Results 1 to 25 of 31
time to change air
    time to change air
    it's getting that time of year to take the summer air out of your tires and put the winter air in
    WoW Josephd14's Avatar
    Fitchburg, MA
    time to change air
    I Did this last year, what a Difference it madr.. Sounded corny but worked out great..
    time to change air
    i still have winter air in... can i run it as is or should i change it out for fresh? how many miles do you go between air changes? I didn't do that many miles on my bikes this year.
    Jul 2006
    Hollis, NH
    time to change air
    Can I just bleed it or do I need a flush kit?
    Jul 2006
    Beaches of North Carolina
    time to change air
    Luckily I hit it just right, put new tires on the bike a month or two ago so I have a great mix of the two seasons in there. I think it provides the best traction IMHO
    time to change air
    Time to upgrade to nitrogen......and get those cool green avlve covers.
    time to change air
    Oh damn, I never changed my air this season. No wonder it feels funny.
    Just Registered wookie's Avatar
    Sep 2006
    San Antonio, TX
    time to change air
    I'm not changing untill I have to -- I don't want to lose the 5-6 hp.
    Last edited by wookie; 09-24-07 at 08:04 PM. Reason: becuase I don't know the difference between lose/loose.
    2003 R6 - Track
    2000 SV650 - Street/Track
    time to change air
    It's best to put colder winter air in than you need, so I send my wheels to Saskatoon to get the good stuff.
    time to change air
    I run 4 season air....it's a bit generic and I'm not making the MPG I could be with season-specific air, but I never have down time and I get alot of grip in the snow.
    time to change air
    apparently everyone thinks this thread is a joke, it's meant as a reminder that air pressure flucuates significantly during the change of seasons
    I discovered day before yesterday my rear tire was down to 28 from 41, last time I checked was a week ago, and it's been consistently at 41 all summer...
    a little crazy... 978chris's Avatar
    Haverhill, MA
    time to change air
    hahaha
    checking tires cold?
    you still have the same mass of air in the tires, it's just that in the colder mornings now the cold pressure difference vs. operating temp is going to be greater, since the molecules are all crawling up inside like your peepee in the ocean.
    check them hot. if you fill em too much while they're cold then they'll be over once you're riding.
    you probably already know all this; if so just ignore me. been stuck at home a week on massive oxycodone pills and feeling pretty stupid. i've just never seen an actual fluctuation (once warmed up) that is as big as what you mentioned that didn't involve some other issue (leak etc). but this is my first season riding in a cold part of the country, so....
    2007 GSX-R600
    1997 ZX-9R (sold)
    1979 RD400F Daytona Special (sold - i know, i know)
    Had at one point or another for off-road: KX125, Four-trax 250R, 250 3wheeler, XR250, XR400
    KB KB's Avatar
    Manchester NH
    time to change air
    Ohhhhh no he didn't. Here we go for the 40millionth time on the cold vs warm tire pressure thing.
    LRRS/CCS EX #13
    GMD COMPUTRACK
    Lifer richw's Avatar
    Aug 2004
    Baltic,CT
    time to change air
    Randy checking tires a good thing...
    That much change and I vote for slow leak
    what did the other tire do ?
    Glen Beck is John the Baptist
    Lifer Billy's Avatar
    Feb 2006
    Metro West, MA
    time to change air
    I run helium in my tires. Makes the bike soo much lighter!!!! Oh don't forget blinker fluid flush!
    Winchester, MA
    time to change air
    A good rule of thumb is about 1psi change in cold tire pressure for every 10 degree farennheit change in ambient temperature. It will vary depending on the volume of the tire, but that's a good average.
    time to change air
    To analyze this a little more scientifically, lets use the ideal gas law
    PV=mRT
    Pressure*Volume=mass*gas constant*temperture
    Units matter of course, lets stick with english since everyone knows them. We have to use an absolute temperature scale which is has zero at absolute zero and in the English system that's the rankine scale. One rankine degree has the same change as one farenheight degree. Pressure is in psia, Pounds/inches^2 in the absolute scale. Absolute measures pressure relative to a vacuum as opposed to gage pressure that you get on an ordinary pressure checker which measures relative to atmospheric pressure (~14.7psi)
    We can re-arage the original equation which yields
    P/T=mR/V
    This is helpful since mass, the gas constant, and the volume of the tire can be considered to be constant from one temperature change to another. This allows to equate one temperature and pressure situation to another.
