Results 1 to 19 of 19
need suggestions/help gsxr600
    AMA wannabe lrrs699's Avatar
    RI,NH, Derby,ct
    Havent started the bike for awhile, put a crap load of parts on it this weekend, went to start..... nothing, Discounted the ignition mod i put in, back to stock still nothing, Doesnt wanna turn at all.. turn key, pump turns on, wont turn over,.......... hooked to charger, connected between fuse relay and got bike started, thats the only way it would start up. wanted to keep working but just ran out of daylight, any ideas what it is?? thanks
    Re: need suggestions/help gsxr600
    Sounds like a Bad battery...I have a spare thats always fully charged just to check.
    I would either borrow a good one or replace.....
    also was the bike on a battery tender at all if not DEF battery...
    What MOD where you doing a TRE or PC???
    This is Why...........just enuff to fire up but not enuff for the whole system to really work 100% so Bad Battery.
    "hooked to charger, connected between fuse relay and got bike started, thats the only way it would start up."
    Just my 2 cents
    Do you have a power Commander?
    If so Check how its hooked up. For some Reason I think the red wire goes to Negitive for some reason. Dollar bill Would know
    Zip Tie Alley Racing #444
    Signature edit by Tricky mike
    what year gixxer? if it's an 01-03 model, have you tried the electronic choke? my K2 is FI, but still has problems starting in the cold sometimes.
    Lifer Pittenger5's Avatar
    Austin
    Quote Originally Posted by BLACK SQUIRREL View Post
    Zip Tie Alley #505
    I did that on mine too
    LRRS EX #99 Kitt's Avatar
    Lake Champlain, VT
    02 was the last year they did that IIRC
    Justin - this problem was happening without the PC plugged in? or was your PC in already? and this problem was with or without the ignition module?
    RI,NH, Derby,ct
    06 gsxr 600
    Stupid me i didnt try to start it before i installed everything....
    power commander was already in from last year. put in ignition module which i dont have the cd for so i am borrowing that from a buddy. figured that was it. so i disconnected and put back to stock..nothing still.
    Got it running thru another method, bike was running rough, odometer kept flashing/throwing rpm tach up as if it was starting. You know what i mean, when u start bike the tach goes up and back.
    Lake Champlain, VT
    check your ground... You may not have had a good ground after installing the Ignition Module, since adding a couple extra ring terminals (PC, IM) to a regular battery machine screw makes it hard to reach the captured nut (unless you lift it up with a flathead while you're threading in the screw). It's possible you didn't tighten the hot/ground wires back up tight.
    Assuming you checked this thoroughly, you say the fuel pump was priming? So... not the TOS. Was this a previously salvaged bike? If so, it's common to have scored wires in the main tach/headlight portion of the harness from front end impacts (plugs into main harness just behind the neck & has the clear rubber boot around it).
    If those don't pan out, I can take a picture of the 2 wires you need to jump to put your bike in dealer mode... may give you a code.
    but yea, as mentioned above... it would be a good idea to test it with another battery (you must have a friend with a GSXR nearby).
    RI,NH, Derby,ct
    battery hookups were tight as it could get.........was a salvage bike, never had an issue with it before. my buddy checked that connection( clear rubber boot) i didnt look personally. Kitt could you shoot me that picture, just in case...bike is still in RI so i am running out of options/time before first weekend.
    Lake Champlain, VT
    Quote Originally Posted by lrrs699 View Post
    well if you want to bring it to my place next weekend (I have good friday off) we'll get it sorted for you.
    The connection wasn't my concern... wires with insulation cut around the neck was... One of my bikes had this issue.
    I have spare TOS's, Spare Batteries, Dynojet software, Spare GSXR's haha... we could find your problem in no time.
    RI,NH, Derby,ct
    Probably gonna take you up on that offer, unfornately i have to work friday. plus with all your spares is a big plus, i am afraid i figure it out and have to wait for an ordered part to show up. we should definately figure it out....i hope...
    Lake Champlain, VT
    I'm down for whenever then... Let me know what works. weekday night or weekend anytime doesn't make a difference. Meg wants to make it to Boston saturday or sunday for the day - so give me your thoughts sooner than later.
    RI,NH, Derby,ct
    Cant really at all during the week, i work 2nd shift. Sunday would be best for me. I can finish my trailer up and get it all loaded and head your way Sunday morning.
    Doesnt make a difference to me but it is Easter sunday dont know if got some family stuff going on.
    Lake Champlain, VT
    I do have some plans sunday.... Is your bike ready otherwise? I'm not too worried about being able to figure out this problem, and the following weekend is much emptier schedule wise.
    RI,NH, Derby,ct
    Bike is basically good to go but the following weekend is fine. I figure my mom would be pissed if it went home to visit grabbed my bike and took off on easter. Hey where do you get your bike dyno'ed?
    Lake Champlain, VT
    I have a custom tune, but GixerJockey has a buddy who does sidework out of his garage in CT. Other than that, nowhere close.
    RI,NH, Derby,ct
    figured i would ask, i will just bring it by a place Leo suggested in dracut
  1. For Sale - Motorcycles | 2006 GSXR600
    By Stoneman in forum For Sale
    Last Post: 03-12-20, 01:56 PM
  2. For Sale - Parts & Tools | 06/07 GSXR600 Parts
    By MaRce1o in forum For Sale
    Last Post: 03-21-14, 12:26 PM
  3. 08 R6 vs. 08 GSXR600
    By RyanNicholson in forum Pit Area
    Last Post: 11-05-07, 02:44 PM
  4. Replies: 21
    Last Post: 02-15-07, 06:03 PM
  5. The Elusive Red GSXR600...
    By Rhonda66 in forum General Bike Related
    Last Post: 08-15-05, 07:01 PM
