Page 3 of 6 FirstFirst 123456 LastLast
Results 51 to 75 of 131
V-Twins Vs, Inline 4's
  1. #51
    Originally posted by ZX-12R
    That is not exactly true. Any vehicle's peak acceleration is found at its peak power output, not its peak torque output. All other things being equal, a higher powered vehicle will be quicker than a less powerful one.
    In a motorcycle, I-4 engines produce significantly more power for any given displacement then the twin counter part. This is due to a number of reasons including combustion efficiency and engine balance. As a result, you will be hard pressed to find a twin that can out run an equivalent sized I-4.
    if you could get a twin to spin that high then i bet it would. your comparing a motor that evrrything is moving together(I-4) to a Vtwin that is almost working against itself.
    i got mine because i like the sound
  2. #52
    Lifer Wishbone's Avatar
    Jul 2006
    first off the itallians do do it better (wops) look at the history of races and the fact that thats all they make. neat i LOVE ducsbut am not rich so the matnence kills you, also the jap fours are WAY more dependable, my 620 monster blew up with 61787 miles on it my fizza is going strong with only oil changes with 12k plus. so in summary all the working class stifs go with a jap four if ya got a bank roll go itallian, jap twins are like triump 4s that right i said it now go ahead and start all the pissed off jap twin owners firing back
  3. #53
    Member R-S-V's Avatar
    Apr 2005
    A good comparision is the Master Bike shoot out, I'm sure most here know about it, one bike is picked from all types (600, 750, lliter I4 and Twins, etc) after several performance tests. This year a vtwin took the crown, so they can't be as far off in performance as people like to believe.
    Granted I have not been on any of the recent I4 liter machines, but for me, the twin are so satisfying. No need to worry about what gear I'm in, instant thrust anytime in any gear, and that glorious sound, I just can't get enough. They are also very good track weapons, they just need to be ridden differently (so I've heard, have yet to do a track day myself so I'm no racer).
    As for Aprilia vtwins, back off They make great power and the 04 and up are lighter and have a good top end (mine is still making power when the rev limiter kicks in).
    Eduardo
  4. #54
    Originally posted by SVRACER01
    ummm.... my SV650 makes MORE torque than a zx6R
    and it doesn't wait till 10,000 rpm to make it's torque either, the SV 650 is within 5lb/ft of it's peak torque throughout the rpm range
    twins are much more streetable, they have enuf power everywhere that you don't have to worry about getting out of your own way without downshifting 2 gears
    who cares about peak power, it's just a meaningless number
  5. #55
    Super Moderator beet's Avatar
    May 2002
    Meriden CT
    Which is why you find so many Diesel engines on the race track!
    HP is a man made #some college boy made up .. torque is a real #
    the only bad thing about twins is 4 cams instead or 2 = heavy .
    You have a Diesel on your bike ? I sure don't ..
    www.bostonmoto.com
    Forum Rules
  6. #56
    Lifer ZX-12R's Avatar
    Candia, NH
    What???
    Horsepower is just as real as torque. It is a measure of how much work an engine can do.
    These horspower vs. torque arguments spring up because most people when asked can't give a good definition of either.
  7. #57
    Screw the I-4s and twins.... get a big single thumper.....Bwaaaaaap
    May 2002
    Meriden CT
    What???
    No way HP was made up to sell cars
    " In scientific discourse the term "horsepower" is rarely used due to the various definitions and the existence of an SI unit for power, the watt (W). However, the idea of horsepower persists as a legacy term in many languages, particularly in the automotive industry for listing the maximum rate of power application of internal-combustion engines."
    "In physics, torque can be thought of informally as "rotational force". The SI units for Torque are newton meters although centinewton meters (cN·m), foot-pounds force (ft·lbf), inch pounds (lbf·in) and inch ounces (ozf·in) are also frequently used expressions of torque. The symbol for torque is ô, the Greek letter tau. The concept of torque, also called moment or couple, originated with the work of Archimedes on levers. The rotational analogues of force, mass, and acceleration are torque, moment of inertia, and angular acceleration respectively. The force applied to a lever, multiplied by its distance from the lever's fulcrum, is the torque. For example, a force of three newtons applied two metres from the fulcrum exerts the same torque as one newton applied six metres from the fulcrum. This assumes the force is in a direction at right angles to the straight lever. More generally, one may define torque as the cross product:"
    www.bostonmoto.com
    Forum Rules
  9. #59
    yeah... it more of a torque "table" then a curve. my G/F has a 750 I4. its fun to have that stupid kind of top end. but just like on any I4 the power doesnt come on until halfway up the rev range. who rides around town at 9K+ RPMs on their I4? no one. if that was the case then there would be no need to shift. my G/F bike goes 80+ MPH in 1st!! thats at least 30mph OVER the speed limit on the highway. like BEET said.. I4s are automatics. Twins make you work for the fun and thats half the fun.
