[QUOTE=TLRMan;352374]I was gonna say the same thing about the 32 bit ECU.
Ryno, looks like you can charge $$$ for a yosh box redo!
MY PCII has timing feature disabled, so I'll be going back to that unit again.
Once she's back together, I'll head up to your neck of the woods...haven't seen you in a while...
QUOTE]
Nice to see a familiar name here, Mark. Been a while since I saw you on the SV portal. Riding season is almost here. Cheers Mate!
Sadly, an 01 GSXR 750 will have more HP than our bikes
n00b question...
Was the TL1000R the predecessor to the Hayabusa?![]()
"Harley Davidson: The most efficient way to turn fuel into noise without the risk of power and handling."
Selltekk.
-'04 Yami YZF600R (NOT R6)
- Uberfast Blue color
-Two Bros. Exhaust
-OES Sliders
-Helibars
-Mototeck Flushies
-Factory Pro Shift Kit
<a href="http://www.linkedin.com/in/davefortin" ><img src="http://www.linkedin.com/img/webpromo/btn_viewmy_160x25.gif" width="160" height="25" border="0" alt="View David Fortin's profile on LinkedIn"></a>
No, totally different bikes.
TL is a 90 degree V-twin 996, Busa 1300cc inline four
[QUOTE=SVRACER01;352790]Stock SV1k is good for about 105-107 hp
BMC airfilter, M4 or Yosh 2 into 1, with your head clearance sucked up to .9mm
will get you about 10 more...next step is 2mm larger intake valves, '05 flywheel (stator), and 54mm TB's, JHS cams, and hi comp pistons to compensate.
Now you'll get into the mid 120's to 130hp. Some other head work is involved, but kiss your midrange goodbye. Oh, I almost forgot, toss the stock ECU, and go with a Motec system...will allow for higher revs = more HP. Then you won't need the powercommander.
Stock TLR is good for 114 hp
Responds well to the BMC, Yosh pipes, airbox mods, and Powercommander.
My 1st set up yielded 121 hp.
With the head clearance set, and port clean up. Set the cams at 105 degree centers, and soft limiter bypassed, added another 500 rpm's and went to almost 128 hp. My latest screwing around should net over 130.
You think she'll hold together long term if you end up using the extra RPM's, Tillerman? You know.. trackdays and such.
i dynoed it last year and i think it did about 110![]()
My S got nut that is all @ 50K
www.bostonmoto.com
Forum Rules
www.bostonmoto.com
Forum Rules
I miss mineNever should have gotten rid of it. Oh well, someday I'll have another.
2001 RC-51work in progress
1997 GSXR-600 track only-gone![]()
2001 CBR600 F4i-gone
2002 Suzuki Hayabusa-gone
slip ons, k&n, PC3 with the micron map (i think). i need to fiddle with the PC3 some more
im gonna take the airbox completly off and remove the gas tank. that should get more air in there
can i swim with it?
www.bostonmoto.com
Forum Rules
well the torque reading didnt come through and now that im looking at the sheet and it was all broken up. looks like 106.5 HP and 67.1 TQ. im gonna haffta rerun it.
Hey what happend here?? Though we were gonna do the V-twin day thing? Ryno, Mark, Keena??? beetster...![]()
