I'm having an issue with the front end on my 10r. It seems to like to pogo stick in corners when I hit bumps mid corner. It doesn't seem to settle like it should. I've never adjusted a suspension before. Can anyone give me a rough Idea or point me towards a good how too page to get me started?
check your tire pressure.
i wouldnt mess around with compression/dampning adjustments unless you really know what youre doing. it can make it a whole lot worse
2002 RC51
USMC - Semper Fi
POW/MIA - Not Forgotten
i'd ask in the "Suspension Corner" should get some good info in there.
LRRS EX #165 (formerly)
I did that, Just got the bike serviced... I'm kinda big and heavy so I'm wondering if that's part of the problem? (6'7" 240lbs) I've never had to adjust a suspension before on any of my bikes though... My previous bike was an 02 r1 and it felt perfect from the getgo....
Typical stock bike. Your rebound is probably too soft. Turn the rebound adjusters all the way in, then 1 turn out. That should help. If you have more questions call me.