    P1/T1=P2/T2
    P1 and T1 are the Pressure and Temperature in case one and P2 and T2 are the Pressure and Temperature in case 2
    So for instance, let's say that we inflate our tires on a 90 degree Fahrenheit day to the recommended temp of 35psig. Then the temperature drops to 40 degrees Fahrenheit, what will the pressure be?
    35pisg = 49.7psia = P1
    90 F = 550 R = T1
    40 F = 500 R = T2
    thus
    49.7psia/550R = P2/500R
    P2=30.5 psig
    At 20 Fahrenheit
    Pressure drops to 28.6 psig
    At 0 Fahrenheit
    pressure drops to 26.8psig
    Now for a different case, let's say that you inflate your tires on a cold morning before a trackday it's nipply out (30 Fahrenheit) and you go with 28psig knowing that they will warm up a bit. What will the pressure be when you are riding at full tilt and the air in the tires is 140 Fahrenheit?
    28psig = 42.7psia
    30 F =490 R
    140 F = 600 R
    42.7psia/490R = P2/600R
    P2= 37.5psig
    Try it out yourself.
    Honclfibr, your rule of thumb is a pretty good average. However, it is incorrect that the volume of the tire matters, it is irrelevant.
    time to change air
    Quote Originally Posted by Mad Max View Post
    Check your tire pressure regularly & adjust accordingly
    Well put, Chris!
    JACKASS hammadown's Avatar
    Hopkinton, MA
    time to change air
    Is someone studying for a general chemistry exam? You get an A nice work!
    PV=mRT
    P/T=mR/V
    P1/T1=P2/T2
    90 F = 550 R = T1
    40 F = 500 R = T2
    thus
    P2=30.5 psig
    At 20 Fahrenheit
    At 0 Fahrenheit
    28psig = 42.7psia
    30 F =490 R
    140 F = 600 R
    P2= 37.5psig
    Zip Tie Alley #237
    time to change air
    Quote Originally Posted by richw View Post
    probably, but I haven't found one, the past few days I've been checking a couple times a day with no loss
    probably a nail that leaked at first but has sealed itself, sprayed the tire with soapy water, nothing that's obvious
    ny normal routine every morning I pinch the tires in my hand for the obvious, and once a week, I use a tire gage,
    front tire was down 3psi
    Aug 2004
    Baltic,CT
    time to change air
    Schraeder valve it can be seated or have a tiny dirt and not quite seal
    or it may need to be snugged
    Its another Liberal Conspiracy
    time to change air
    Quote Originally Posted by hammadown View Post
    No, just recalling some of the basics from a Thermodynamics course. And I got a C
    Aug 2004
    Baltic,CT
    time to change air
    I have to do it
    Boyle's law is
    pv = nrt
    but otherwise pretty dawm close
    time to change air
    You're right, that is the classical form of the ideal gas law. However n is simply the number the mols of the substance which like mass remains constant and has no bearing on the ratio P/T also being a constant.
    Sep 2006
    San Antonio, TX
    time to change air
    haha, Thermo is a bitch. I got a C also.
    2003 R6 - Track
  1. Long time listener, first time caller!
    By Josephd14 in forum Welcome and Intro
    Last Post: 04-19-14, 11:14 AM
  2. Time for a change?
    Last Post: 09-14-10, 11:40 AM
  3. Name change??
    By EFD 05 1K in forum Site Info & Suggestions
    Last Post: 06-25-10, 04:34 PM
  4. Oil change
    By amajew in forum Bike Maintenance
    Last Post: 08-21-07, 05:13 PM
  5. Brake Pad change time...
    By zx7rou812 in forum Bike Maintenance
    Last Post: 04-02-04, 09:37 PM
