Results 1 to 16 of 16
SO I got me a track bike...
    Old and Slow Sheppo's Avatar
    Westford, Ma
    Some guy in NY wanted my RD's real bad. So I traded him.. Both RD's for a '97 GS500 all set up for track days... well sort of.
    It has all the good stuff, I conferred with Kurlon before the purchase. It has Keihin CV Smooth bore carbs, a full Yoshi exhaust, after market rear sets, braided stainless lines, track plastics and allegedly engine work to match the good stuff. Here's my issue, Wiring, I can get it to run, but the wiring harness was hacked and spliced etc. I am working through it. Can someone explain to me how the started button works? Should power be getting to it to send to the solenoid OR??? Here's the diagram and I can't for the life of me see how it works. I understand most things but this has me stumped. I wont get back to it until next Wednesday...
    http://www.bbburma.net/Scans/Haynes_...m_US_90-96.jpg
    Here are some pics of the beast...
    Attached Thumbnails Attached Thumbnails SO I got me a track bike...-imgp2346-jpg   SO I got me a track bike...-imgp2345-jpg   SO I got me a track bike...-imgp2342-jpg   SO I got me a track bike...-imgp2344-jpg
    Posted by Jane in BoxChat
    Lifer JettaJayGLS's Avatar
    Tahoe City
    Re: SO I got me a track bike...
    Awesome! See ya out there.
    The starter button gets power from the kill switch. When the kill switch is on you should have power on the orange and white wire coming out of the switch, and the coils. This line also feeds the TCI box and starter button. When you press the starter button that sends juice down the yellow/green line, through the clutch safety switch if still present, to the starter relay.
    The kill switch gets fed via the orange/blue wire, which goes to the sidestand relay if still present.
    The relay has it's own power feed, a black/white line that it uses to drive the starter motor when triggered by the starter button.
    So, things to check if chasing the starter:
    kill switch
    starter button
    sidestand switch
    sidestand relay
    diode
    clutch switch
    starter solenoid
    neutral switch
    I'll see if I can reduce the diagram down to a race only minimalist setup for you. You can defeat the sidestand and clutch switches by shorting them out with a jumper at their connectors and the OEM harness will assume you've always got the clutch in, sidestand up so you can start it at any time.
    Westford, Ma
    Josh,
    I must not be getting power up to there.... Although With the key on I can jump the solenoid to get it to start/run.
    I would appreciate a minimalist diagram.. thanks
    Doug
    Westford, MA
    Congrats and good luck Sheppo! Lemme know if ya need a hand with that.
    Oh and when you do get that thing running, you'll never use all that power!
    Haverhill, MA
    SO I got me a track bike...-gs-wiring-jpg
    Here is a start. Not a great one but what I could whip together in a few minutes. Hope it helps. Let me know If I royally screwed the pooch on anything and I'll fix it.
    Joel
    Doug, I know you're a smart dude and all but I must ask, have you checked the contacts and wire connections inside the starter button?
    Josh,
    Doug
    Ok, so if it'll run that way that rules out the kill switch, ignition switch, solenoid... there is power to the coils, so this has got to be a safety. If it'll stay running when you put it in gear that clears the sidestand safety gunk.
    Does the neutral light work?
    Do you have a meter or test light? If so, key on, in neutral see if you get voltage at the yellow/green wire coming out of the right hand switch cluster.
    Westford, Ma
    see just talking to some one I got it figured out somewhat. I'll let you know next week. (when I have the time to work on it ) I do have a Neutral light. I am sure it has to do with the hacked wiring not the connections Bergs I've been over those. I now see how the power gets into the kill switch starter button and I can't honestly say if the bike is wired correctly in that area OR if the Side stand relay is borked... I am sure it's not rocket science I just needed to talk it out a little bit. Thanks.
    Westford, Ma
    Joel
    thanks Joel. I think that will work well with what I understand needs to be.
    Westford, Ma
    Josh,
    I was running off a coke bottle of gas. I didn't put it in gear. baby steps
    Fair enough. I had to ask when you mentioned that it worked after jumping the solenoid because I experienced a button contact issue with a bike and saw the same results after jumping the solenoid.
    Best of luck on getting that thing sorted
    Westford, Ma
    It's all Good Paul, Sometimes we over look the obvious. Thanks
    Westford, Ma
    Thanks for talking me through this. I spend yesterday getting rid of un-needed wires and straightening out what someone with no knowledge of how to read a wiring schematic started. It's pretty well sorted out now. I need to change the oil, put on new rubber and sign up for a track day.
    Thanks, Josh, Joel and Paul. Oh Rossco, I used all the power ( in 1st gear )
    Lifer Pittenger5's Avatar
    Austin
    Awesome Duck! Congrats!
    Zip Tie Alley #505
    Awwww yeah!
  1. Any cart track/small track/slow bike days?
    By nick5446 in forum Pit Area
    Last Post: 04-26-21, 12:41 PM
  2. For Sale - Motorcycles | 2008 Ducati 848 track bike - very light use on track days / 3 races
    By brass_rat in forum For Sale
    Last Post: 05-30-15, 05:48 AM
  3. Wanted - Motorcycles | Cheap track EX500 or some other small/light track bike
    By DanRo in forum Wanted
    Last Post: 10-28-14, 02:42 PM
  4. Replies: 55
    Last Post: 09-24-14, 06:19 PM
  5. track bike or track prepped street bike
    Last Post: 10-23-08, 05:51 PM
