Page 3 of 3 FirstFirst 123
Results 51 to 74 of 74
twin vs inline?
  1. #51
    Old and Slow Sheppo's Avatar
    Westford, Ma
    Re: twin vs inline?
    Quote Originally Posted by R1 View Post
    Twins only for the torque factor alone....
    Fixed it for you...
    Posted by Jane in BoxChat
  2. #52
    Lifer Pittenger5's Avatar
    Austin
    Re: twin vs inline?
    Singles are the best
    Zip Tie Alley #505
  3. #53
    Lifer R1's Avatar
    Somewhere you dont know...
    Re: twin vs inline?
    Fixed it for you...
    torque = wheelies
    Re: twin vs inline?
    Twins are to 4 strokes as inlines are to 2 strokes.
    Although my RM250 does wheelie on command
    old guy with bikes
    Nov 2009
    Re: twin vs inline?
    I have had both Twins in line fours and Turbo in line fours.
    My last twin was a 05 999. It was an incredible bike a chassis that was telepathic. Insane tourque off the line From 0-60 faster than my turbo busa. In the 4 years I had it I put 4500 miles on it because the Ergos killed me. There is no quiestion to me that a twin "feels" more controlable. Inpart cause you are not having to fan the gear box.
    Feb 2008
    Devon/Surrey, England
    Re: twin vs inline?
    Go for an opposed twin! Two singles having a fight in opposite directions
    Re: twin vs inline?
    I've owned at least 1 single, 1 parallel twin, 1 V twin and 1 inline 4.
    All I need is a triple and I'll have batted for the cycle
  8. #58
    Lifer obsolete's Avatar
    Norf Sho
    Re: twin vs inline?
    The only inline motor I like has 6 holes and gets dirty.
    -Alex
  9. #59
    Lifer R1's Avatar
    Re: twin vs inline?
    most circles would already consider you well rouded
    live to ride seth399's Avatar
    Feb 2007
    CA
    Re: twin vs inline?
    vtwin vs inline...it's like a 450 4stroke vs a 250 2stroke in the dirt
    *edit* damn cssmutty beat me to that!
    LRRS #399
    MX #505
  11. #61
    Re: twin vs inline?
    You should know best, since you can't get laid.
  12. #62
    Austin
    Re: twin vs inline?
    Quote Originally Posted by 07BladeRider View Post
    Zip Tie Alley #505
  13. #63
    Re: twin vs inline?
    Quote Originally Posted by seth399 View Post
    I read through the whole thread and was really surprised that nobody posted up that comparison. The only place it doesn't work is that inlines are used for the top racers, where 4 strokes are used for top racers.
    Feb 2007
    CA
    Re: twin vs inline?
    haha true
    LRRS #399
    MX #505
  15. #65
    One could say that may be because torque rules dirt, hp rules pavement?
  16. #66
    Expatriated to Seoul spicy's Avatar
    Reading-> 서올특별시 강남구
    Re: twin vs inline?
    hurray, strikethrough!
  17. #67
    Lifer BSR6's Avatar
    Re: twin vs inline?
    This really only applies to those who are mountain/road bikers on the site but...If you really want to get an idea of the difference between power delivery on a twin versus an inline four try riding a bicycle with different length cranks.
    I used to run 175mm cranks on my mountainbike, til one day someone suggested I try a shorter crank arm. I went to 170mm and just that small 5mm difference was huge. I felt like a completely different rider. I used to work at a bike shop in highschool, and one of the factory reps told me that the cycling institute actually does Dyno sessions with cyclists to research power output etc. I guess longer cranks give more leverage but make it difficult to spin at higher pedal RPMs. The increase in leverage shows more torque on the "dyno" but slows the riders pedal RPM's. Shorter cranks are easier to spin quickly but the lack of leverage means less power per thrust of the pedals, in this case they see higher power but less torque on the cycling dyno.
    He actually used motorcycles as an analogy. He said the easiest way to explain it, is that longer crank arms are like a twin, and shorter crank arms are like an I4. It makes sense since I4's give a smaller bang more frequently, where as a twin delivers a bigger thrust with each firing of the pistons due to larger displacement per cylinder, but less often seeing that they rev lower. Also, I believe the stroke is typically longer in a twin so the leverage issue increases the "more thrust less often" concept. There are advantages to this type of power, which is why the crossplane firing order of the new R1 is such a hot topic.
    The cycling comparison is true, I have experienced it myself. A good cyclist will notice immediately that with shorter cranks you spin much faster in a natural more comfortable manner. With the longer cranks you spin slow and tend to want to turn bigger gears. For the record when I switched to the shorter cranks my average speed went up per ride so it seems to be the better way to go in terms of overall results. The longer cranks were better for climbing and mud pits...but the shorter ones were giving me more speed in the long run.
    Its a good analogy cause your legs are like the displacement of the engine. You can see how the same pair of legs (same cc's in engine size) can deliver power differently, and actually feel the difference first hand being that you are the power source.
    Feb 2007
    CA
    Re: twin vs inline?
    Quote Originally Posted by BSR6 View Post
    interesting, I have 165mm arms on my hardtail jump bike mainly because its what I had when others bent and it also makes it closer for my feet to pinch the seat for nohanders and stuff. I can see what you describe though, its kidna tough to get going but once I am upto speed I can spin very quickly.
    LRRS #399
    MX #505
  19. #69
    Huh.... Interesing! Makes total sense, too.
  20. #70
    Re: twin vs inline?
    Get the best of both worlds with a cross-plane crank I4 (new R1) or V-4
    Always love for the V-Twins though. Who can say no to two big jugs?
    CCS/LRRS #83
  21. #71
  22. #72
    Re: twin vs inline?
  23. #73
    Lifer BSR6's Avatar
    Re: twin vs inline?
    Seth, get on a bike with 175's after riding those 165's for a while and you will really know what I am talking about.
    May 2007
    Southern NH
    Re: twin vs inline?
    Quote Originally Posted by brewmaster View Post
    Bump
    Figured this was a good winter subject to warm the keyboards.
    shouldnt you be making beer or something?
    Muhammad Ali.
  1. Inline 4 to a Triple?
    By csmutty in forum General Bike Related
    Last Post: 10-28-11, 09:32 PM
  2. inline 4 jap to a duc 848??
    By boloson in forum General Bike Related
    Last Post: 07-03-10, 07:02 PM
  3. V-Twins Vs, Inline 4's
    Last Post: 07-24-07, 10:27 AM
  4. V-Twin or Inline-4
    Last Post: 05-04-07, 07:46 AM
  5. Info about inline 4's and V-twins...?
    By marcv125 in forum Bike Maintenance
    Last Post: 02-24-05, 02:35 PM
