Results 1 to 3 of 3
Fork abrasion clip, what does it do?
    Aug 2009
    Fork abrasion clip, what does it do?-310043e1-5be2-4bb5-8d43-222b0661c733I just noticed a thin plastic ring dangling from the left fork on my Triumph Rocket III Touring. The parts if he calls it an abrasion clip.
    What does it do and how critical is it to replace it. It’s a $4 part but there appears to be considerable disassembly to put it in.
    Aug 2009
    Re: Fork abrasion clip, what does it do?
    I'm adding some additional information to help sort this out. There are 3 pictures:
    1. The diagram from an online parts vendor showing part #18 circled in red, which I believe is what fell out.
    2. The part description and part number from the same vendor.
    3. The disassembly diagrams from my service manual which does not show this part at all.
    My belief at this point is that the part is not part of the fork mechanicals, thus pic #3, but some sort of protection between the upper fork and the upper fork shroud. Also, it was not broken as in my earlier picture when I saw it. It was only split in one place, it was brittle enough that is snapped again when I removed it from the fork.
    Fork abrasion clip, what does it do?-1-jpg
    Fork abrasion clip, what does it do?-2-jpg
    Fork abrasion clip, what does it do?-3-jpg
    Central MA
    Yes, most dirt bikes have something similar. The WP forks on my KTM have a similar (black) split plastic ring that snaps into place on the bottom of the upper fork slider. Its sole purpose is to prevent the lower fork guard from rubbing the finish off of the upper slider tube.
    In your case, it probably has a similar function, as your bike's fork appears to have a shrouded upper.
    Generally, when they are new, they are thick enough, and flexible enough to open up enough to snap into place without disassembly.
  1. Wanted - Parts & Tools | R6 clip ons
    By Kurlon in forum Wanted
    Last Post: 05-05-20, 07:28 AM
  2. Replies: 7
    Last Post: 07-08-11, 11:07 AM
  3. Changing a fork seal/fork oil??
    Last Post: 08-11-10, 07:58 AM
  4. Clip-Ons
    By 600rr0504 in forum General Bike Related
    Last Post: 08-18-09, 01:19 PM
  5. clip-ons
    By Wishbone in forum General Bike Related
    Last Post: 01-20-07, 01:02 AM
