to insure. But, Next season I will be riding the S4R again..
    Member clutch's Avatar
    Oct 2008
    The best way would be to find a self storage unit about 50 miles away. And ride it there everyday.
    Lifer akira700's Avatar
    Apr 2005
    in the city
    One thing people didn't seem to mention is get the tires off the
    ground. And keep it away from ozone producing electric motors.
    2008 Honda CBR 600RR
    LRRS EX #99 Kitt's Avatar
    Lake Champlain, VT
    Dear S4R GRL,
    Your duc would be approximately $15/month to insure in NY. Please send photo application in order to use my NY mailing address to get in on this excellent offer.
    Love,
    Kitt
    Apr 2008
    Thank you so much for all the offers of assistance. This is not just a matter
    of the cost of insurance, but due to the fact that the bike needs some work
    and every time it goes into see Miles up at BCM it costs me an arm and a leg.
    Which normally I'm happy to pay for the peace of mind of fantastic service,
    however with the recent home purchase I don't have any spare arms or legs.
    From the serious responses I have gathered to:
    a) fill the tank and put Stabil in gas
    b) remove battery and charge once a month
    c) cover up exhaust and air (is this really necessary since it will be stored
    in my basement which is dry and heated?)
    d) get it off the tires (will having on a pit bull suffice?)
    Thanks in advance to those offering genuine advice.
    Quote Originally Posted by S4R_GRL View Post
    On point B, the easiest thing to do it not to pull the battery, but to get yourself a BatteryTender and keep it plugged into the battery. This makes sure that your battery always has a charge. It comes with leads that you attach to the battery terminals and the BatteryTender plugs right into them.
    It keeps a maintenance charge on the battery and only runs to trickle charge the battery as needed.
    When you're ready to ride, just put the cap on the leads and tuck them away.
    Apr 2008
    I already have a battery tender and the leads, it is usually kept this way for winter. I was wondering why some said to pull the battery rather than just keeping it on the tender?
    Maybe because it is still attached to your bike's electrical system.
    Apr 2005
    in the city
    C) Yes cause rodents can make your bike a nice home!
    D) Pit Bull? That's the Lexus way of doing it!
    Quote Originally Posted by akira700 View Post
    I can definitely attest to this. I had quite a bit of sunflower seeds come out of my wife's bike's pipe when I started it up a couple of weeks ago.
    Block every orifice that a rodent can stash stuff and hole up in. THey usually go for the pipe and airbox. Both of which are scary, if they get all the way to the engine.
    Oct 2005
    Wrentham MA
    In addition make sure you have stabl throughout the fuel system.
    I would also fog the motor...(fogging oil) any marine store has the stuff.
    It' s as simple as getting to the air cleaner - removing it and quickly spray the oil mist directly into the in quick secession-back and forth - about 5 seconds with the throttles 1/4 to 1/2 open when you hear the motor stumble throttle bodies- shut it off quickly....
    if anal - also pull the plugs and squirt more (or marvel mystery oil right into the cylinder and spin the motor over with the starter... this last part is usually for multi year
    why do all this - your valve seats and cylinder walls can quickly rust....
    Also Before putting to sleep run at least 20 miles so the oil is hot (outgases all the gas and nasty stuff that blows by the rings. AND NEVER start it until you are ready to de-winterize...
    when you pull it out to use - remove plugs and spray in marvel mystery oil and let sit for a day... also throw away all the gas (in lawnmower etc) fresh gas and add marvel mystery oil to your gas (helps lubricate the valve stems.
    Proof: today I just started up my Aprilia that has been sleeping undisturbed for +6 years... started first time on the same battery that has been on a battery tender for those six years...(make sure the battery is not sitting on concrete).
    Ok folks are going to say I never fogged my motor- my question is, when did you last do a leak down test - to check your valves are sealing tight.?
    Graham
  1. Storing a track bike
    By Baggey22 in forum General Track Day Talk
    Last Post: 05-31-12, 04:57 PM
  2. Replies: 1
    Last Post: 07-08-09, 04:25 PM
  3. storing bike w water/coolant
    By seth399 in forum Bike Maintenance
    Last Post: 11-22-08, 12:26 AM
  4. ? Storing bike indoors/basement
    Last Post: 11-28-07, 03:59 PM
  5. Storing the bike in a condo?
    By Bster in forum General Bike Related
    Last Post: 11-11-06, 08:50 PM
