Results 1 to 10 of 10
Do I need a tune or re-mapping?
    Lifer 01xj's Avatar
    CT
    2014 Multistrada 1200. Bought it over the winter completely stock. Didn't do anything significant to it other than a mid pipe (deletes the cat) and an aftermarket can. Should I be running a Power Commander, Rapid Bike, or some other tuner? My last long term bike was my Triumph and I could change things around with TuneECU and a laptop, so it wasn't too much trouble to upload a new map. With the multi I'm not positive what the right move is, if I should add anything? The bike seems to run okay, there is no popping on decel or anything, but I don't have a real good way to determine how rich or lean it actually may be running. I'd rather not pull half the bike apart to periodically look at spark plugs.
    Jamnuts jhawley's Avatar
    Oct 2009
    Southern CT
    Re: Do I need a tune or re-mapping?
    have you had anyone ride with you behind, do they reek of fuel after a few miles?
    Lifer 01xj's Avatar
    CT
    No one to ride with so I'm not sure on that end. I start it inside the bay at work snd it doesn't smell overly rich.
    Lifer jimmycapp's Avatar
    Oct 2008
    NW CT
    It would be running leaner not richer with those mods, typically. I don't have any experience with that bike. Probably better off on ducati forum. I'm sure it's been beaten to death.
    Oct 2018
    Quote Originally Posted by jhawley View Post
    I can’t believe I used to pay John to dyno and tune my bike when I could have just had you follow me!
    Joe you’re the best.
    Adam I don’t have much to add. If it were me I’d probably leave it alone if it was just the slip on, but coupled with the cat delete I would likely bring it to someone to tune properly.
    Lifer 01xj's Avatar
    CT
    It has. Since it's on the older side there's a ton of info. Filtering through the posts and topics is more of the issue.
    Guess I'll try power commander first and have it tuned a dyno shop who supports them.
    Hypertarded
    RI / CT border
    Not sure on that year multi, but check to see if there is a Ducati OEM "race" ECU they sold with the Termignoni full system. I know for my Hyper there was a new Race ECU they sold with the exhaust to compensate for the removal of the cat., may be able to find one of those on the forums / Ebay...
    New Haven-ish, CT
    Just keep it stock, you damn hooligan.
    Sep 2007
    Also, look into a Rexxer tune by the dealership. It takes them a couple of days but they dial the bike properly. I think it is around $400
    Feb 2011
    Somerville MA
    I would personally always go with an external "box" like a PowerCommander to modify fueling, because the theoretical possibility of bricking an ECU on a Ducati gives me the fear.
    Not a reflection on the engineering prowess of the TuneBoy folks or anyone else, and I'm sure the internet contains well-reasoned disagreement.
    Edited to add: Once you start changing any hardware that modifies AFR dynamics, I can't think of any reason (other than cost) to avoid at least attempting a remap. If I'm shopping for a used bike with swapped exhaust or airbox parts, I want to see a PowerCommander and hear about the map, even if the answer is "I picked a map that sounded close and it runs fine."
    -Jared
  1. For Sale - Parts & Tools | Bazzaz Z-AFM Self Mapping Kit
    By Punjistick in forum For Sale
    Last Post: 02-15-15, 03:45 PM
  2. Mapping experience - Ducati 998
    By sandros in forum Vermont Events
    Last Post: 05-03-11, 07:33 PM
  3. Power Commander mapping
    By Doc in forum Pit Area
    Last Post: 05-21-08, 11:27 AM
  4. Need Mapping Website/Software
    By HBerry in forum Rides & Events
    Last Post: 03-27-05, 09:46 AM
