Results 1 to 25 of 45
The TL1000s is finally done!!!!!! (well pretty much)......
    Central VT
    Ok, so I bought the '99 TL1000s from mrwog who changed a few things after he bought it from biscuit. I know Paul put on the Ohlins shock and changed the bars among other things, not sure about the Gilles rear sets. Here's pic of when I took the reigns:
    Now I'm not much of a streetfighter fan but was just going to use it for a track bike so no big deal......WRONG!! This thing had the fastest(and most unmanageable by me) turn in I've ever ridden. I figured I'd just put the clip-on's back on and be good to go...... WRONG!! Biscuit had made a new cluster mount that pulled the instruments MUCH closer to the top triple so the clutch cable was not going to work.
    Okey-dokey, now I'm on a quest for all of the stock bits to make it track-able. Go ahead, try to find all of the stock parts in decent shape... After a while I give up on the fairings and decide to go the Shark Skinz route..... the exhaust being hand made by biscuit does not follow the regular aftermarket pipes lines.... start hacking up my freshly painted fairings....
    As of now I believe I've done the following since acquiring:
    - forks replaced with hayabusa forks, internals all pulled, ultra-sonically cleaned and reassembled with 1.1 Traxxion springs
    - added nifty machined pre-load adjusters
    - CHRISPY mirrors with delrin bar ends
    - Buell turn signals
    - Galfer wave rotors
    - '07 GSXR1000 radial calipers with adapters I made
    - '07 GSXR1000 radial m/c
    - Speigler lines in black with red ends
    - front axle sliders
    - extended frame sliders to go thru fairings
    - added stomp grips
    - vandriver rear m/c
    - new chain & sprockets(SuperSprox tri-metal rear) +3 in rear
    - hugger(cheesy plastic one for now just to keep crap off the Ohlins)
    - Scotts damper
    - lots of black powder-coating
    - new pair of Pilot Powers 190/120
    - Superbike grips
    - Zero Gravity tinted screen
    - removed rear fender and installed undertail
    - Clear Alternatives integrated rear turn signals/tail light/rear brake light
    - added led license plate light
    - mirror block off plates from ebay
    Things left to do:
    - install PCIIIUSB(in the garage) and get custom map done
    - install rectifier with +mod done(sitting on PCIII right now)
    - get suspension dialed in
    - cut more fairing of for exhaust clearance(little place on right side)
    - get state inspection and insurance
    - install Lindemann 800 lb. spring on SOAS(during winter)
    - mod and install TLR swing arm(maybe during winter)
    - RIDE!!!
    Jake
    2006 ZX-10R
    1999 Kawasaki ZRX1100
    Super Moderator beet's Avatar
    May 2002
    Meriden CT
    Re: The TL1000s is finally done!!!!!! (well pretty much)......
    Nice Jake
    www.bostonmoto.com
    Forum Rules
    Member gixerhp's Avatar
    Jun 2009
    Nashua
    Very nice!
    Performance: 1397 JE bigbore, Dual Intake cams, Adjustable cam spockets, Sm air box mod,Pc3 usb,Ingnition box w/hub, and Lcd screen, Hindle stepped race header, Dual Fans, 24 volt starting
    Suspension & Brakes: Ohlins road and track forks, Ohlins rear shock, Sprint top mount dampner, PRM top clamp, Dymag Carbon mags, Brembo HP rotors, Brembo Hp radial calipers,
    Show & GO: Topgun undertail, Libertek led lights, Pazzo lever, PMR Switches & Kill,PMR cover. Revolution Custom Paint, Harris Grips.
    Massachusetts' Noth Shoah
    Holy guacamole, nice work!!
    Go fast. Have fun. Repeat.
    Lifer greenmonster's Avatar
    Aug 2003
    Looks awesome...nice job!! Are those ram air ducts with the V2 insignia in the first 2 pics?
    Oh, I forgot to add, I charge double for Kawasaki's
    "My God, you're gonna have to cool me down, give me an ice block to shove in my pants or something".
    -Barbecue Lou
    Lifer obsolete's Avatar
    Norf Sho
    Nice work man! That's a good looking bike!
    -Alex
    ..and I thought the naked TL was hot.
    great job!
    the bike looks fantastic
    so will this be a track bike now?
    was this a restoration project for enjoyment?
    I'd really love to do something like this someday
    Central VT
    Quote Originally Posted by greenmonster View Post
    I'm pretty sure they were wet-vac hose and ends from Sears..... Really....
    Jake
    2006 ZX-10R
    Central VT
    great job!
    Thanks everyone!!
    I bought Noels gixxah750 for track time, I'll be riding this one on the street.
    Jake
    2006 ZX-10R
    High maintenance priss
    Central MA
    Sick TLS, really like it.
    Quote Originally Posted by Uncle Snake View Post
    Things left to do:
    I've got a couple spare TLR swingers that are straight & clean. Hit me up if you end up needing one. Listed them a while back on TLZ for cheap, but shipping tends to kill it for most folks. One of them already has a channel welded for Vans brake hanger (I think a GSXR hanger may work as well...)
    Central VT
    Thanks man, it's been off and on for 2.5 years..... .
    I've got a TLR arm but it's unmodded so far.... How much do you need for the
    one with the channel already welded on?
    Jake
    2006 ZX-10R
    Feb 2008
    Las Vegas
    Soooooo...when we riding Snake!!!!
    Wicked bro, looks very very good. Very happy to see you close to being back on the road again!
    Hows the shoulder/arm/back feeling?
    Carpe Diem
    '10 Yamaha R6-Race-
    Southern, NH
    Excellent work
    Oct 2007
    Peabody Assachusetts
    That really looks awesome! Great job
    Meriden, Ct
    Holy shit Jake! What a transformation. I know there's a lot of slick shit going on there... But the radial calipers with the adapter is absolutely incredible! Nice work.
    Looks awesome. Although I did like what it looked like as a streetfighter.
    giggity
    Member BoxDude's Avatar
    Bend, OR
    Very nice TL! Good work..
    Too cool for sigs.
    Yowza LaRNZ's Avatar
    Oct 2004
    Tewksbury , MA
    not generally a fan of the TLs, but i like this one!
    .:|LaRNZ|:.
    Senior Member marshdrummer's Avatar
    Nov 2006
    Southington, CT
    Sweet 'S'!
    Cabin Fever kb1's Avatar
    Dec 2008
    Down South
    Very nice looking bike!
    Wow! Awesome job Jake!
    CCS/LRRS #83
    Feb 2009
    Burlington
    that thing looks great man!
    Old and Slow Sheppo's Avatar
    Westford, Ma
    that thing is S I C K ! !
    Good Job !
    Posted by Jane in BoxChat
  1. TL1000s gearing
    By aneweira in forum General Bike Related
    Last Post: 06-21-10, 04:56 PM
  2. 1999 suzuki TL1000S
    By aneweira in forum For Sale
    Last Post: 03-05-10, 04:10 PM
  3. 1997 Suzuki TL1000S.
    By Jank in forum For Sale
    Last Post: 05-30-07, 10:48 PM
  4. TL1000s info please
    By Uncle Snake in forum General Bike Related
    Last Post: 11-08-06, 11:10 AM
  5. Still can't decide what to buy: TL1000S maybe?
    By number9 in forum General Bike Related
    Last Post: 12-10-05, 08:54 AM
