Results 1 to 10 of 10
Urgent: Need a Radiator
    16L MACK POWERED GSXR... Boston Chuck's Avatar
    Apr 2008
    Boston/Philly/Western MD
    Rode home smoking with coolant all over the engine. Took the fairings off and low and behold theres a pee sized hole in my radiator pissing coolant everywhere. The bike is an 03 1000. Does anyone know if a radiator from an 01-02 will fit? And if so, anyone have something lying around?
    Thanks in advance.
    -Chuck
    Just some dumbass
    Lifer DaSarge's Avatar
    Oct 2002
    Cape Cod
    Re: Urgent: Need a Radiator
    Whats the easy fix for this...I know some one knows...The JB weld fix?
    An "03 1000"? I have one of those but it's a Yamaha.
    Willard's Radiator in Hudson, NH is the place to go to repair that.
    AMA wannabe lrrs699's Avatar
    RI,NH, Derby,ct
    Quote Originally Posted by DaSarge View Post
    JB weld should do the trick. I dont have a box i front of me but i think it can hold through that temp.
    LRRS Expert #99
    08 R6
    "why tip-toe through life to arrive safely at death?" Tony Campol
    To quote PK, I "went in too hot and ran out of talent".
    Wirelessly posted (BlackBerry8330/4.5.0.160 Profile/MIDP-2.0 Configuration/CLDC-1.1 VendorID/105)
    It can. Jb weld. Mask off a square in duct tape and apply two thin layers of jb.
    Lifer akira700's Avatar
    Apr 2005
    in the city
    If that dont work then
    check these guys out.
    They fixed mine for less than a new one.
    Rogers Auto Radiator
    389 Riverside Ave
    Medford, MA 02155-4932
    (781) 395-7777‎
    2008 Honda CBR 600RR
    Ense petit placidam sandman's Avatar
    sema
    even better than jb is epoxy (like jb) designed for aluminium radiator repair
    jim
    "Molon labe"
    May 2007
    Southern NH
    Here's a nice one...!
    (...wouldn't have hijacked this if you hand'nt already gotten some good info..!)
    Muhammad Ali.
    NorthShore
    Well, not to hijack further, after you get it fixed, why not get one of these? I installed one on the C-14 before the trip up, and trapped in it up there, I found big bugs, couple of dings from rocks, various and sundry chunks of grass, leaves, and it all blew off with the brush of my hand, leaving the radiator unscathed when it would have had fins flattened all over. Those things are really soft, the fins. The grid stands off about a half-inch from the fins. It didn't change the cooling characteristics, either. For a lousy 90 bucks, it was a good find. The one I got was this one, but the pics up close of the two bottom guards show the grid better than the pics of the one I bought from Cox Racing. Hope it helps after ya get fixed!
    http://shopping.netsuite.com/s.nl;js...=2&category=61
    The branded ones below are a lot more expensive, like $190.00, but are the same mesh and mounting. They come from here:
    http://projektd.com/index.php?cPath=...f908790c4330da
    Apr 2008
    Thanks for the tips. I work at the Mack engine facility so I brought it downstairs to see if one of the mechanics could fix it. He took it and said he would let me know, otherwise im going to try the JB technique and/or epoxy. Thanks guys.
    Just some dumbass
  1. urgent ! help needed in marlboro!
    Last Post: 04-23-12, 12:49 PM
  2. *Urgent - Rear Tire Help
    By jsven007 in forum General Bike Related
    Last Post: 08-12-03, 10:15 AM
