Page 2 of 2 FirstFirst 12
Results 26 to 35 of 35
voltage regulator test?
    I Dance With Will
    Oct 2002
    unknown
    Re: voltage regulator test?
    there it is, "something you should know". honky explains things very well.
    "fuckit!"
    I Dance With Will
    Oct 2002
    unknown
    Quote Originally Posted by rbrais View Post
    OK, I lied. One morething;
    You may have had a problem before jumping it, which may be why the battery died in the first place. Drains can be hard to locate. Could be something as simple as a wire that is grounding out on the frame, or a bad speedo/tach (if they are electronic); maybe a bad switch somewhere. Hard to say, but if you have a Honda, they are known for having the voltage regulators go bad because they are undersized and can't disipate heat adequately, at least on the bikes from the late 90's.
    i put hte kickstand down and left the key on.
    "fuckit!"
    Lifer rbrais's Avatar
    Brooklyn, CT
    Good to know, thanks!
    Like I said, just going by what mechanics have told me. Maybe they are wrong, too. I don't have the technical knowlede to give a sure answer.
    Brooklyn, CT
    Well, I guess you found your original draw.
    Now you need to figure out why it won't hold a charge.
    Simple explanation you cannot fit a car battery into a motorcycle battery.
    I Dance With Will
    Oct 2002
    unknown
    where you from?
    i need to figur eout if the original regulator is still good.
    "fuckit!"
    Brooklyn, CT
    CT.
    Sorry, not good with testing things like regulators. I let the shop diagnose it than fix it myself if I can. Swapped my stock Honda Super Hawk R/R with one from a 2001 R-1. Works great and is much larger than the Honda was; and it has cooling fins.
    What kind of bike is yours?
    Jul 2006
    Hollis, NH
    Can someone take over? My arms are getting tired.
    Honci is correct. Current capability of the charging system makes no difference. In fact, the current potential of the car battery itself is more than the charging system could produce so turning the car off doesn't "current limit" anything.
    If you don't understand the water analogy, think of the dome light in a car. It's drawing ~0.05 amps from the battery when it's on. The battery it's connected to is capable of delivering 100 amps. Do all 100 amps flow to the dome light? The motorcycle battery you're jumping is like the dome light. It will only draw what it needs to charge. Nothing more ...
    I Dance With Will
    Oct 2002
    unknown
    Quote Originally Posted by Ćheese View Post
    just to add - it draw according to what the regulator tells it to i should say.
    "fuckit!"
    Lifer Wishbone's Avatar
    Jul 2006
    Stop making sense. This is the interwebs and I will not stand for it
  1. WTB: voltage regulator 95 monster m900
    By SCRLT01 in forum Wanted
    Last Post: 06-22-12, 11:52 AM
  2. MOSFET type voltage regulator
    Last Post: 07-16-10, 05:40 PM
  3. sv650 voltage regulator
    By PPS26 in forum Wanted
    Last Post: 05-06-10, 06:01 PM
  4. Voltage/regulator rectifier??
    By FireFly in forum Bike Maintenance
    Last Post: 10-15-05, 09:47 PM