    When i tell people hao much tap dancing im doing on the shifter around the track.. the I4 guys always say.."why are you shifting so much?" because i have to i rode Dans bike around NHIS and i think the only place you shift is the straight, i think you just leave it in 3rd around most of the track. is that right Dan? BOOOORING!! fast but boring
  10. #60
    Pepperell, MA
    [QUOTE]Originally posted by ZX-12R
    Underwelmed by a ZX-14? Are you sure all the plug wires were installed? Power wise the 14 is in an entirely different league then the RC-51 so I'm not sure how it was underwelming.
    Maybe you should check out an SV650. I've seen one that consistently beat an RC-51 up at New England Dragway
    [/QUOTE
    Originally posted by jwm2k3
    Maybe that had something to do with the riders ability?
    You fuckers... There will be a re-match some day when I don't have to fucking work..
    I will never let this down until I beat OXX....
    In My mind TWINS RULE!!! I love the power where ever I feel the need to use it! No dead spots anywhere! I moved from an underpowered YZF600R right onto the RC51 and will have a very hard time moving back to a I4.
    BUT NOTHING BEATS THE SOUND OF A GOOD TWIN WITH NICE PIPES!
    www.tailofthedragon.com
  11. #61
    Ride my Rex, 70ftlbs by 3 grand.
    of course, 1200cc compare a 1200cc twin... 70ftlbs as soon as it's off idle
  13. #63
    Candia, NH
    I've said it before, the concept of "power" and its relation to torque is lost on most people. The term "horsepower" and its associated physical meaning has been in use long before automobiles came to be. Just because the standard unit of power is the Watt doesn't mean there are no other ways to express it. Look at distance measurement. 1 Mile is the same as 1.6 Kilometers. Is either one of them more or less real then the other? Power is the same way. 1 HP is the same as 745.7 Watts; 550 lbs-ft/sec; 33,000 lbs-ft/min; 42.4 BTU/min; or 178.3 calories/sec. All of these units are ways of expressing power. Because of its origins in quantifying a power source's ability to replace farm animals, the term horsepower has forever been associated with all forms of engines and motors.
    The resource that you quoted offers no support to their assertions which is all too common on the internet.
    The "horspower doesn't exist" theories you see floating around usually come from the anal scientific community that does not like having multiple units to describe the same physical property.
  14. #64
    Member Tiller Ayuh's Avatar
    Greater Portland, ME
    I knew this is what this would turn into...People with I-4 saying their I-4's make WAAAAY more power than L-twins...I-4's cc for cc would eat a twin...HP's better than torque..Blah...Blah...Blah...I think I've read these type of posts 100 times...I don't care what anyone says, an L-Twin with aftermarket exhaust sounds WAAAAAY better than an I-4 with aftermarket exhaust...
    I guess I don't care if a magazine says an I-4 makes 10 - 30 horses more than a twin...Mostly comes down to rider...I don't get my underwear in a bunch because my bike's not the fastest bike out there...I don't care...It sounds NIIIIICE!!! I like what I ride...just my $.02
    07 Ducati 999S Team USA
    04 Ducati ST3
    66 BMW R50/2 - Project
  15. #65
    Candia, NH
    I can say for certain that my SV650 with a slip-on sounds much meaner than my 12R with a factory exhaust! When I get around to getting an aftermarket pipe on the Kawasaki, I'm going to have a hard time deciding which I like better!
  16. #66
    May 2002
    Meriden CT
    ok horse power predates autos
    "A horse power (also rendered horse-power) is a now largely-obsolete machine for using draft horses to power other machinery. It is a type of animal engine somewhat more sophisticated than a horse mill. A common design for the horse power was a large treadmill on which one or more horses walked. The surface of the treadmill was made of wooden slats linked like a chain. Rotary motion from the treadmill was first passed to a planetary gear system, and then to a shaft or pulley that could be coupled to another machine.
