Results 1 to 14 of 14
Wheel Chock
    Lifer Rye's Avatar
    Nov 2002
    Behind Enemy Lines
    Wheel Chock
    What are you people using for front wheel chocks on your trailers? I want something removeable, reasonably priced, and will not contact rotors (320mm). Also looking for a local supplier for tie down rings. I want something sturdy. They don't have to flush mount.
    '95 ZX7/9
    '02 XR650R
    '78 KZ1000
    Pepperell, MA
    Wheel Chock
    I got an E-Track set up in my trailer for a very resonable cost with lock in D-Rings. You can have options to reposition tie down points where ever you want!
    This company used to have a wheel chock that went with the E-System, I didn't see it listed though??
    http://www.etrailer.com/
    E-Track link w/tie down points: http://www.etrailer.com/Merchant2/me...tegory_Code=ET
    www.tailofthedragon.com
    Wheel Chock
    I don't use any chocks in my trailer, I just have my own special way of tieing stuff down.. 5 tie downs per bike please and it's not moving
    Pepperell, MA
    Wheel Chock
    If you do get wheel chocks, make sure they are wide enough or the rail is low enough so it doesn't fuck up your rotors!
    I always use my wheel chocks! I just feel better about it staying more stable. To each his own! What ever works!
    Also Rye, do a search for pocket chocks! They fold down flush with the floor when you don't need them! BBZX10 Formally known as BBZX12 ( Brian has them ) He needs his screen name changed back to BBHZX12 again... (Degs/Jay/Gord/Dan)
    He folds them down for hauling sleds and doesn't have to store the chocks elsewhere like I do!
    Lifer mycirus's Avatar
    Aug 2003
    Whitinsville, MA
    Wheel Chock
    Get a sportbike chock. They work great.
    Bruce
    Feb 2004
    Bellingham, MA
    Wheel Chock
    Use the 8 inch and put the bike in backwards. I have several that have lasted for 6 years of heavy use with no problems.
    http://www.blackandgray.com/main.htm
    100 X slower than Gerard scootertrash's Avatar
    Alton Bay, NH
    Wheel Chock
    The free approach if you want something quick and easy:
    Find a scrap piece of plywood that's about 2' x 2'.
    Find 3 scrap pieces of 4" x 4" that are around 1' long each.
    Arrange the 3 pieces of 4x4 in a "U" shape on top of the plywood. Space them appropriately for your tire size.
    Screw the 4x4 into the plywood from underneath the plywood.
    Attach your newly built wheel chock to your trailer using screws, bolts, set pins, or what ever clever way you want. Can be easily removed as necessary.
    Wheel Chock
    3 feet of 4 x 4...check!
    2 x 2 piece of plywood...check!
    Handfull of woodscrews...check!
    Thanks Gordo!
    Pepperell, MA
    Wheel Chock
    Originally posted by Stoneman
    3 inches...check!
    2 x 2 fold out Playgirl spread...check!
    Handfull of wood...check!
    Thanks Gordo!
    Wheel Chock
    what kind of trailer? can you put the tire against something (wall or rail on trailer)?
    i have one of these in the back of my pickup. built in chocks and tiedows its called a box bar and you can get it from parts unlimited or WPS and probably others too
    Wheel Chock
    Originally posted by Half Squid
    So am I. Can ya let me know when I get to the funny part?
    Pepperell, MA
    Wheel Chock
    Whats not to get? You jerk it to Gay porn...
    That right there was funny, I don't care who you are!.... Shiiiiiiiiiiiiiit...
    FYYFF theothersean's Avatar
    middle of nowhere
    Wheel Chock
    I used the 4x4 method on the flat bed utility trailer we had they are high enough to hold the wheel in place but don't come near the rotors. it looks more like this l_l
    I didn't screw them to plywood though I screwed them right to the trailer as I didn't need to move them. They worked well for me and as far as I know the guy that bought that trailer from me still uses that set up with out issue.
    The enclosed trailer we have now has chocks that fold into the floor, they came with the trailer when we bought it used so I don't know how much they were but I would say they are not cheap.
    12 Vstrom 1000
    09 KLR 650
    (hers)
    13 Vstrom 650ADV
    09 KLR650
    Lifer Currently's Avatar
    Ooltewah, TN
    Wheel Chock
    I got a pair of BikePro chocks. They do clear the rotors.
    They are not fantastic but they do get the job done.
    I tried to buy the chocks made by the same folks that make
    EazyRizers and he never answers his phone. You got to leave
    a message but he can't call me back cause I work in a call center.
  1. For Sale - Parts & Tools | Wheel Chock
    By DucatiGuy in forum For Sale
    Last Post: 06-29-20, 02:39 PM
  2. For Sale - Parts & Tools | Pingel Wheel Chock, WC 350
    By Rumble in forum For Sale
    Last Post: 04-11-17, 06:28 AM
  3. For Sale - Parts & Tools | Flip Up Wheel Chock
    By Mustang in forum For Sale
    Last Post: 08-13-14, 01:05 AM
  4. Wheel Chock
    By Half Squid in forum Wanted
    Last Post: 09-13-12, 05:34 AM
  5. Wheel chock
    By j4eric in forum Wanted
    Last Post: 08-15-11, 10:15 AM
