Results 1 to 15 of 15
what's the point of "gp style" shifting?
    "aaah!" Matt K's Avatar
    Oct 2002
    Acton MA
    How come they use 5 down/1up and we don't? Is there an advantage to either setup? I mean, it's so easy to change, why doesn't everybody do it? : Thanks....
    "Balls," I said. "Never mind the track. The track is for punks. We are Road People. We are Cafe Racers."
    - Hunter S Thompson
    2 x 82 GS 650, '94 RM 80
    Oct 2002
    Acton MA
    ah, that makes sense. maybe I'll give it a shot
    - Hunter S Thompson
    Lifer SEVENSGT's Avatar
    Warwick, RI
    I was thinkin bout it too seems to be easier then normal but don't I repeat don't let anyone ride your bike......................
    Oct 2002
    Acton MA
    cool... I just flipped the lever around and went for like a 10 min ride, I like it better already, it just seems a little more natural and intuitive, which is cool.
    - Hunter S Thompson
    I had been riding for over 25 years with 'regular' shifting before I switched last year on the Tiller. When people ask why I did it, I explain like this: Ya never miss a downshift, right? Now imagine that when you make that same shifting motion, you're upshifting...
    It took me a coupla weeks to get used to it though. And it really helped during track day going through turn 7 to be able to shift like that. But on the street, it means no false neutrals...
    Jon and Clara's Dad snaggle's Avatar
    Mar 2002
    Walpole,NH
    I switched to GP this summer, 'cause I was starting to miss 2nd gear shifts. Haven't had a problem since then though. Thanks for the advice stoneman!
    '04 600RR
    For me, I like Gp shifting cause you can upshift while your leaned over, ever since they paved the Chichester Center Road, one of the corners I always want to shift up while leaned over, I need to get down into second coming into the corner, but right about the time your leaned over the most, the rear wheel wants to spin, and short shifting into third solves that problem but theres no way to get your toe under the shifter to shift up if you have regular shifting.
    I want to switch my 920R to GP, but they don't make it quite as easy as on modern sportbikes
    Junior Member flexysteve's Avatar
    Apr 2002
    I changed it on my R6 for faster shifting (shorter "throw" due to using an r1 arm) and less false neutrals.
    At work one time, someone tried to steal it. They hotwired it and tried to take off with the disklock on the front. Luckily it was probably in second because no real damage was done. Then they just left it and tried another bike
    Though it would have been worth it to see some asshole theif on the news in a bodybag after revving the hell out of it and trying to do a 1-2 shift and really doing a 2-1 shift, swap ends and go flying off the thing racing up Rt 93.
    Beware of stealing peoples bikes. They might have hidden booby traps that only the owners know about.
    Posting Freak SWEET_Z's Avatar
    Jul 2002
    Smallbany, NY
    The reason's given are what I have always thought. When I first started riding I thought the shift pattern was opposite of how it should be! Can someone post some info on how to make the change? Thanks!
    Easy as pie on most newer bikes. Just flip the linkage over that funs from your shift lever to the shift shaft. On my TL-R, the linkage originally connected to the top of the shaft. Five minutes later, it connected to the bottom of the shaft and I had GP shifting...
    Badda BING!
    Warwick, RI
    Yes I'm goin to do it!
    This winter when the bike is on blocks I will be tinkering around wit just bout anything my unmechanical ass can(oh BTW Racya we will be changing to 1 up 5 down on my bike)
    Member alfred's Avatar
    Jul 2002
    Manchester
    I took my TLR for service about a month ago. The mechanic ran my battery dead trying to find neutral. They had to call me at work to ask if my netral lite was burnt out. Only then did I tell them I had reversed shifting (GP).
    Oct 2002
    Acton MA
    guys, you could be the most un-=mechanical person in the world and you could still flip it in under 5 minutes. It seriously took me like 45 seconds. Here's what you do: look at the picture,
    see the red bar? Flip it from pointing up to pointing down. You'll probably have to pull out ONE SCREW, the one that holds the red bar in place. you should go try it, 'cause it's too easy to not try.
    Freak Posting snowborder's Avatar
    Mt. Wannahuckaloogi
    not all bikes are as easy... some like mine have fairings in the way.
    2001 RC51!!!
    2007 Husky SMR 510 - no longer... blown tranny
    Oct 2002
    Acton MA
    oh well, I'm sure you all have friends who can help you.
    - Hunter S Thompson
  1. Can we get a "free stuff" or "pay it forward" section?
    By nick5446 in forum Site Info & Suggestions
    Last Post: 01-26-17, 04:06 PM
  2. From "Sunuvabitch" to "Hell yes" to "WOOT!"
    Last Post: 05-16-12, 06:46 PM
  3. Big thumbs down to "clip style" master links
    By madkaw in forum General Bike Related
    Last Post: 06-15-09, 07:02 AM
  4. There's "Posing"... and then theres.... "Pousing in style"
    Last Post: 06-18-07, 09:22 PM
