Results 1 to 13 of 13
? for you SV Racers
    Ahh why not! lrrs428's Avatar
    Oct 2007
    Littleton NH
    ? for you SV Racers
    I was wondering if i were to buy a SV to race which one would i buy?, can you put a gsxr front end on a SV? Thanks , Adam
    Senior Member marshdrummer's Avatar
    Nov 2006
    Southington, CT
    Re: ? for you SV Racers
    I can't speak for the actual racing part cause this will be my first year, but I kept going back and forth between the gens when I was looking....I went with a second due to the fact it's fuel injected. Carbs and I don't get along.
    Yes, you can put a gxsr front on them. Mine has the 04-05....
    From what I found in my searches:
    1st gen - carbed, stronger frame, stronger motor (slightly less hp #'s), a little cheaper
    2nd gen - FI, little more flex in the frame, better forks
    FYI - 03 was the first year of the FI...It also has some parts that are 03 specific. I stayed away from that one for that reason.....
    Lifer DuncanMoto's Avatar
    Wirelessly posted (BlackBerry9000/4.6.0.297 Profile/MIDP-2.0 Configuration/CLDC-1.1 VendorID/102 UP.Link/6.3.1.20.0)
    Gen 1 is great.
    Send the front end to GMD and Pensky for the rear.
    i would assume the question would be if you wanted to to run SS or SB
    yes its pretty common to run the GSXR Front end, People have gotten good results doing the emultors in the stock forks if you buy a "race bike" odds are the front will be done I woud run the SV front first before doing any "Global" changes
    Zip Tie Alley Racing #444
    Signature edit by Tricky mike
    Oct 2007
    Littleton NH
    all good stuff thanks
    Registered Boozer PPS26's Avatar
    May 2007
    haverhill ma
    we still have one forsale adam!!!!
    Plaistow Powersports Racing
    Lrrs/ccs/ahrma EX #26
    Wirelessly posted (Instinct: TELECA-/2.0 (BREW 3.1.5; U; EN-US; SAMSUNG; SPH-M800; Teleca/Q05A/INT) MMP/2.0 Profile/MIDP-2.1 Configuration/CLDC-1.1)
    I have 750 forks on mine.
    now, while it wasnt a cheap mod, it was simple to do and was worth every penny. the stock gsxr forks are worlds bettef than sv forks. have gmd do them and they only get better.
    I've got a 2nd gen with Ohlins shock & worked (springs & emulators) stock forks to keep it LWSS legal.
    Other than that, just the standard bolt-ons (woodcraft bits, PCIII, pipe, SS lines etc, nothing major) and a stock motor.
    That bike was good enough for 1:18's and 5th place in the 09 LRRS LWSB Championship.
    Supposedly the 1st gen handles a little better, but the difference is marginal at best.
    I say don't be picky. I just went with what was readily available & what I could find the best deal on.
    If racing SS is truely that important to you than keep the stock forks and just rework them, because SS is the only class youll need them in.
    in LWSB, GTL, LWGP, Thunderbike, and Supertwins (and even LWF40) you can run pretty much any mod you want...including slicks.
    so thr real question is... is losing the ability to race in LWSS worth getting better suspension performance (IMO)?
    Word. I used the same line of thinking, I just came to a slightly different conclusion.... reason being, I think the biggest difference between competitive LWSS times and competitive LWSB times is motor work.
    If I could afford to, I'd built a motor, go the GSXR front end & slicks route and skip LWSS, but for now, I think my LWSS bike is plenty competitive as it sits, both in LWSS as well as the other LWSB bikes running stock motors.
    Lifer daviid's Avatar
    Oct 2004
    Plantsville, CT
    Quote Originally Posted by DuncanMoto View Post
    Gen 1 is great.
    only if you listen to LRRS racers, every where else seems to be G2
    i have 2 2nd gens. One has a 06 gsxr front end. its sweet
    -Benjamin Franklin
    Oct 2007
    Littleton NH
    ill have to do a thurs or fri practice on one check this buzz out
  1. For you racers...
    By be4tnut in forum General Bike Related
    Last Post: 10-11-08, 08:25 PM
  2. Anyone know these racers?
    By Doc in forum Pit Area
    Last Post: 06-18-07, 03:20 PM
  3. Racers
    By Degsy in forum Pit Area
    Last Post: 05-03-07, 11:26 AM
  4. 125 Racers...
    By highsider in forum Pit Area
    Last Post: 05-01-07, 09:57 PM
  5. RULES FOR BEGINNING RACERS (experienced racers too)
    By need4speed in forum Pit Area
    Last Post: 04-05-07, 08:42 AM