    Horse powers were used to power farm implements and industrial processes. Examples of machines that were powered with a horse power include the threshing machine, the corn sheller, pumps and machines for sawing wood. Horse powers were modular in that they could be attached to whichever implement they were needed for at the time, preventing these machines from needing to incorporate power sources into their design. They could also be used interchangeably with other forms of power, such as a hand crank, line shaft, stationary engine, or the PTO shaft or flat belt pulley from a tractor, which eventually replaced them.
    The name of the horse power probably predates the name of the horsepower unit of measurement. (For reference the 1864 Webster's Dictionary defines Horse-power as “A machine operated by one or more horses; a horse engine.")
    www.bostonmoto.com
    Forum Rules
  17. #67
    Tifosi RSVMILLE661's Avatar
    Oct 2004
    Somewhere between here and there
    I agree that the twins sound better. Thats the whole reason why I bought one. (2 actually)
    My first twin was a super chicken. While a fun streetsport it left a bit to be desired in the twisties due to rubber like chassis. Talk about flex.
    My Mille' was a fantastic ride and thanks to the help of Peter Kates and Mike Marterie, it was fairly well sorted when I sold it. I am now saving my pennies for a new (04 or later) Mille' to set up again.
    Scott Major
    Ferrari Fix it Club Racing
    ALMS, SCCA, LRRS, CCS, FUSA #'s 161, 62, 676, 661, 205, 12, 60, 89...
    Karloff? Sidekick? FUCK YOU!! That cocksucker does not deserve to smell my shit!
  18. #68
    Andover
    I'm confused, so far I've learned that a 1000cc v-twin is almost as good as a 750cc I4??? And that V2s have more torque or something?
    So I went to Sport Rider and found that Honda's 600s are faster then their RC51 and that a 954 has more torque on a flater curve that the RC51 on a lighter bike with less displacement. Forget about the newer bikes.
    Sorry I guess
    Oct 2004
    Scott Major
  20. #70
    May 2002
    Meriden CT
    Originally posted by RSVMILLE661
    http://en.wikipedia.org/wiki/Horsepower
    All you need to know.
    LOL wikipedia is where I go Scotts a git
    www.bostonmoto.com
    Forum Rules
  21. #71
    Oct 2004
    Sorry I guess
    1000 cc twins are the "equivolent" of a 750 4cyl machine.
    As for what sets a faster lap time, it all depends on the track. At NHIS the track record for CCS / LRRS is held by a 600cc 4cyl machine. Certain tracks suit certain bikes better than others.
    Scott Major
  22. #72
    Oct 2004
    I learned it by watching you.. Beet!
    Scott Major
  23. #73
    ....... Nazo's Avatar
    Jul 2004
    I have both and still love an inline 4 overall
    However V-Twins do have more character.....especially an Italian.
    I love my Duacti 996....I'm not a fan of any other bikes that are supposed to be in the same class though. V-Twins are fun to ride and do offer a different experience with their low end torque.
    Downside though is the low RPM range and extreme engine breaking when you let off the throttle.
    I also have a Honda 600RR for my racebike and would never imagine being as fast on a V-Twin.
    The power of an inline 4 in my opinion is comparable to that of a 2 stroke dirtbike......When the RPMs rev up, the bike comes alive.
    I only ride 2 stroke dirtbikes as well.
    Inline 4's have a longer power range and less engine breaking. If your talking about liter bikes, you won't find any V-Twin that can match the power of an R1, Gixxer 1000 ...etc.
    Its all preference and opinion I suppose. Its a good topic, but its like argueing about religion
    I'm glad I have both and don't have to choose one or the other.
    P.S...Jay just badmouths my Ducati because he knows he can't afford one and even if he could its too classy for him......Hessoghetto
    Chris
    LRRS Expert #160
  24. #74
    Andover
    I like the Duc's too, shame they're always in the way.
    Oct 2004
    In a perfect world I would have a Tuono for the street as well as an MV Brutale 910R. The track would be a Mille' and a GSX-R 600.
    Again best of both worlds.
    Scott Major
  1. Inline 4 to a Triple?
    By csmutty in forum General Bike Related
    Last Post: 10-28-11, 09:32 PM
  2. inline 4 jap to a duc 848??
    By boloson in forum General Bike Related
    Last Post: 07-03-10, 07:02 PM
  3. twin vs inline?
    Last Post: 12-02-09, 01:28 PM
  4. V-Twin or Inline-4
    Last Post: 05-04-07, 07:46 AM
  5. Info about inline 4's and V-twins...?
    By marcv125 in forum Bike Maintenance
    Last Post: 02-24-05, 02:35 PM
