Results 26 to 50 of 66
Suggestions for safety wire pliers?
    Re: Suggestions for safety wire pliers?
    Cuz I don't like anything less than 8" in my hands.
    (Sorry Jim)
    Srsly tho, I don't think it makes much difference. The only thing I can think of is:
    9" pliers require less pulls if you've got a lot of space between bolts.
    6" pliers allow you to work in smaller work areas.
    I never really had any tight work areas.
    Lifer JettaJayGLS's Avatar
    Tahoe City
    I have both the 9 inch and 6 inch harbor freight pliers. After having borrowed a good set from time to time, I know first hand the harbor freight pliers suck. As does the thick ass safety wire they sell. If I have to do it over again (especially with a motard where I was changing oil constantly and the only way to safety wire the drain bolts were to each other) I would spend the dollars for a reputable brand.
    Lifer Ductard's Avatar
    Sep 2013
    South Boston, VA (not a typo)
    I just got a set of the Milbar 25W's from crawford tool. I also bought some of the Malin 0.025 Stainless steel wire.
    I have some 0.032 wire and some blue-point pliers kicking around somewhere...got the ?blue-points? used off of ebay and they worked great (they cut the wire unlike some of the cheaper versions) but they aren't reversible and when I dig them up I can keep one set in my garage and another in my trailer.
    I got the 0.025 wire only because I already have the 0.032 wire...looks like the 0.032 (per amazon.com and street & comp) is the more popular size, but won't the 0.025 work in *most* applications?
    I mean maybe I should opt for the 0.032 in places where I'm securing a large nut/bolt (i.e. axle / axle nut)....
    LRRS 919
    Lifer jasnmar's Avatar
    Mar 2012
    Chichester, NH
    .025 is the minimum LRRS legal size, but yes, it will work.
    Lifer GMAN226's Avatar
    Coventry RI
    Get the ~$60 Milbar unit.
    Gerard
    It's funny this thread should get tickled. I should pony up.
    When doing track days it didn't matter and the HF set were good 'nuf. Now that I have to wire the whole damned bike and rewire it every time I swap wheels, I feel differently.
    Last race I struggled "fixing" my shitty wire pliers for every other wire I had to twist as the stupid tab kept deforming. Shit.
    Milbar eh?
    Milbar. My buddy snagged a set for crazy cheap at a pawn shop. Maybe check a local one near an airport lol?
    Mar 2012
    Chichester, NH
    Milbar eh?
    You are welcome to mine (when I can find them).
    Actually these are something I can usually locate. I'm relatively sure mine are ancient milli bar's.
    I wasn't going to say it.
    High maintenance priss
    Central MA
    Another vote for Milbar 25W; what i've used for a few years now.
    Sep 2013
    25W seemed to be the consensus...except for Pete, who got the bigger version (26W).....Maybe he's compensating for something?
    LRRS 919
    I want these... Milbar brought the Tigerwave back.
    Milbar - MLB-7W - Safety Wire Twister - Chief Aircraft Inc.
    Posting Freak Gecko's Avatar
    Jul 2008
    I searched for these everywhere years ago. Ended up with a pair of MLB25W's and never looked back. I think the time has come to right a wrong.
    John
    CCS/LRRS Expert #69
    LRRS Rookie of the Year 2004
    Windham NH
    Having only ever used my cheapo pliers, I would love to understand what all the fuss is about with the expensive ones. They seem like pretty basic, uncomplicated things. My only complaint about the cheapos, and its not a big one, is that I must hold the pliers on the wire with one hand, then lock the clip in place with the other. Would be nice if this could be easily one-handed.
    Tahoe City
    Over time my harbor freight pliers have lost strength in locking ability. Meaning I set the wire, lock the pliers, pull, and the pliers slip, and spin the wire further down than I would like.
    The clasp that holds the cheap HF ones closed deforms. This means they will no longer stay closed on their own. I can 'fix' my pair and have done so 10+ times. But each time the metal clasp deforms a little more and becomes weaker. Now I feel as if I am 'fixing' them more than I am using them.
    Also, the cutters don't cut. And the face of the pliers don't always hold the wire very well. Sometimes they require a lot of force to close. Sometimes the handle doesn't quite line up with the clasp and is 539204x harder to close than should be.
    Basically, they suck. I got what I paid for.
    Windham NH
    Sounds like I either got lucky or just havent used them enough for the problems to arise.
    Yeah, all the cheap ones I've had rusted if you looked at em wrong, got dull the first time you used em (I use .025 wire), weren't smooth to open or close, pull knob was notchy & didn't return easily, etc.
    As far as specialty tools go, safety wire pliers are the ones I use the most by far. More often than my torque wrench, even.
    Next time we're both at the track & you need a pair of safety wire pliers, come find me. I'll let you take em for a test run. They're pretty nice.
    Jul 2008
    While I haven't been racing as long as many others ... after 12 years, I want everything that I reach in and pull out of my tool cart to work ... every time, all the time. It's one less thing I have to think or worry about.
    If my MLB-7W's are here in time for the Classic (thanks Pete ), swing by and I'll let you take my pair of MLB25W's for a test drive over the weekend. But don't blame me if you end up not being able to live without a pair afterwards.
    John
    CCS/LRRS Expert #69
  21. #46
    Quote Originally Posted by Gecko View Post
    Jelly!
    I'll have to check em out. If they have the cushion throat imma have to wrestle ya for em.
  22. #47
    Sep 2013
    Jelly!
    Are they that much better?
    They just have a "wave" in the jaws to hold the wire better? I haven't really had an issue with the wire slipping in my blue-points.....
    Wondering if I should try to cancel my 25w's.......
    LRRS 919
  23. #48
    They're not THAT much better.... The wave is so it holds them firmly without little micro nicks in the wire that the normal knurling can cause. It's a "cool kid"/super anal safety thing. A little unnecessary in my opinion but I think it was once required by the FAA?
  24. #49
    Where are you all buying these tools for (the most) reasonable money?
    crawfordtool.com had the best prices delivered to my door that I could find at the time.
    chiefaircraft.com is another site you can pricecheck.
  1. Replies: 74
    Last Post: 07-30-16, 05:27 AM
  2. Safety Wire Pliers
    By Ray-Ray in forum Wanted
    Last Post: 04-13-11, 03:16 PM
  3. Safety Wire Pliers?
    By oVTo in forum Bike Maintenance
    Last Post: 05-22-09, 07:34 AM
  4. Anyone need Safety wire pliers?
    By Doc in forum Pit Area
    Last Post: 02-22-07, 02:39 PM
  5. Safety wire pliers on ebay
    By Degsy in forum Pit Area
    Last Post: 03-27-03, 09:05 PM
