Results 1 to 11 of 11
SV rizoma grips
    Lifer obsolete's Avatar
    Norf Sho
    SV rizoma grips
    Rizoma doesn't make grips and levers specifically to fit the SV but I want some bling this off season. Pete was talking about Aron using R6 grips on his SV for better throttle response.
    So the question is, what should I get from Rizoma for grips and levers to fit a 05 SV1000S? Also is there a US online distributor for them or do I have to buy from here. http://www.rizoma.com/
    -Alex
    Uxbridge, MA
    Re: SV rizoma grips
    This is the only US distributor of Rizoma that I know of.
    pjsparts.com
    Great customer service.
    Meriden, Ct
    Re: SV rizoma grips
    Not grips... Throttle tube. (the white thing under your grip) Some folks replace the Suzuki throttle tube with one off of an R1 because the diameter is slightly larger. It makes the stroke to WOT shorter. Basically going from 1/4 turn to 1/5 turn. It doesn't improve throttle "response".
    Cal PJ's like Eric suggested. PJ or his wife will answer. And ask them what the suitable replacement is. I'm sure they can suggest the right thing.
    Norf Sho
    Re: SV rizoma grips
    Pimp! I'll give them a call.
    -Alex
    Re: SV rizoma grips
    i guess i dont understand why you would need grips to be SV specific. a grip is a grip is a grip. levers might take some research but i bet that similar year GSXR levers would be close (at least the brake IDK if GSXR clutch levers are cable)
    Expatriated to Seoul spicy's Avatar
    Reading-> 서올특별시 강남구
    hurray, strikethrough!
    Feb 2009
    mass
    Re: SV rizoma grips
    The 04 R1 tube is plug and play and 1/5 turn, the NEW 06 R6 is 1/6 but it is not plug and play, you'll have to remove 8mm from the end of the puller throttle cable outer housing for clearence in the throttle tube housing, but the 06 R6 is the quickest turn @ 1/6. Either is an improvement.
    High maintenance priss
    Central MA
    Re: SV rizoma grips
    If you're looking at the Rizoma billet grips (which are grip + tube all-in-one)...I find that the throttle control isn't quite as precise(?) vs. a traditional rubber grip. Not horrible, but worth mentioning. They do look sweet.
    Re: SV rizoma grips
    Driven has a knock off of the rizoma's grips for sale....close but Diff
    http://drivenracing.com/content.cfm/...?productid=849
    Re: SV rizoma grips
    Quote Originally Posted by fiahfighta View Post
    interesting
    Norf Sho
    Re: SV rizoma grips
    Good info in here, thanks guys! Anymore info of the levers?
    -Alex
  1. Rizoma Tapered Bars - silver $75
    By whynot in forum For Sale
    Last Post: 08-13-13, 07:26 AM
  2. Rizoma Bar w/ Rizoma Bar End Sliders- $50
    By McBiggity in forum For Sale
    Last Post: 02-22-13, 01:36 PM
  3. Ducati 749/999 Rizoma rearsets
    By shashankmittal in forum For Sale
    Last Post: 05-29-12, 10:08 PM
  4. New Rizoma Mirrors on the Gladius
    By Kenn157 in forum General Bike Related
    Last Post: 06-04-09, 08:44 PM
  5. "Hot Grips" heated grips
    By interceptor in forum General Bike Related
    Last Post: 11-13-01, 04:32 PM
