Results 1 to 8 of 8
stuck fairing bolt??
    Apr 2004
    boston burbs....
    Ttrying to replace the light swith on the sv650.
    the harness runs thru the frame under the airbox behind the radiator.
    pain in the ass to get to.
    Looks like I have to take off the side fairings to take off the radiator but....
    the dam Left side fairing bolt is stuck. The bolt has never been taken off, bike is 3 years old only 800 miles.
    I tried using a t-allen wrench and i cant get the bolt to budge. I know i'm weak and out of shape but this is ridicolous.
    Any ideas? beside getting a bar to slip on the the T and create more leverage? not much area i can get some PB(seized bolt remover) in there. I'm actually worried I might strp the bolt head or break the T-allen wrench
    yes I could access the other side but I still need to put on the frame slider and take off both sides.
    I need to replace the switch as its broken and need it fixed to pass an inspection
    hmmmm......
    Mar 2004
    woonsocket ri
    Re: stuck fairing bolt??
    Get some allen sockets. You get more leverage. They are pretty snug. Just dont get all superman on it and break it. You should be able to tell breaking from turning. If it seems like you are putting too much pressure on it. Stop.
    If you are able to lightly tap on the head of the bolt before you attempt to loosen it that might help as well.
    Jan 2009
    Waltham
    Wirelessly posted (Tilt: HTC-ST7377/1.59.502.3 (67150) Opera/9.50 (Windows NT 5.1; U; en))
    +1 on socket bits
    dont forget to re locktite when finished.
    #331 CBR929RE's Avatar
    Bridgewater, MA
    Quote Originally Posted by WordTooYoMamma View Post
    +1 on socket bits
    you put loctite on fairing bolts?
    KB KB's Avatar
    Manchester NH
    Grow a set and twist.
    LRRS/CCS EX #13
    GMD COMPUTRACK
    san fran
    I used my cigar lighter to heat up the bolt without melting the plastic when I had to remove the chin piece from my tuono. Same situation as yours, never been removed since new and after a few thousand miles or rain and other funk, it was stuck on there. Try to find a little torch lighter.
    Tuono
    Apr 2004
    boston burbs....
    good points... thanks.. going to pick up some allen sockets..
    then some balls....
    hmmmm......
  1. Fairing bolt size and sourcing
    By Eddie in forum Bike Maintenance
    Last Post: 03-23-18, 12:01 AM
  2. Replies: 28
    Last Post: 12-05-14, 12:43 PM
  3. fairing bolt kits?
    By crowspeed07 in forum General Bike Related
    Last Post: 07-13-11, 06:04 AM
  4. Clutch Lever Pivot Bolt/Nut -- stripped/stuck -- removal
    By dhawks in forum Bike Maintenance
    Last Post: 03-13-10, 06:45 AM
  5. TL1000R race fairing & fairing support
    By jeffsv in forum For Sale
    Last Post: 05-07-09, 02:23 PM
